How good is the RF 100-400 for Sports?
Started Feb 25, 2022 | Questions
NorthernMike New Member • Posts: 6
Hi everyone,
I'm just getting back into photography after a hiatus of several years. Ordered a new Canon RP because it fits my budget and seems like it should be a huge updrade from the Rebel T1i that I've had since 2009ish.
One of the main things that I'd like to do with this camera is take it with me to an Ultimate frisbee tournament in June and try to get some nice shots of the action on the field.
I have a cobbled together collection of primes and wide-mid range zooms that I've collected over the years, but the only lens that I currently have longer than 100mm is an old EF 75-300 (https://www.canon.ca/en/product?name=EF_75-300mm_f/4.0-5.6_III&category=/en/products/Lenses/EF-Lenses/Telephoto-Zoom) that I have found to generally not be worth carrying around most days. I don't usually take a tripod with me, so it's pretty rare that I'll have an opportunity to shoot at the longer end of it's range, and most times I'd rather just use my 100mm prime (https://www.canon.ca/en/product?name=EF_100mm_f/2.8_Macro_USM&category=/en/products/Lenses/EF-Lenses/Macro), which I love.
So the question that I'm getting to:
Is the new RF 100-400 likely to be a huge difference for me over the old 75-300?
I'm thinking the IS alone will make it much more usable for the shooting that I do, and I'm wondering if anyone has experience to share with using it for sports. I realize that it's not going to perform like a lens that costs 10-20x as much, but I'm curious if it's likely to be "good enough" or if I'm just going to end up deciding that it's almost never worth the weight and leaving it behind like the 75-300?
Thanks in Advance!
 NorthernMike's gear list:NorthernMike's gear list
Canon EOS 500D Canon EF 28-80mm f/3.5-5.6 II Canon EF 75-300mm f/4.0-5.6 III USM Canon EF 100mm f/2.8 Macro USM Canon EF-S 18-55mm f/3.5-5.6 IS +2 more
MarshallG
MarshallG Veteran Member • Posts: 8,951
Re: How good is the RF 100-400 for Sports?
Member Birdbrain thinks very highly of the lens. Check out this thread for his thoughts and the opinions of others. To be honest, it’s either this $650 lens or else you’re north of $2,000.
https://www.dpreview.com/forums/post/65597055
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
Leigh A. Wax Senior Member • Posts: 1,621
Slower lenses are not considered ideal for sports, and the RF 100-400's F8 is a bit on the slow side.
Although F5.6 is not exactly fast, I think perhaps, if you can afford it a used EF 100-400L-2 would be a better choice, as it has "L" quality optics, and top-notch lens IS.
spec68 Contributing Member • Posts: 530
Thanks in Advance!
I don't have, never used either the 100-400 or 75-300, but reading the description in your link about the 75-300, yes, I think you'd be frustrated using it for sports - it has a DC motor which means it's AF will lag the R's capabilities. It also seems like it's a starter level kit lens, geared more for static travel and grip and grin type shots than fast action.
That said, if you are hesitant about buying another lens why not give it a test run and prove to yourself whether it's "good enough," for your purposes or not. Zero cost to do that -- other than the adapter, which, I'm sure you could get a full refund on if you decide to then buy the 100-400.
tdbmd Senior Member • Posts: 1,546
From an image quality, the RF 100-400 is miles ahead of the old 75-300.  The question may be more of the AF capability of the RP.  It will work but has a fairly slow fps
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
OP NorthernMike New Member • Posts: 6
Thanks, that's pretty much what I thought.
I realize that the RP is not really considered a great choice for sports, but it seems like it's overall a good fit for me, and I'm trying to figure out what I need to make it also do some sports shooting.
I've found generally that I'm happier in the long run putting the money I do spend into lenses, since there's always a better body around the corner. The 100-400 looks like it's probably worthwhile, and at that price seems pretty reasonable if it will actually let me play with those longer focal lengths. I guess I'm just a little paranoid that if I don't buy an L lens I'm going to end up disappointed like with the 75-300 and end up with 2 lenses sitting at home instead of one. Getting more and more confident that this isn't the case, though.
Thanks! That post by birdbrain was quite helpful. They certainly do seem to like it, and there are some great shots in there. One of the things I was worried about was whether the narrow aperture would be limiting for faster moving scenes, but there are afew beautiful shots of birds in flight, so it's probably not going to be a concern outdoors.
Thanks for the suggestion, but going over budget isn't really an option right now.
This is more of a "go ahead and get it" or "no, it really won't work for that" situation for me, since I don't really want to spend that much, or be stuck carrying a giant heavy lens on a 2-week vacation.
I realize this wouldn't be the best lens for shooting sports (definitely not the best camera, either), but it seems like it should be a pretty big step up from what I've used before, and I'm wondering if anyone has some experience trying it?
Yeah, that's more or less the plan for now. I'm definitely going to have the adapter for all of my other old lenses, and I've got a couple months before I'll probably be doing much outdoor photography.
MarshallG
9
Ok, so here’s the thing: He could buy an R3 for $7,000 and attach a $3,000 telephoto, but he has an RP and wants to know if a $650 lens will work out. He understands that it won’t be as perfect as a $10,000 setup.
In practical terms, he’s asking two questions: Will the $650 lens be notably better than the 75-300 (YES!!) and will the $650 lens be good enough, or does he HAVE to buy a $2,300-ish lens? I’d say that he can get much better photos with the $650 lens, but will run into problems if it gets dark. And the background blur won’t be as good… still, the $650 lens should give him great results.
The RF lenses in general, seem to be quite good, whether they are "L" or not.  I only have 2 RF lenses, the 35mm and the 24-240 and have been very happy with the IQ from both of them.  I have shot with the 75-300 and it is far and away the worst lens I have ever used on any of my Canon bodies.
I agree.  And the ML bodies handle the higher ISO much better so the 100-400 will be great compared to the 75-300.  Not arguing that point at all.  Just wanted the OP to be aware that there are some limitations for sports with the RP body
G Rash Senior Member • Posts: 2,890
I think the RF 100-400 is a very good compromise of size, weight, cost and image quality.  I use it for kids soccer and it works well on the R6.  It won't match an L lens, but if "good" is good enough, then it's a bargain.  For the reach, it is actually very small.  I use it on the R6 with just a hand strap and it doesn't get uncomfortable over the course of a couple of hours.  I've never walked around with it all day, but I don't think it would be a problem.
Gary
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
JustUs7 Senior Member • Posts: 4,327
I just picked up the 100-400 and plan to use it for my son’s soccer games. But not indoor sports.  The USM focusing motor is blazing fast and almost silent.  For a zoom telephoto at that price it’s pretty incredible and the stabilization is great even without IBIS on the RP.
Shooting sports with the RP isn’t a matter of frame rate and tracking.  What I do is use zone tracking. I place the zone in the frame where I want my subject. Then I keep that zone over my subject.  I use H instead of H+ for better tracking but slower frame rate.  I get a decent hit rate that way.  I also go into the menus and set up my AF for stickier tracking and better EVF refresh rate instead of battery conservation.  Check the manual on that.
Indoors for court sports I’ve been using the RF 85mm f/2.  It’s STM, but a lot brighter than the zooms.  I just shoot when the action is close enough.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
Thanks! That's very helpful!
MarshallG
Worst case, you pay $700 with tax, use it a few seasons, sell it for $500 or $550 and upgrade. Not much of a risk.
I have used the 24-240 for XC and been very happy. As noted, is it the EF 100-400L? No, but good results overall.  The RF 100-400 is basically in the same class as far as AF and NanoUSM focus motor
Skookum New Member • Posts: 1
Same exact setup (R6 with strap) and use case (kids soccer).  The handling on this RF100-400 lens is just wonderful...shockingly light, and the zoom range covers really quickly, so it's easy to keep things in frame even during an oncoming fast break without re-gripping the zoom ring.  I was worried about the depth of field vs my 70-200L, but its so thin at 400mm that faces still pop really nicely despite the f8 aperture.  Autofocus is as good as my L and the stabilization is excellent.
My kids' games are typically a little after noon so I generally have plenty (if not too much) light to work with.  The R6 seems to handle high iso situations well regardless.
There's probably better options for golden hour or indoor sports, but if your use case scenario is similar to mine, I'd say the RF100-400 is a no-brainer.  I've rented the RF150-500 and although it's an awesome lens, I'm keeping that money saved until I see if Canon does an R7 or if Tamron/Sigma makes an RF version of their 150-600.  Even a new version of the 300 f4 would get my attention if it's on their road map.  The one I have is at least 15 years old, and just doesn't quite keep up with the frame rates of the R6, although it curiously works pretty well on an adapted M6ii (fun setup for getting a younger kid into sports photography FWIW).
John Sheehy Forum Pro • Posts: 26,688
This slower lens will struggle more than a faster one in very low light, where the actual light available makes it hard for the AF system to see in real time, but in very bright light where the bottleneck is motor and communication speed, it may easily surpass faster EF lenses.
Also, keep in mind that a smaller aperture is sometimes helpful for focus, since the deeper DOF means that when you first point a lens at the next subject, it is more likely to be focused enough for the AF system to immediately recognize objects like faces and eyes, and work on focusing on them. I have this zoom, and I have the R5 and EF lenses of 400/4, 400/5.6, and 400/6.3, and unless the light is low enough to need the faster EF lenses, the RF100-400 generally gives less focus problems. If you start adding TCs, then the AF may start to favor the faster EF lenses when ambient light flux on the sensor gets very low and becomes the main AF speed bottleneck. The RF100-400/5.6-8 can take the RF 2x, but the AF speed drops a lot more than it does making the 400/4 into 800/8, even with moderate light sometimes.
Of course, the body plays a large role in AF ability, too.
You might want to consider how much background blur/separation you want, because despite any AF ability, a smaller aperture dictates a deeper DOF. Blurring the background more requires either getting closer to the subject, or using a larger aperture or pupil (actual size; not necessarily the f-ratio per se).
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
It may be BETTER on the RP without the IBIS, for most shooting of distant things at significant shutter speeds. The IBIS on the R5 is great if you are using an OIS and are also very close to the subject (X/Y translation) or the shutter speed is so slow that the camera can "roll" a little during the exposure, but these 3 axes really need no correction when shooting at a distance and the camera is operated from a stable base (shooting from a moving vehicle or vibrating platform may mostly benefit from X/Y correction, even for distant subjects). The fact of the matter is, added IBIS is NOTHING like adding more rocks to a bag hanging from a tripod. Added IBIS does not "dampen vibration more"; it REPRODUCES it in the opposite direction to cancel it out in each axis, with a very slight lag and an imperfect path, so it always ADDs some blur, even if it is mostly reducing blur. If there is nothing for it to reduce in a given axis, it may actually only ADD blur in that axis. I think that Canon is screwing R5 and R6 users over by not allowing OIS while IBIS is disabled.
John
