Oly v Panny straps
Started Feb 22, 2022 | Discussions
alcelc
alcelc Forum Pro • Posts: 19,003
Re: Me neither
Metal on metal, with time it could grind the contacts and damage either/both end. Obviously the camera strap eyelet could be the weaker link.
And a metal surface might also scratch the camera body easier on daily uses.
If I must use it I would wrap a piece of plastic surround the hook to reduce the grinding, also could reduce potential scratching to the body.
As a matter of fact, besides the PD similar design quick release connectors, I use plastic carabinar (which are rated for 2Kg, good enough for my gear) having a short link made from 550 paracord. This can make sure minimal damage to the strap eyelet.
My 2 cents.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
Peak Design Leash Re: Oly v Panny straps
I only have Panasonic bodies: GM1 to G9. The original straps are OK, albeit broader than they need to be and of fixed length. The PD Leash is light, flexible and easily adjustable. I did buy one of the heavier and wider PD straps, thinking it would be better for G9+100-400mm, but found it too stiff and difficult to adjust, probably better suited to a traditional FF SLR with big lens. Any hoo - the leash is much easier to use and wraps around the lens barrel for easy stowage. Also, using the clip buttons, the strap can be quickly detached and swapped for a wrist strap. I use on G9/G80/GX80.
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
I never use the strap that comes with the camera.
I use a Peak Design neckstrap or wrist strap or nothing at all.
Cheers
Eric
(Feel free to edit and repost in DPR any image that I have posted)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: I make my own
cba_melbourne wrote:
Allan Brown wrote:
DIY strap on EM5II
I make similar straps myself. Not for cameras though. I have good success in preventing them from fraying over time, by lightly melting the cut area with a lighter flame. And after sewing, put a chunk of heat shrink tubing (as used for electrical cables) over the sewn area to hide my stitching skills. You have to thread the strap through the heat shrink tubes before the last stitch of course. If you use the type of heat shrink tubing that is coated with glue on the inside, it is extremely durable. And looks good too.
I sometimes use that technique as well. However, rayon is made from natural sources of regenerated cellulose and does not melt. So, the lighter trick does not work. I could use heatshrink but I have not bothered.
https://en.wikipedia.org/wiki/Rayon
Allan
Allan Brown
Re: I make my own
Michael Meissner wrote:
While your straps look good, particularly since you are sewing them together, instead of just gluing them, personally I tend to prefer wider straps for heavier camera bodies/lenses. For lighter bodies, I prefer much thinner straps like you use.
One firm requirement that I have is any strap I use must be easy to remove and put back on. If I'm doing tripod work, I prefer to remove the strap entirely. When I get bored with a strap, I want to replace it.
My straps are removable as they are attached to the ring and not directly to the camera. They are a bit of a bother to put back on as you have to figure out which way to rotate the ring before attaching. Get it wrong and the strap will be twisted.
Allan
jalywol
jalywol Forum Pro • Posts: 12,301
I never use the camera company straps.  I use either generic wrist straps or a little sling strap from Op-tech, depending on the weight of the camera/lens combo I am using at the moment.
-J
Bassam Guy Veteran Member • Posts: 4,885
That's good too
My 2 cents.
I have clips like those above but without the turnbuckle. The metal ones mayhave tarnished my 5.2 a bit but IDC. No effect whatsoever on the plastic 5.3
Either way, a far more economical solution than Peak Design.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Searching Veteran Member • Posts: 3,964
Olympus has an excellent leather strap which you can buy.  It has the word Olympus stamped on it but it is not very visible.  The strap is pebble like leather on the outside and kind of suede on the inside.  It fold very easily too.
 Searching's gear list:Searching's gear list
Olympus E-M1 II Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +4 more
Re: Me neither
Bassam Guy wrote:
Fast, easy, cheap
The clips don't look very reliable, seem a bit large, and will likely scratch the body in the lug area.  I don't think it's a good set up.  Cheap, yes.
one blind eye
one blind eye Contributing Member • Posts: 806
Re: Me neither
Bassam Guy wrote:
Fast, easy, cheap
No to metal turnbuckles.   👎.    They scratch.
I see life through monocular vision.
 one blind eye's gear list:one blind eye's gear list
Sony RX100 Sony RX100 VII Panasonic Lumix DMC-GX7 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +5 more
jonbev
jonbev Veteran Member • Posts: 4,077
Re: As do I
Amazing that such a simple question can garner so many methods of holding a camera.
 jonbev's gear list:jonbev's gear list
Panasonic Lumix DMC-ZS7 Panasonic Lumix DMC-G10
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: As do I
We all do what is best for each of us alone.
In my case a small shoulder bag, strap cross body for M4/3 gear and the camera spends most time in the bag, only removed when I need to take a photo. So the wrist strap idea works for me.
As for other tourists, I see way too many with large cameras with largish lens (always with lens hood reversed, even when shooting) slung casually over one shoulder with the camera and lens pointing behind them when not being used. Ideal way to lose the camera due to snatch and run or to bump and bash into street furniture.
Aeons ago I started out with neck straps but too many times the camera swings wildly so wrist strap and living mostly in the bag proved the best for me.
At home in its bag....
