Underwater housing
Started Feb 25, 2022 | Discussions
AngelFish Regular Member • Posts: 296
Underwater housing
GDome have brought out a Mirrorless/DSLR underwater housing that is much more reasonably priced than others I have seen. Wondered what peoples thoughts on it are?
https://getgdome.com/products/gdome-xl?variant=42058242588926
 AngelFish's gear list:AngelFish's gear list
Nikon Z50 GoPro Hero9 Black Nikon Z 16-50mm F3.5-6.3 VR Nikon Z 50-250mm F4.5-6.3 VR Nikon Z 40mm F2
kelpdiver Veteran Member • Posts: 5,564
Re: Underwater housing
3) The GDome XL is rated for 5m/15ft max depth, we know it can go deeper however we limit the rating for the safety of your camera. The GDome XL is not a dive housing and should not be treated as a dive housing due to the flexible rear membrane. If you would like a housing with a solid backdoor (that will be able to achieve a deeper depth), they are available (optional extra +$35), however, you will need to add your own buttons in order to get the functionality that you require.
This product is aimed at the pool crowd, and maybe the topside snorkelers.   I don't think it would be up the the task for surf photography.
From a price perspective, you can get model specific housings from Seafrog for 3 digit prices for many cameras.
While those aren't universal, neither truly is this product which requires specific modifications to use the shutter.  The 10 bolt closure also makes it awkward to use.   Last, the universal design means a bulkier housing and while the optics will be fine for the flat port, the image quality for the dome rely on the appropriate distance for the camera/lens combo, and may not be achievable in the one size fits all design.
Barmaglot_07 Contributing Member • Posts: 633
I would hesitate to call it 'underwater', or, indeed a 'housing'. Looks like one step above a soft bag. It's flexible, so you can't use it at anything even resembling a depth - my guess is at 1-2 meters everything will get pushed in. No vacuum system, so higher chance of leakage. Extremely bulky as well, and unlike a soft bag, you can't roll it up.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
Sheena Marie New Member • Posts: 3
ISSUE IS SORTED
POST IS DELETED
Bobby Handal
Bobby Handal Veteran Member • Posts: 5,839
Thanks for the link, its interesting for several reasons, but specially its "universal" appeal for any camera body. For shooting surf and for snorkeling , more than enough.
Having said that , for about the same price you can buy a Seafrogs housing w/ lens port , but not the dome one. And its much more secure, me thinks. Albeit not universal, you must sell the housing if you change cameras.
 Bobby Handal's gear list:Bobby Handal's gear list
Nikon Coolpix AW130 Nikon 1 V1 Sony Alpha NEX-6 Nikon 1 V2 Panasonic Lumix DMC-GX7 +84 more
Wet Willy New Member • Posts: 1
First time out and it's great so far. The Gdome XL surf is awesome
Brett Eagle
Brett Eagle New Member • Posts: 2
I am a little biased as I am one of the owners of GDome. I can definitely tell you from a lot of experience that even with the flexible rear back screen, it can take a beating in the waves, so it is not like the other soft bag options out there. It also comes with the solid backdoor in the surf edition configuration (not sure if you have seen the hammer test we did? It can literally take a beating with a metal hammer so you can imagine what it is capable of!) We did not design the XL range to go deep, it is mainly made for shallow applications.
We have really focused on offering the most value for money out there, so much so that we are offering a free XL for anyone that can beat this challenge:
https://www.linkedin.com/pulse/get-free-gdome-xl-surf-edition-challenge-brett-eagle
Is that an 18" wave there?
As tor the "challenge," no one will be able to collect given the long list of subjective descriptions and specific design choices.   It's like the job postings that government agencies post when they are doing an internal hire, but still have to go through open recruiting.
Brett Eagle
it is a fair point, happy to bring it down to a universal housing that comes with a pistol trigger, dome port & flat port with full rear touch functionality 😉
it is pretty much an impossible challenge to be honest, but hopefully it shows what great value we offer 😎
