LO res. sd1m files very sharp
Started Feb 23, 2022 | Discussions
ole kekkonen
ole kekkonen Contributing Member • Posts: 607
how do you handle this?
please show examples or I can find answers on google myself
thanks in advance
Sigma SD1 Merrill
D Cox Forum Pro • Posts: 32,979
Re: LO res. sd1m files very sharp
It isn't clear what your problem is.
Not enough depth of field ?
Don
Sigma fp
ole kekkonen
OP ole kekkonen Contributing Member • Posts: 607
Don
another useful answer from Don.......not
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
thanks in advance
I used to shoot my SD1 Merrills in low res all the time.
Low res gives you 10um pixels, slightly bigger than even than the SD9's 9.12um at high res.
On a per-pixel basis larger pixels give a higher MTF at Nyquist (0.5 cycles per pixel) but visible false detail above Nyquist. At 10um, Nyquist is 50 lp/mm quite within the capabilities of a good lens.
Most of your image is not sharp which is why Don asked his question, so what did you mean by "this"?
It's all in the numbers ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
ole kekkonen
thanks in advance
Ted? English please?
and I dont have a LENS PROBLEM.
quma
quma Forum Member • Posts: 67
I see absolutely no advantage in using low res with the SD1 unless you are in no man's land, your card is running full and you need to get those shots.
Low res doesn't even perform better at high ISO settings, rather the opposite.
If 4-5 MP were enough for me, I would probably still use a DP1s, DP2s or SD15.
 quma's gear list:quma's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Canon EOS R +9 more
xpatUSA
ole kekkonen wrote:
thanks in advance
Never said you did.
ole kekkonen
xpatUSA wrote:
ole kekkonen wrote:
thanks in advance
Never said you did.
yes thats my meaning and its bugs me and I never said you said I did say that
larryj Forum Pro • Posts: 13,086
HI Ole:  here are a couple of cow elk images that I inadvertently shot my SD1 Merrill on low Rez.  I rather like the detail in the fur and the over all look of the images, sort of like SD9 on steroids!
Enjoy!
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
ole kekkonen
Enjoy!
looks great Larry,makes my wanna try harder
xpatUSA
withdrawn n/t
xpatUSA
Low res gives less noise. Therefore, it's ISO "performance" is better.
quma
In theory, but not with the SD1 and Sigma Photo Pro.
Two shots, same settings, the high res photo has been downscaled to match the low res.
Both are unusable as color photos, but the low res is worse, even as a black and white image.
HIGH RES, downscaled to LOW RES, all settings zero, noise reduction off
xpatUSA
Re: LO res. [SD1 Merrill] files very sharp
I was talking about temporal noise, not Foveon green/magenta blotching.
In any case, for temporal noise comparison it is not valid to re-sample one image to match another.
quma
Read again what I wrote:
quma wrote:
I see absolutely no advantage in using low res with the SD1 [...]
What I demonstrated.
xpatUSA
OK, understood. One image unchanged, one image re-sampled to 50% - the unchanged image not looking "better" than the re-sampled image.
quma
The low res image does also have a strong green color cast and some weird artifacts (beyond the color blotching)
Either the pixel binning is faulty or SPP isn't handling those low res files properly.
xpatUSA
withdrawn n/t
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Another Merrill Lo-res image, developed from lo-res raw.
Merrill lo-res is great, and quite like I've seen from the SD9.
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
jande9
jande9 Senior Member • Posts: 1,707
thanks in advance
Hi Ole,
What exactly is your question?
Jan
 jande9's gear list:jande9's gear list
Canon PowerShot A650 IS Sigma DP1s Sigma DP2 Merrill Panasonic FZ1000 Sony Alpha NEX-7 +4 more
