tammons
Re: OM.S (Olympus) Telephoto lens question for birding
ikolbyi wrote:
I presently own the OM.S. (Olympus) 40-150 F2.8 Pro with 2x TeleC MC-20 .... 300mm f5.6 effective view. My images at the long end are softer than I would prefer unless I am shooting at ISO 400 and below. I only have this issue with this lens combination.
Has anyone else experienced imaged softness with this combination?
Out of curiosity, does anyone have on-hands experience using that combination against this native lens for comparison?: OM.S 100-400mm F5.0-6.3 IS
I'm curious if the $1,400 cost would be justified over my existing setup? One benefit I do see is the extra 100mm reach (200mm FF equiv reach). But how is image quality?
The 2x TC does degrade IQ somewhat depending on the quality of your lens and 2x TC you have.
IE, at one time I thought I had an iffy lens/2x combo and so I sent my lens to Oly to have it checked out and it was fine.
Then I tested my current 2x against a 2nd new 2x from B+H and the one from B+H was worse by far.
Also you might want to try E shutter with the 2x TC.
All that said, it's best to stick with the 1.4x TC unless you absolutely need the additional FL.
A good combo is the 40-150 F2.8 + 1.4x TC, and the 300mm F4 + 1.4x TC if you need it.
That works out to 40-300mm F2.8, 56-420mm F4 equiv, 600mm F4 equiv, 840mm F5.6 equiv. The 1.4x TC doesn't really degrade the IQ at all.
I have not used the 100-400mm lens, but from what I ahve read, IQ suffers at the long end. And it cannot dual sync IS where the 300mm F4 can. The 300mm dual sync IS is good enough to hand hold with the 2x which is pretty amazing, but you have to use E shutter, else you will get 1-25+- keepers.
