Oly v Panny straps
Started Feb 22, 2022 | Discussions
one blind eye
one blind eye Contributing Member • Posts: 806
Re: I make my own
Allan Brown wrote:
For the past several years, I have made my own straps with Rayon.
The stuff I use is very soft but very strong and can easily hold my camera and largest lens. Although it is thin, it does not dig in and is very comfortable. I make shoulder straps and not neck straps.
Each strap costs less than $2 to make.
Allan
EP5 with DIY Rayon Strap
Looking closer how the strap is attached. The attachment of the strap to your camera lug looks a bit untidy.  What is that large mass at the end that is attached to the camera ring?  Is the strap secure?  Glue/cement🤔
Regards.
I see life through monocular vision.
 one blind eye's gear list:one blind eye's gear list
Sony RX100 Sony RX100 VII Panasonic Lumix DMC-GX7 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +5 more
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: I make my own
Allan
Regards.
The strap is fed through the lug then sewn in place. They are normally quite neat in appearance.
What you see here is the end of an older strap that frayed with use. I applied Fray-Check to stop it. It looks a little untidy but is still as strong as the day I made it.
Allan
one blind eye
Re: I make my own
Allan
Regards.
Allan
Thanks for explaining. Cost of  $2  per strap  can’t be beat 👍
Allan Brown
Re: I make my own
Allan
Regards.
Allan
Here is a newer strap on my EM5II. Also visible is a thinner safety strap in case the lugs fall off. I had to return the camera to Olympus because both lugs became loose.
Allan
DIY strap on EM5II
cc99 Contributing Member • Posts: 565
Re: Oly v Panny straps
Adrian Harris wrote:
But how do others 'who use shoulder straps' feel about this difference between the Panasonic and Olympus straps and which do you prefer?
I found that every Olympus strap I have is far too short for my taste.  I occasionally use the ONA Presidio [ONA ] as a cross-strap (for heavy lenses), and the PD Leash [Peak Design ] as a neck-strap (for lighter ones).
But I typically use a PD Clutch [Peak Design ] with my RRS plates [Really Right Stuff ], so I don't need a neck-strap if I bring my camera bag.  A neck-strap is lighter than a bag, but a bag can hold more than one thing, and grip-straps are much faster in and out of the bag.
 cc99's gear list:cc99's gear list
Olympus E-PL7 Olympus PEN-F Olympus E-M1 II Olympus E-M1 III OM-1 +28 more
TomFid Veteran Member • Posts: 3,999
I have essentially the same reaction. I hate the stiff, porky Oly straps, and I like the minimalist but grippy Panny strap. My O bodies wear P straps, but I sold a couple P bodies with O straps (apologies to the buyers), so the net marketing effect may be neutral.
This is one of those minor annoyances where Oly could improve their game for probably zero cost.
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
Re: I make my own
Allan Brown wrote:
DIY strap on EM5II
I make similar straps myself. Not for cameras though. I have good success in preventing them from fraying over time, by lightly melting the cut area with a lighter flame. And after sewing, put a chunk of heat shrink tubing (as used for electrical cables) over the sewn area to hide my stitching skills. You have to thread the strap through the heat shrink tubes before the last stitch of course. If you use the type of heat shrink tubing that is coated with glue on the inside, it is extremely durable. And looks good too.
Here an example of a commercial dog leash done with heat shrink tubing. It works with flat straps too, not only with round paracord.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
gpb11 Veteran Member • Posts: 5,035
I think the only Olympus strap I used was 20+ years ago with my C2000z
Past few years I use Joby Convertible straps.
Images are about emotion. Technical perfection is nice, but does not stand by itself.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: I make my own - ditto.
Also home made, but in my case always a wrist strap. Temporarily pinned while I get the right length for my hand, then machine sewn.
My E-P5 pair. Mode dial tops now changed to simpler design.
Unused left hand eyelet thingy removed to stop rattling.
john isaacs Veteran Member • Posts: 8,442
I have never used the camera mfg straps.  I use Black Rapid straps with Arca clamps and custom base plates on all of my cameras, and I remove the strap when putting the camera in the bag.
This approach was confirmed due to the consistent failure of E-M1 strap lugs.
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
Re: I make my own
While your straps look good, particularly since you are sewing them together, instead of just  gluing them, personally I tend to prefer wider straps for heavier camera bodies/lenses.  For lighter bodies, I prefer much thinner straps like you use.
One firm requirement that I have is any strap I use must be easy to remove and put back on.  If I'm doing tripod work, I prefer to remove the strap entirely.  When I get bored with a strap, I want to replace it.  Typically, I will use the Peak Designs anchors (or earrings that I heard people call them).  If the strap isn't a Peak Designs, I will attach the clip to the Peak Designs anchor loop.
But we all have different preferences.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
alcelc
alcelc Forum Pro • Posts: 19,003
Never used OEM straps
I have my trusty OP/TECH weight reduction strap, which is >20 years old, for my main camera.
I also have many other camera straps in various type and size (sling, neck, waist etc) for various uses. Some are DIY from various materials including Paracord.
I have piled up a lot of OEM straps free with every new camera. Never use them and I would trashed them soon.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
Bassam Guy Veteran Member • Posts: 4,885
Me neither
Fast, easy, cheap
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
Re: I make my own
Allan
I like it. Thank you. I think I'll take that route.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Adrian Harris
Bluephotons wrote:
I'm just curious to know, from those who hate logos, does it extend to your cars, refrigerators, etc , or just to cameras?
Yes. All of the above. You? 🤔
I tape over the red dot logo on my Leica cameras.
I debadged my Mustang Shelby 500 GT to make it look like a lowly Mustang 4 popper.
Why? Because they are high value targets for scumbag thieves.
Exactly. The small bag I put my camera in doesn't look like a camera bag. It looks worth £1 and that's when new. But it's scuffed and worn out and tatty.  looks like there would be nothing if value inside. One day I left it on the sidewalk after grabbing a coffee. A passer by found it beside the table later and handed it in to the cafe. I don't think anyone would dream there was £4,000 worth of camera and lens inside ... Thankfully. I went back later expecting the worst and the shop assistant handed it back. The way she held it looked like she didn't want to touch it
mchnz
mchnz Senior Member • Posts: 1,949
Re: If I was made of money...
If I was made of money I'd buy a Lucky strap with their quick release clips . They're not as clunky/clacky as Peak Design, but still quick-enough for my purposes.
I almost did press Checkout once. I couldn't bring myself to do it. If they ever introduce a narrower cotton option, I still might be game to buy.
I currently use a cheap Manfrotto strap which is a kind of olive-drab so I blend in a bit better in nature.
jonbev
jonbev Veteran Member • Posts: 4,077
I use comfortable straps that prevent my camera from falling to the ground.
 jonbev's gear list:jonbev's gear list
Panasonic Lumix DMC-ZS7 Panasonic Lumix DMC-G10
GodSpeaks
GodSpeaks Forum Pro • Posts: 14,713
As do I
Made from the shoulder strap supplied with the camera.
I have not used shoulder straps in over 20 years.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
- Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic FZ1000 Sony Alpha DSLR-A850 Nikon D800E Panasonic Lumix DMC-GX7 +52 more
Guy Parsons
Re: As do I
Back late last century into the first two of yearsof this century when using a Nikon SLR I had the habit of wrapping the attached neck strap around my arm and wrist a few times so it acted like a wrist strap. I found that nicer to use than a neck strap, so when digital came along I made everything into a wrist strap.
Yxa
Yxa Senior Member • Posts: 2,693
Oly v Panny straps
As I was worried when Olympus went to the wall I purchased a second Em1-mk2 body. Frankly I couldn't envisage enjoying my photography if I could no longer access the fantastic features that camera provides. Anyway....
Initially I used both. But for many months now keep using the same one, and this morning realised why!
My Panasonic cameras have a nice slim lightweight and more importantly flexible camera straps, whereas the Olympus straps are big and wide and frankly quite stiff - and of course have a big Olympus logo.
So shortly after I purchased my first em1-mk2 I removed the strap - which I hated, - and fitted the one from my no longer used Panasonic GX7.
Happy days.
The strap is far less conspicuous, soft and so easily folds into a tiny camera bag. Whereas my 2nd new backup camera with the Olympus strap doesn't fold well and also requires a larger bag or that I leave the diminutive 9-18 Oly lens behind.
I also find the - no doubt sturdier but inflexible - Olympus strap a nuisance when you take the camera off and place it on a table when stopping for a cream tea, etc.
So the upshot is, instead of wearing two cameras out gradually together, I always instinctively grab the older one everytime!
I have never been one advocating free company advertising on clothing and hate wearing 'Brands' anyway.
So now my Olympus. Cameras have straps advertising Panasonic
Peak design strap
