Help! My Fuji 16mm f1.4 is really distorted
Started Feb 17, 2022 | Questions
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
Re: Help! My Fuji 16mm f1.4 is really distorted
Gary Martin wrote:
Someone correct me if I'm wrong, but I thought the exaggerated tilting of straight lines prevalent in wide angle lenses was called keystoning, whereas distortion is when straight lines are rendered as curved. As long as straight lines are kept straight (regardless of the angle), there's no actual distortion.
Perspective distortion is different than lens distortion. Keystoning is a term sometimes applied to converging lines. But the correct description is perspective distortion. That is lines in the image plane will remain parallel, while lines in a plane that is not parallel to the image plane will be compressed in separation behind the image plane and expanded in front.
https://fujilove.com/correcting-perspective-and-keystone-distortion-with-exposure-x4/
Most fully function S/W packages, C1, Adobe subscription have facilities to address this issue.  In DXO PL you will need to buy an add on package, Viewpoint.  In reality these S/W solutions will only address perspective distortion in one plane since the transform needed varies for planes intersections the lens axis at different distances from the camera.  For simple images - it works fine.  For more complex images it will be noticeable.  The appropriate way to correct for such distortion is a tilt/shift lens to control the actual image plane orientation.  The unfortunate thing is Fuji doesn't have any.
"The winds of heaven is that which blows between a horse's ears," Arabic Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Snoopy_1812 New Member • Posts: 23
I don’t think distortion disappears when holding a camera level. The lens always distorts, no matter how you hold it.
i am currently looking for a new camera and have to say I can easily spot the Fujis from a gallery. Not because of the “fantastic colors”, but because of the enormous distortions.
Erik Baumgartner Senior Member • Posts: 6,894
5
Nope.
Care to show an example?
If you're looking at OOC jpegs, any inherent distortion will have been corrected in-camera. Most RAW editors will automatically correct distortion as well. I see no distortion with any of my Fuji lenses other than natural perspective distortion.
The 16mm f/1.4 in particular is very well corrected optically, and shows very little distortion even without any electronic correction...
From Optical Limits
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Some examples. I see the distortions immediately, no need to zoom or align to the corner of the screen or something like that.
All 16-35 lens by the way. Will look for some examples of your lens
Absolutely unacceptable for me.
https://flic.kr/p/2nwHWhH
https://flic.kr/p/2nw8QfE
https://flic.kr/p/2nC2pP5
And the XF 16 1.4. Buildings on the left fall to the right, buildings on the right fall to the left
https://flic.kr/p/2ntW4eR
robert1955 Veteran Member • Posts: 7,302
The fourth one is clearly caused by tilting the lens up
Not sure what you see in the other ones
These are all examples of perspective distortion and are all the result of focal length/camera position, not a fault with the lens. If you see converging verticals tilt your lens down, diverging verticals, tilt your lens up. The wider the focal length, the more exaggerated this effect becomes and why extra attention must be paid to camera level (and height) when shooting with wide angle lenses - all of them, not just Fujis.
Buildings and trees that look like this:
I don’t know how much you want to keep a camera higher / lower / otherwise tilted, but if I see buildings and trees that look like this: ( ) then it is IN THE LENS and no matter how you move the camera, everything that gets in that spot gets the same distortion.
Especially picture 2 building goes like this )
buildings on picture 4 are COMPLETELY warped.
I don’t see any barrel distortion in any of your examples. If you are shooting something with a wider than normal focal length, the center is going to appear exaggerated and the corners more distant and stretched - again, perspective distortion. If you’re close to your subject and your camera isn’t level you will get both effects - a bloated center and converging verticals. Your examples show poor focal length/compositional choices (which may be forced due limited positioning options), not any fault with the lens.
tacogeoff
tacogeoff Regular Member • Posts: 347
great pics of winnipeg btw!
 tacogeoff's gear list:tacogeoff's gear list
Fujifilm X-S10 Fujifilm XF 56mm F1.2 R Fujifilm XF 33mm F1.4 R LM WR
RangerPhotog Regular Member • Posts: 303
Re: 3D Level
Erik Baumgartner wrote:
For those who aren’t aware…
The newer cameras have a custom assignable Electronic Level option that will get you level lines for both roll and pitch that are exceptionally useful for super wide angle lenses and shooting panos.
A
This is great information. While I am able to assign a button for this function, I can't find a menu item to perhaps put under MyMenu. What am I missing? Of course buttons are limited on my XE4 and I would hate to dedicate a button to it. Again, what am I missing? Any help would be appreciated.
 RangerPhotog's gear list:RangerPhotog's gear list
Nikon Coolpix A Fujifilm X100F Fujifilm X-Pro3 Fujifilm X-E4 XF 90mm +9 more
not his, four different photos from others that he thinks illustrate his point
Re: 3D Level
A
As far as I know, the fancy level (and the fancy RGB histogram) are only available through custom assignable buttons (and touchscreen swipes). This is one of the reasons why lots of people (me included) complain about Fuji continuing to add lots of interesting customizable options while removing the useful custom buttons, switches, and dials required  to access them.
tacogeoff
I didnt mean to hit reply to snoopy. I was replying in general to the OP
After reading your words and watching the photos over and over again, I have to say, you are right. And I was wrong. I was so convinced there was lens distortion going on.
