Re: RAF Camera customization
MacM545 wrote:
Are you able to print in metal?
In theory, yes; in practice, no. Metal printing isn't really a thing in the same sense plastic is. Basically, plastic parts often come of the bed ready to use, whereas metal parts need a LOT of postprocessing: burn-out of binder, sintering bake, bandsaw removal from build plate, CNC mill clean-up of build plate and part where it touched build plate, etc. Metal parts also change dimensions a lot during postprocessing, and you have to allow for that in your design.
I have printed with steel filament, but it's nasty stuff. Very abrasive on the nozzle. The material is about 30% nano steel particles, 70% plastic binder... which gives you some idea how much this stuff will have to shrink if you burn-out the binder after printing. Things are a tad better for laser sintering 3D printers, but there's still something like 30% binder in the metal powder. There's some hope for minimal postprocessing with welding-based metal printing, but that's not really an established tech yet.
I was looking for someone who might be able to make me a M39 to M52 macro coupler. I'm not entirely sure about plastic being strong enough. The weight of the lens going onto the end of the main lens is 260 grams. Thank you for any information!
I wouldn't be worried about 260g (nor even 500g). Well-designed and correctly printed plastics are surprisingly strong. For example, this bracelet can actually hold >30 pounds without having the tiny clasp fail. That said, 3D-printed adapters are more subject to wear and especially abuse. For example, leave a 3D-printed PLA adapter on your car's rear deck at 140F for a day and the odds are the adapter will have "wilted" a bit, deforming slightly and maybe even partly delaminating. After all, PLA is a thermoplastic monomer -- not a thermoset -- so it can be remelted multiple times, and is extrude-able goo by around 190C (around 370F).
The bad news for you is I don't make adapters as a business. You'll have to do it yourself or find somebody else. I make adapters mostly for my own needs and kindly post many designs as a public service. Every so often I consider making adapters as a side business... but I'm too well payed and too dedicated to my real job as a professor to make a side business worthwhile.
