need help with t2i and close up pictures
Started Feb 22, 2022 | Discussions
gromit95 New Member • Posts: 10
i work in a quality lab and need to take picture defectives product.
i have a stock T2i with a 18-55 lens. I'm getting good pictures but a lot of times I'm waiting on camera to focus.
i used to have a canon G12 and it did much better unfortunately  i broke it.
what advice can you give me? should i get a led light , manual focus? different lens?
thanks fred
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4) Canon PowerShot G12
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Re: need help with t2i and close up pictures
Hello...
I think IMHO - buy the Nifty Canon 50 MM lens.
thanks fred
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
stevet1 Senior Member • Posts: 1,300
thanks fred
Fred,
Here's a web site that offers tips and tricks to get close-up shots with your T2i
https://www.cameratips.com/t2i/take-great-macro-photos-canon-t2i
As Sue Anne suggested, and as the article mentioned, a 50mm STM lens would not be a bad idea.
They run about $150.00
Narrowing your aperture might help some too.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
guinness2
guinness2 Veteran Member • Posts: 4,617
Hi,
your samples have various problems. For example #1 has too shallow depth of field, smaller aperture could help.
As to focusing: try to setup the central focusing point.
Move the subject closer to the window. Cost effective pro solution for your bussiness is two lamps setup. Anything else, except of a circular macro flash will make unlikely shadows.
The 50/1.8 lens gives you more speed, as it has bigger max aperture, on the other side you loose unlikely much of the depth of field, when full open.
Additionally, it is not wide enough for your usage. It is no way to go, IMHO.
All in all, your lens is fine, bring more light and use f/8.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
OP gromit95 New Member • Posts: 10
Sounds good
I will give it a try
thanks fred
Dunlin Senior Member • Posts: 2,611
How about the EF-S 24mm f/2.8 STM?
Twice as wide angle-of-view as the 50mm.
Sells for £150 new in the uk. Cheaper used, obviously.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
I desided.   to get more light first.
any recommendations on a led light?
thanks fred
