SL1 and my old Canon Lenses
Started Feb 26, 2022 | Discussions
MikeM58 Contributing Member • Posts: 657
Newbie... so not sure if this is the right forum, if not, let me know and I'll move it to the correct one.
My question is simple: I have a collection of Canon lenses, from my film days and was wondering if there's an adapter that I can get so that I can use these lenses on my SL1?
 MikeM58's gear list:MikeM58's gear list
Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D Sigma 30mm F1.4 EX DC HSM Sigma 17-50mm F2.8 EX DC OS HSM +2 more
Canon EOS Rebel SL1 (EOS 100D)
OP MikeM58 Contributing Member • Posts: 657
Re: SL1 and my old Canon Lenses
Found my answer. Looks like it's a lost cause with these old lenses. From what I've gathered, focusing to infinity will be an issue with these lenses.
Well, I tried to see if any thing has changed since the last time I looked into this.
Aoi Usagi Veteran Member • Posts: 3,221
If you are referring to Canon Fl/FD/FDn lenses, there are adapters that can work with your modern Canon camera.  The adapters have optics inside them to make infinity focus possible.  There are a few downsides though.  First, the optics in the adapter may decrease contrast and sharpness of the lens.  Then there is the issue of the adapter being a slight teleconverter design.  This means the focal length will change, not counting the 1.6x crop for APS-C. However, even with these flaws, the lenses will still work with your camera, manual focus and aperture of course.
They're EF lenses.
rmexpress22 Senior Member • Posts: 2,304
5
Then you just slap them on the SL1 and you use them as you normally would.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
5
MikeM58 wrote:
They're EF lenses.
Then you do not need an adapter.  They should be fully compatible and able to focus to infinity.
Aoi Usagi wrote:
MikeM58 wrote:
They're EF lenses.
Yes I do need an adapter. The lenses don't connect. Different connectors on them. I've tried. Doesn't even come close.
MikeM58 wrote:
Aoi Usagi wrote:
MikeM58 wrote:
They're EF lenses.
All Canon EF lenses are compatible with Canon EOS EF and EF-S bodies. They all have the same mount, with the same flange distance so they do not need a adapter. What lenses are you trying to use?
Canon lens compatibility
Digirame Forum Pro • Posts: 41,857
Using old film lenses for digital DSLR cameras might not be always best. The digital EF and EF-S lenses are so relatively inexpensive; that's all you might need to get the best quality. My favorite EF-S lens that I bought on Ebay was my previously owned 18-135mm USM lens. I got it for a price of about $150 including shipping. I've never seen one priced that low. It is still being used and is high quality (for the price). I was fortunate that it was in such good condition.
Are your film lenses FD mount instead of EF mount? If we can't help and you still want to use your old lenses, consider asking this question on the Canon SLR Lens Talk forum. From what I read a few minutes ago the previous poster is right that EF lenses should work on your Canon SL1 (100D) camera without an adapter. That's why I'm questioning the mount.
Aoi Usagi wrote:
MikeM58 wrote:
Aoi Usagi wrote:
MikeM58 wrote:
They're EF lenses.
Canon lenses from my old AE1... film. Which I think is the problem.
stevet1 Senior Member • Posts: 1,300
Mike,
Then they are not EF lenses. They are probably FD lenses.
I had an AT-1 camera that had the FD mount. I got a Fotodiox Pro adapter to allow me to use my FD lenses on my Canon T6. Just be aware that it will be manual focus, and you have to manually set your aperture.
You can get one of those adapters on Amazon here:
https://www.amazon.com/Fotodiox-Adapter-Compatible-Lenses-Cameras/dp/B003EB0AXY/ref=sr_1_5?keywords=Canon+FD+Lens&qid=1567281061&s=gateway&sr=8-5
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Canon AE-1 use Canon FD mount, and not EF mount. If you are still looking for an adapter, see my first post.
davev8
davev8 Veteran Member • Posts: 4,837
No well not in any meaningful full way  the adoptor has to have an optic which is not very good
i have quite a fetish for MF glass and use a 50mm f1.4 FDn  and others regularly
now trying to focus MF glass through the poky SL1/100D viewfinder is a challenge
its best to use the live view as with canon a dab and swipe  or 2 will have you zoomed in 5 or 10X anywhere on the back screen forgoodt focusing  .. which is not much good to you if you can't fit the lenses
But all canons with a touch interface are like this which means the canon M mk1 MILC (or any other M body} which will fit any MF lens as adaptors are made for about every mount and is very cheap ..the big problem with the M was VERY slow AF but that don't matter to you
i dont know what your budget is or how many FD lenses you have but a better option that gives you an EVF and focus peaking to help with focus when using an VF is the old Sony full-frame A7..again one of the main problems with the A7 was poor AF
so its just an option for you to think about
be warned the MF lens bug can be pretty contagious and you may end up with more MF lenses than AF lenses
Attention Dislexsic i mean dyslexic person... This post will have many although spell checked, spelling and grammatical errs ..its The best its going get so no need to tell me it is bad I know it is .....................................................................................................
the EOS M is not dead and wont be for a long time ....as long as you don't want a flagship camera with a VF...if that's the case it died sometime ago
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
If you wait for a camera that will  tick all your boxes ....by then you will have more boxes to tick..... so the wait continues .....David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
I probably misstated what the lenses were... so it appears that they are FD lens. I have about a half dozen of them. I hate to just throw them away if they could be used.
davev8
no, i understand that they are FD lenses from Canons manual focus film cameras
they will adapt to any mirrorless (ML) body very well but not to DSLRs very well like your SL1
as i say in my last post, it may be worth getting a cheap ML body to use them depending on what they are they are, as they are getting more expensive to buy on ebay
a quick look on eBay UK the 1st Canon FD 50mm f1.4 i see sold  in completed listings went for 119GBP
Lisa Horton
Lisa Horton Contributing Member • Posts: 694
Don't throw them away!  If they're in good usable condition sell them to KEH and use the money you get to buy EF lenses for your SL1!
 Lisa Horton's gear list:Lisa Horton's gear list
Canon EOS RP Canon EOS R10 Canon EF 24-105mm f/4L IS USM Canon PowerShot SX10 IS Canon EF 85mm F1.8 USM +6 more
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Hello...
I like my SL1 and all the len(s) fit on it.
Can you find one on B&H store?
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
That's an idea.
Sue Anne Rush wrote:
Hello...
I should look.
Thanks!
mdmarqphoto Senior Member • Posts: 1,460
As already mentioned, your FD lenses will work (manually of course) on mirrorless cameras with a simple adapter.  They will also work on your SL1 for closeup work with an adapter without glass in it.  I use my FD 135mm on my DSLR for flower photos all the time.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
