What is the best camera flash with rechargeable battery (not AA) for Nikon DSLR?
Started Mar 1, 2022 | Discussions
cybersnap
cybersnap New Member • Posts: 22
I am looking for a camera flash for my future Nikon DSLR mirrorless.
I have found that all Nikon flashes come with AA batteries.
Do you know what are, if any, camera flash comparable to those by Nikon but with batteries that can be rechargeable (not the AA type)?
Thank you.
 cybersnap's gear list:cybersnap's gear list
Nikon D7000
NickZ2016 Veteran Member • Posts: 6,275
Re: What is the best camera flash with rechargeable battery (not AA) for Nikon DSLR?
You don't like AA?
How much do you want to spend? How much power?
Nikon seems to have started working with Profoto and Nissin for third party flashes.
Profot A10 isn't exactly cheap. To say the least
Godox would be much more budget friendly
 NickZ2016's gear list:NickZ2016's gear list
Nikon D800 Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 35mm f/2D Nikon AF-S Nikkor 50mm F1.8G Nikon 85mm F1.8G +4 more
Ellis Vener
Ellis Vener Forum Pro • Posts: 19,805
7
The Godox V1 gets my vote. It is also sold by Adorama as the Flashpoint Zoom LI-ON R2N.
Ellis Vener
A working photographer since 1984.
To see my work, please visit http://www.ellisvener.com
Or on Instagram @EllisVenerStudio
 Ellis Vener's gear list:Ellis Vener's gear list
Nikon Z6 Nikon Z7 II Sigma 70-200mm F2.8 EX DG OS HSM Nikon Z 24-70mm F4 Zeiss Batis 40mm F2 CF +4 more
Thomas Hegna Junior Member • Posts: 40
Godox V1 is a great off camera flash. It’s also compatible with the godox radio trigger and all of the bigger Godox flashes.
it’s a great alternative to the OEM flashes.
calson Forum Pro • Posts: 10,717
Use rechargeable AA batteries like the Powerex ones. That is what everyone else uses with camera speedlights. It is only the studio level flash like the Quantum Qflash where rechargeable battery packs are useful.
The advantage of the rechargeabel AA batteries is that you can start the day with fully charged batteries instead of putting new alkaline AA batteries in the flash each day.
The only issues are with flash that use only two AA batteries and so provide half the voltage level to the flash capacitors. Stick with flash units that take 4 AA batteries.
"It is horrifying that we have to fight our own government to save the environment." Ansel Adams
 calson's gear list:calson's gear list
Nikon D5 Nikon D850
john isaacs Veteran Member • Posts: 8,966
Thank you.
It depends on what you mean by "best".
But you can look at the Godox V860II for regular shape speed light, or V1 for round head speed light.
kli
kli Veteran Member • Posts: 4,677
Godox would be the typical recommendation since they started the whole li-ion battery pack flash craze.
Also, are you sure AAs aren't going to be sufficient? While the li-ion pack can last 2x-3x as long as a set of AAs, unless you're an all-day wedding shooter or someone who has portrait sessions booked back to back 5 days a week, you may not actually require them. And they do warrant a bit more care,more constant use (I.e., they can die if you don't use them for long periods of time), and are harder to get your hands on than AAs (which you can find at any big box store).
If you're talking speedlight (hotshoe flash), Godox makes six models of Li-ion powered speedlight. All their models named with "V" use a lithium ion battery pack; the "TT" models are AA-powered (and are less expensive and [aside from the TT350] have an external battery pack port). Which one is the best fit for you depends on how you plan to use it and your budget:
  • V350-N ($160). Mini-speedlight but does TTL/HSS. Less swivel (270º) and power than the full-sized models, only 16 channels and roughly 1/3 the radio range as a transmitter. Also no recycle beep and no sync port. But very small and light and great to balance on small mirrorless bodies for on-camera use. [$85 TT350 counterpart]
  • V850 II ($140). Single-pin manual speedlight, but radio transceiver built in allows for remote power/group control and HSS. Cannot be firmware updated. [$65 TT600 counterpart]
  • V850 III ($160). Refreshed update to add ID codes and to make its UI more uniform with the V1. But still manual single-pin and still not firmware updateable.
  • V860 II-N ($180). Full-sized TTL/HSS speedlight with traditional fresnel head. [$110 TT685-N counterpart]. The only model in this list that can also do Nikon's "smart" optical CLS/AWL communication.
  • V860 III-N ($230). Full-sized TTL/HSS speedlight that's basically a V1 with a fresnel head. [TT685 II-N sorta/kinda counterpart]
  • V1-N ($260). Top of the line round-headed flash with addition UI updates, including a slight backwards head tilt, TCM switch, LED lamp, and slidelock on the foot instead of a screwlock. UI overhaul and some new functions (SCAN) added.
Also, the VB26/VB26A packs that are used in the Mk III and V1 models is only 2x the capacity of a set of 4xAA; the VB18's (in the older II models) capacity is 2.8x.
Other options would include Profoto's A10 ($1000 or thereabouts pricetag), and the Jinbei HD2-Pro/Westcott FJ80.
Keep in mind, none of these flashes (aside from the Profoto) are going to be quite as good at TTL consistency/accuracy, overheat protection, AF-assist or fit'n'finish (not to mention forwards/backwards compatibility) or customer/warranty service and factory repair as an OEM Nikon speedlight. Lower pricetags gotta come from somewhere.
And, that, as per usual with any 3rd-party reverse-engineered gear, if you're contemplating getting a very new camera body mode there may be some compatibility issues that require firmware dates that may not yet exist, since Godox can only reverse-engineer against what exists at the time they created the flash.
 kli's gear list:kli's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS 50D Panasonic Lumix DMC-GX7 Canon EF 135mm F2L USM +12 more
Bob Veteran Member • Posts: 4,511
You can buy rechargeable AA’s.
Greg Presseault
Greg Presseault Junior Member • Posts: 27
On the topic of rechargeable, I've been using EBL high capacity rechargeable for my flash and sometimes, even when freshly charged, I've had issues with longer then expected recharge times. I've heard Enloop's are better, but at a decent price hike.
Can anyone chime in on this as it does relate to flash choices?
Thanks! Sorry if this is considered a thread hijack. Not my intention.
I have some older Eneloops are they're great. Lately they've been hard to come by. I bought my set in part to get the nice four battery charger to use when I travel.
The question usually comes down to use case. Most amateurs could just buy a big box of Amazon Nihms and swap them during the day. It's not like the difference will be that great.
Greg Presseault
I don't suppose there's a lithium rechargeable that was made to fit a 4 AA battery slot?
Is there another rechargeable company you would recommend other then Enloop?
Ellis Vener
A quick search found these: “Amazon Basics 8-Pack AA Batteries, High-Capacity 2,400 mAh Rechargeable Battery, Pre-Charged, Recharge up to 400x, Green, High Capacity (2400 mAh)”
Ellis Vener
cybersnap
OP cybersnap New Member • Posts: 22
I wrote in this forum to know if rechargeable AA batteries are suitable for occasional use like mine (a whole morning once in a while) or you have to buy them every time.
If so, I think I'm better off with the supplied battery from one of those camera flashes I mentioned earlier.
So the experience of users who have used the latter option is essential.
Nikon D7000
Greg Presseault
Those are NiMH, not lithium.
Macro guy
Macro guy Veteran Member • Posts: 6,134
Thank you.
You can get the Godox 685N with a PB960 power pack. That's a lithium pack and will provide about 2,000 full power flashes on a single charge.
 Macro guy's gear list:Macro guy's gear list
Canon EOS 5D Mark II Canon EF 50mm F1.8 II Canon EF 70-200mm F4L IS USM +4 more
The whole point of NIHMs is you recharge them. You invest in the batteries and charger. Better ones have more power and claim higher number or charge cycles. But none are use one and toss.
cybersnap
Thank you.
Mi sai dire se per un uso saltuario per esempio una o due mattinate al mese funziona bene o corro il rischio che non ricarichi più e bisogna comprare un'altra batteria? Ty.
Nikon D7000
Comprati dei NIHM. Amazon rivendica 1000 cicli di ricarica.
cybersnap
Il punto è l'uso saltuario, diciamo una mattinata o due ogni mese. Poi ricaricherebbero o devo comprare un nuovo set di NHM?
Ecco perchè mi chiedo se le batterie in dotazione al Godox siano migliori per il mio uso.
Nikon D7000
Mark B.
Mark B. Forum Pro • Posts: 30,051
Rechargeable NiMH are the best.  A set of 4 will cost about $10 USD, and can be recharged at least 1,000x.  Get a couple sets and a good charger.  That way you can quickly swap to a charged set if they run down.  Then when you're done just charge both sets back up.
