Canon T4I - Wont take pictures of pure white paper
Started Feb 28, 2022 | Questions
dinsum New Member • Posts: 2
Hi,
I just picked up a used Canon T4I with the canon EF-S 18-135mm IS STM Lens
I just updated firmware from 1.0.1 to 1.0.5 without problems
I put the camera in M mode and it has no problems auto focusing and taking pictures but I am trying to take a closeup picture of a white piece of paper to see if there is dust on the sensor but for some reason the camera just won't take a picture of it. The only way for me to be able to take a picture of it is if I flip the switch on the lens from Auto focus to Manual focus
Is this normal operation? or could there be a problem with the lens/camera?
Thanks!
Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
Dunlin Senior Member • Posts: 2,611
Re: Canon T4I - Wont take pictures of pure white paper
Cameras find it hard to focus on plain surfaces because there's a not enough contrast.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
Oldpanda Forum Member • Posts: 96
I would expect that behavior
If there is no detail (contrast), the auto-focus will have no way to determine if it is in focus.
My T8i will not auto-focus on a blank computer screen of any color, but will auto-focus on a screen with writing or pictures. It will also auto-focus on a light colored wall with texture on it. That is what you need to do or manually focus.
Glenn
I
 Oldpanda's gear list:Oldpanda's gear list
Canon PowerShot G11 Canon EOS Rebel SL2 Canon EOS Rebel T8i (EOS 850D) Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +4 more
Aoi Usagi Veteran Member • Posts: 3,221
5
As others have mentioned, without contrast, the AF can't lock on. There is also a limit to how close you can auto focus. Are you within the lens' minimum focus distance to take the photo?
If you want to check how dirty the sensor is, just set the lens to F22, minimum focus distance and take a photo of the clear blue sky.
bridge77 Contributing Member • Posts: 959
maybe take a few different shots of the white paper with a small X on the paper. now you have something to focus on, different positions if you are concerned about the X.
Ray UK Contributing Member • Posts: 977
If you are looking for dust on the sensor then focus doesn't matter. Set the camera to M or AV. Set the lens to manual focus at the smallest aperture (f22) with a very slow shutter speed, position the camera pointing at a white sheet of paper so that it fills the image, press the shutter speed and move the camera whilst the shot is being taken.
The slow sutter speed and moving the camera will blurr out any marks or reflections on the paper, the small aperture will make any dust marks more obvious.
I will say it again "Focus doesn't matter" and the best results will be obtained when the lens is way out of focus.
This depends on how you want to search for the dust. In my post I stated that focus to MFD and shoot the sky, aka something far away. This blurs out any objects that may appear to be dust, like aeroplanes, flies, birds etc. This makes it easier to see dust in this particular way. Setting focus at infinity may show these objects, which may appear as dust. Setting Shutterspeed in this case, does not matter, as long as it is properly exposed. Your last sentence is a bit odd. You say "Focus doesn't matter" and then state "best results will be obtained when the lens is way out of focus". Well than the focus does matter a little, doesn't it.
Yes that would work but it is still easier to use a clean sheet of paper especially if you live in a country where clear blue skies are a rarity.
OK, so I should have said "correct focus doesn't matter"
Gray, overcast skies work too.  Probably not at night though.
Understood.
rmexpress22 Senior Member • Posts: 2,304
Draw a tiny line on the center to give the camera something to focus on.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
