Sigma 56 F1.4 on M6II versus RF 85 F2 on R
Feb 23, 2022
9
In another thread there has been some discussion recently of how the Sigma 56 on the M6II compares with the Canon RF 85 F2 on the R (or other R camera). This might be of interest to those deciding whether to go the M or R route, because both lenses are good, sharp, moderately priced (not dirt cheap, but not silly expensive either) primes that are well suited to traditional portrait shooting. Luckily for me, I don't have to decide which route to go, because I have both systems (an R and an M6II and two other M bodies), with several primes of roughly equivalent FOV for each system (22, 32, and 56 on M, and 35, 50, and 85 on R). A bit over a year ago, I did a comparison of several primes on the M6II and R, shooting the same subject from the same distance in the same lighting (within a few minutes), all at base ISO. This was the thread in which I compared the 22 and 56 on M6II with the 35 and 85 on R:
https://www.dpreview.com/forums/post/64718104
And this is the one in which I compared the 32 on M6II with the 50 F1.8 on R:
https://www.dpreview.com/forums/post/64746137
I thought it would be interesting to go back and reprocess some of the shots with DXO PL5, to see whether that makes a difference. I only did it for the 56 v. 85 comparison, because I have limited time, and that was the specific comparison that came up in the other thread. I processed in both PL5 and LR, both a web-sized version (2000 pixels on long side) and a 100% crop of the subject (Paddington Bear). I only did wide open shots (F1.4 on the 56, F2 on the 85), and did both a corner/edge shot and a center shot for each. Here are the results, first with Paddington in the center:
Sigma 56 F1.4,Lightroom
Sigma 56 F1.4, DXO PL5
And 100% crops:
Sigma 56 F1.4, Lightroom
Sigma 56, DXO PL5
Canon RF 85 F2, Lightroom
Canon RF 85 F2, DXO PL5
and 100% crops:
And now the shots with Paddington in the upper left:
And 100% crops:
Canon RF F2, Lightroom
And 100% crops:
After peering at the results for several minutes, here are my preliminary observations: (i) both the Sigma 56 on the M6II and the Canon 85 on the R give excellent results. I'm sure different people will find different differences between them, but let's be honest, if you can't take a good shot with either of these combinations, it's on you, not the gear. Does one combination have better sharpness and/or bokeh than the other? Darned if I know. My choice between them is based on which combination I feel like using on the day, and has more to do with size, weight, ergonomics, etc. than with any possible differences in the output. (ii) the difference between Lightroom and DXO PL5 is much less apparent at base ISO than at higher ISOs, where DXO clearly does a better job at controlling noise and preserving details. At least that's seems true for these two lenses. Perhaps the difference in lens corrections would be more apparent for different lenses. I think the DXO versions here have a bit more detail, but nothing like the striking difference you see at high ISO.
Edit: After going back and looking closely, I can definitely see more detail in the DXO versions. But the bokeh isn't as nice in them. That's probably because the settings are different. It's really hard to get similar settings between Lightroom and PL5, because some of the adjustments don't exactly correspond to each other.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
