LO res. sd1m files very sharp
Started Feb 23, 2022 | Discussions
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Re: LO res. sd1m files very sharp
As soon as I opened this I thought "Hmm...looks very "SD9-ish".  What do you attribute it  to?
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Tom Schum wrote:
Another Merrill Lo-res image, developed from lo-res raw.
Merrill lo-res is great, and quite like I've seen from the SD9.
Wow. I decomposed this image and extracted the finest detail level (1px) to be greeted by the best DOF I've seen (absolutely everything in focus) and just look at the color definition!!!
DP3M roolz, OK.
It's all in the numbers ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
ole kekkonen
OP ole kekkonen Contributing Member • Posts: 607
nervermind
jande9 wrote:
ole kekkonen wrote:
how do you handle this?
please show examples or I can find answers on google myself
thanks in advance
Hi Ole,
What exactly is your question?
Jan
dont bother I did find a solution on the problem
xpatUSA
Re: nervermind
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
Good. What exactly was the problem?
I ask because the thread says "files very sharp" but most of the above image is soft on my computer.
ole kekkonen
Re: nervermind
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
I could easily post a picture that was more sharp but whats the point?
ole kekkonen
Re: nervermind
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
xpatUSA
Re: nervermind
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
There is a big misunderstanding by some of us, judging by the responses. You started a thread that said in the title "files very sharp" and posted a mostly soft image as an example.
Is your only problem exactly "LO res. sd1m files very sharp" and no more?
ole kekkonen
Re: nervermind
xpatUSA wrote:
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
what did you expect? its the internet, the age of egocentric!
xpatUSA
Re: nervermind
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
OK, you refuse to answer the question but at least you did post another image:
Yes, the image is "very sharp" but it is not over-sharp.
The edge response has no overshoot (no halos).
An MTF50 of 0.360 c/p is excellent but the response at more than Nyquist means that there will aliasing visible BUT only for repetitive scene items in excess of 25 lp/mm.
Your camera/lens is excellent. I envy you!
xpatUSA
Re: nervermind
xpatUSA wrote:
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
Our discussion would have been better if you had not got defensive by answering questions with questions.
ole kekkonen
Re: nervermind
xpatUSA wrote:
xpatUSA wrote:
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
thanks,at least you where friendly at took a look at it
jrtrent Veteran Member • Posts: 6,495
Your title says that at LO resolution, the files are very sharp.  I would handle this by using the LO resolution setting.
I don't have examples to show, but I found a related advantage to using either medium or low resolution raw files with my SD14; at higher ISO settings, the images were cleaner, less noise or blotching.
tohereknowswhen Regular Member • Posts: 483
Re: nervermind
ole kekkonen wrote:
ole kekkonen wrote:
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Hi Ole,
Jan
Looks super! Have to try low res on my DP2m. I really like low res on my dp3 quattro.
rick decker
Here is a low/hi comparison
Hand-held at 320 (low res); 250 (hi res) and braced against wall. Low es shot appears richer and more detail and  more contrast.
hi res
hi res downsized and some contrat added
low res
