Problems with over exposure Nikon D100
Started Feb 15, 2022 | Discussions
Nerys New Member • Posts: 23
got a D100 trying to make it work right but I am getting an "odd" result
Pretty much no matter what I do it insists on shooting 2 to 8 second exposures. WTAF now I can hand hold a 2 sec exposure at times but as expected the pictures are white way way over exposed. at iso 1000 it should be shooting around 1/10th of a second
sure enough I switch it to shutter priority and set for 1/10th of a second and I get the shot I expected.
but I switch it back to P program auto mode and its wacked again insisting on taking multi second exposure. I hit the reset button figuring some settings might be out of wack. the camera did reset but it did not reset all settings (it still remembers I had set ISO to 1000 so it did not fully reset)
Suggestions? I thought it was lens but it does it with any lens I put on the camera.
in Program Auto mode (P) it just insists on using multi second exposures.
Nikon D100
arniebook
arniebook Senior Member • Posts: 2,454
Re: Problems with over exposure Nikon D100
Then just shoot shutter priority.
Have you tried shooting in full manual mode, or manual mode with auto ISO?
Program mode goes back to film days, when the ASA of the film was todays ISO.  Once selecting a film, photographers couldn't select a different ASA, so Program Mode was as "Auto" as a film camera could get.
Today we can select both aperture AND shutter speed in Manual Mode, and let the ISO "float" (Auto ISO).  In other words the camera selects the ISO incumbent upon amount of light and the aperture and shutter speed we have set.  It's very convenient way to shoot in varying light, and still have control of aperture and shutter.  We keep an eye on the ISO the camera is selecting, in case it gets too high in low light, or "bottoms out" in bright light.  If either occurs, then we adjust our shutter speed or aperture accordingly.  For example, my camera's lowest native ISO is 100, so, when shooting in daylight, if I see the camera select 100 ISO, I need to increase my shutter speed and/or select a smaller aperture to avoid overexposure.  It's simple really.
Afterthought ... The D100 was last produced in 2005, so it's old, and could be broken.
Cheers!
Arnie
What we spend on this stuff is equal to the depth of our pockets squared ($²) times what we (j)ustify in our minds as to what we expect to do with our pictures plus (+) the (e)njoyment we experience from using our stuff and sharing the result ... $xxxx=$²(j+e )
 arniebook's gear list:arniebook's gear list
Nikon AF Nikkor 50mm f/1.4D Nikon 200-500mm F5.6E ED VR Nikon D300 Nikon D500 Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +3 more
OP Nerys New Member • Posts: 23
I plan to sell a kit so need to either make it work right or just keep it for myself. ie can''t sell a "cludge fix" to someone else. that's not right
turns out it was exposure compensation. for some reason that does "NOT" reset when you reset the cam even when you write new firmware!!! that setting remains!
Once I put it back to neutral it works flawlessly.
arniebook
Great! ... Glad you were able to figure that out.
Arnie
