Panasonic GH6 Exiftool shows ---- 16 bit RAW?
Started Feb 22, 2022 | Discussions
Interceptor121 Veteran Member • Posts: 8,691
Bits Per Sample : 16
Linearity Limit Red : 65535
Linearity Limit Green : 65535
Linearity Limit Blue : 65535
High ISO Multiplier Red : 1
High ISO Multiplier Green : 1
High ISO Multiplier Blue : 1
Black Level Red : 2048
Black Level Green : 2048
Black Level Blue : 2048
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
drj3 Forum Pro • Posts: 12,632
Re: Panasonic GH6 Exiftool shows ---- 16 bit RAW?
7
ExifTools also show 16 bit RAW for the E-M1.3.  My guess is that it has something to do with the algorithm used to produce the files.  OMD workshop Tiff images are also exported as 16 bit Tiff files.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
(unknown member) Forum Pro • Posts: 47,805
Could be a bug. Could be many other things. I don't think we have 16-bits at this tier of sensor. BUT, if their HDR mode they talked about is really that good and the tops increased significantly, maybe?
Or maybe simply shots the file is written using 16 bits but whether all 16 bits hold useful information it's another deal?
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - Apparently Selwyn Duke and not George Orwell
JakeJY Veteran Member • Posts: 5,442
The linearity limit field is more important. GH5S is 16383 which is 14-bit. 65535 suggests 16-bit.
DP Review says the Dynamic Range boost combines the data in 16-bit space in reference to the raw file.
"These two streams are combined, using the high gain data for the shadow regions and the low gain data for the highlights. The results are combined in a 16-bit space, so that the shadow regions aren't just crushed back into the low-precision tail-end of the Raw file."
https://www.dpreview.com/articles/1570070253/what-is-dual-gain-and-how-does-it-work/1
I suppose the same test can be done with multiple files to see if there is any "padding" going on like when Panasonic sometimes switches to 10-bit mode.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
OP Interceptor121 Veteran Member • Posts: 8,691
The size is larger than the S5 files that were 14 bits
i think this may be needed for the wide dynamic range functions
Panasonic rw2 structure is always the same so no reason to believe is an error
No bug is a 16 bit rw2 file. For normal shot it uses 14 of those 16 and for the dynamic range boost uses 16 bits. There is an explanation of dynamic range boost here on dpreview
The file size is larger than my S5 files that were 24 mp
Dpreview sample confirms
File size starts at 33 MB and goes to over 42 MB
So clearly depending on engaging the dynamic range boost and the scene some values are zero but having seen the file size bigger than the 24Mp S5 I would think the range is 14 to 16 bits
