Oly 12-100 f4, why so heavy?
Started Feb 14, 2022 | Discussions
Skeeterbytes Forum Pro • Posts: 23,186
Re: Oly 12-100 f4, why so heavy?
Diagrams are great!
Am also a sucker for "stuff cut in half" exercises. As long as it's not me.
Rick
Jon555 Veteran Member • Posts: 7,722
richmadeknives wrote:
I do agree that it’s a heavy and large lens (relative for the MFT family). However since I use it on my full sized E-M1X body it balances quite nicely. The weight and size are worth it because of the excellent one-lens range (24-200mm), dual IS, and excellent image quality. In my opinion it’s probably the best single lens in the entire MFT line-up across all manufacturers. It is definitely the lens I’d pick if I had to choose to be on a desert island with only one MFT lens. If OM would update the 40-150 f/2.8 to a newer version with built-in IS then I think that vII edition might steal the crown. But for now I’d rate the current 40-150 f/2.8 as the 2nd best lens, followed by the Panasonic 35-100 f/2.8.
I briefly considered the 40-150 earlier this month, but the edge sharpness at the wide end and the general sharpness reduction at the long end turned me off...
https://www.ephotozine.com/article/olympus-m-zuiko-digital-ed-40-150mm-f-2-8-pro-lens-review-26893
https://www.lenstip.com/479.4-Lens_review-Olympus_M.Zuiko_Digital_40-150_mm_f_2.8_ED_PRO_Image_resolution.html
70mm did seem a good compromise.
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
victorav Senior Member • Posts: 2,751
cba_melbourne wrote:
victorav wrote:
Woah this is very cool. Thanks for sharing. I suspect the combination of all glass elements and all the thick plastic parts contribute to the weight the most. I can see why they chose to use plastic internally. Then lens likey would have been much more bulky and heavy with an all metal build.
No, not necessarily. Other lens makers use thin walled metal inside, and plastic on the outside. Its less of a weight question than a cost question. Plastic is likely cheaper for mass production, intricately machined metal for smaller batches.
The reason the plastic sliding barrels on the 12-100 are so thick, is probably to support the weight of the front ED elements without flexing/sagging when fully extended to maintain alignment. This lens has considerable barrel extension, it is 158.5mm at its longest:
Yes that's a good point. I guess it's hard to say since of they went all metal, it likely require a different design.
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
Skeeterbytes wrote:
Diagrams are great!
Rick
It is very labor intensive. You can't just slide the lens through a butchers bandsaw. Each part is cut individually, carefully deburred, and reassembled to a high display quality standard. I once inquired for the cost from a company specialized in cut display models for teaching/universities, and was more than shocked.
Me personally, I am more inclined to buy a camera or lens if I can see how it is made inside (provided I like what I see). Most consumers would not bother though.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
You may be reading the zoom resolution backwards. It's sharpest zoomed long--center and edge--and that is very sharp, indeed.
Lenstip 40-150 Pro center
Should add I love this lens.
Rick
Photo magazines (remember those?) once did teardown articles for cameras (maybe lenses too, don't recall) and I found lots of useful information in those, because the choice of materials and design decisions revealed a lot about how robust they might be over the long haul, plus what a CLA might encompass and whether they could even be repaired, if broken.
Now the only folks I know of are Lens Rentals, but they can only manage a smattering of the many cameras available.
Pre-digital, I tended to keep cameras a loooong time between upgrades. It's just a thing to hold film and a lens, right?
Rick
PhotonBeam
PhotonBeam Contributing Member • Posts: 538
victorav wrote:
tammons wrote:
Oly 12-100 F4? Because of the range and it's build quality which is mostly all metal.
Olympus uses plastic internally, with a metal shell. Although it's unclear how much metal is used.
The Pany Leica 12-60mm F2.8-4 is nearly half the weight with less range with a lot of plastic.
To me, after owning a using a lot of MFT lenses over the years, Oly pro lenses especially are built like tanks with quality of construction the main concern and weight as a secondary concern, while Panasonic seems to be more interested in saving weight, although both provide excellent IQ.
This is the 12-100/4-IS cut in half. We can clearly see that it is constructed just like any other Olympus Pro lens. There is not more metal used, the interior is almost entierly plastic.
The weight is most likely due to the front elements made with very heavy Extra low Dispersion ED glass. There is a lot of thick plastic though, which could partly be to blame for weight too.
12-100 cut
Yellow = focus lens, blue = IS lens
The moving lens groups
The DSA lens = Dual Super Aspheric
The IS mechanism does not look overly heavy, but certainly contributes to weight too
This is a very impressive lens. If it was not so big and heavy, I would definitely want one.
Original pictures and interesting comments by Mr Daichi Murakami from the former optical system development department can be found here. The article is dated April 2017:
English translation: https://dc-watch-impress-co-jp.translate.goog/docs/news/interview/1053285.html?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en
Original Japanese: https://dc.watch.impress.co.jp/docs/news/interview/1053285.html
I hope OMDS will continue going to the considerable expense of cutting lenses in half for demonstration purposes like this
I suppose cutting it in half is one way to reduce weight.
 PhotonBeam's gear list:PhotonBeam's gear list
Olympus E-M5 II
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
Also plastic is far more temperature stable. Whereas metal will change its length with temperature and move the optical elements.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Adrian Harris
Atho wrote:
Adrian Harris wrote:
I shoot with both Panasonic and Olympus, love both and happily Intermix lenses and bodies.
For general walk around my single go-to lens is the Panasonic 14-140 MK2. It is a very good lens in that it is really light, covers a superb range and it quite sharp.
However it slightly falls short of my ideal requirements. Ideally I would prefer starting at 12mm, a slightly faster long end of the zoom, a constant aperture, and slightly better optics - as although the Panasonic 14-140 MK2 is good, it doesn't quite have the same micro contrast as the pro lenses.
I already have the Panasonic 12-35 & 35-100 f2.8 pro lenses, but do not want a 2 lens system for walk around.
Hence I thought the Olympus 12-100 f4 pro would be ideal
However on checking the weight and size of it against all my other lenses I was horrified
Using the ubiquitous digital kitchen scales and a ruler I was shocked to find that even the Olympus 75-300 was something like 20% lighter and smaller and the Panasonic 35-100 f2.8 was tiny and feather weight in comparison - and it's faster !!!
Why was it necessary for the Olympus 12-100 f4 to be so big and heavy?
I will say up front that it's size and weight has stopped me from even considering it as a walk around lens. Such a shame
... And is that why so many are available seconhand?
It is heavy but without compare. It is a 12-35 & a 35-100mm in a single body offering improved close focus and macro capability as well as 1.5-2 stops IBIS at 100mm.
Except of course the Panasonic's are f2.8 and have a much smaller filter diameter, which is also a bonus.
I carry mine mostly with the lens resting on my forearm.
Olympus has no history of making light, high quality, short telephoto lenses apart from the 1245 f4 and which perversely doesn’t appear popular!
The four-thirds Zuikos are plastic--the kit lenses, the high-grade lenses, the super-high grade lenses. I assume various metal bits are concealed beneath the humble plastic shells as required, but they're mostly plastic and glass. (Tripod feet are metal, as the lens gods demand.)
I assume the materials were selected during design for best possible performance. And they do perform.
Rick
Boss of Sony Senior Member • Posts: 2,425
5
For a walk-around lens, I highly recommend the Canon 800mm f5.6. It's particular useful for shooting the interior of churches, especially if you get an adapter and mount it on a Pentax Q.
 Boss of Sony's gear list:Boss of Sony's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 9mm F8 Fish-Eye Body Cap Lens
tammons Veteran Member • Posts: 8,142
12-100 cut
Nice!
Very complex.
That is a chunk of glass up front.
Cafe Racer Senior Member • Posts: 2,137
Yep, it's a beast!
 Cafe Racer's gear list:Cafe Racer's gear list
Olympus PEN E-P1 Olympus PEN E-P5 Panasonic G85 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II Olympus M.Zuiko Digital 45mm F1.8 +4 more
Messier Object Forum Pro • Posts: 12,724
Re: emojis
Yannis1976 wrote:
Haven’t seen such a clever response for quite some time
and I haven’t seen such ugly emojis for some time.
I wish DPR could block emoji use in post headers
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
cba_melbourne
I do not know what plastic is used in Oly lenses.
I do know that the plastic Oly cameras use PCGF10, and on one single occasion a PCGF20 stamping was noted on a part. That is Polycarbonate with an admix of 10 or 20% glass fibers in form of glass powder. I think it is very likely the same stuff is used for lenses.
Now, the thermal expansion coefficient of Polycarbonate (PC) is 65-70.
Glass fiber reinforced Polycatbonate with 10% (PCGF10) is around 45
Glass fiber reinforced Polycatbonate with 20% (PCGF20) is around 25
Glass is around 4 to 10
Aluminium is 21-24
Brass is 18-19
figures in 10-6 m/m DegreeC
the lower the figure, the less does the material expand or contract with temperature
So, it does not look there is much difference between common plastics and metals. Of course, one can always find better materials for more money... Titanium has a  thermal expansion coefficient of only 8.5 but is very expensive to machine.
Another problem is mould shrinkage. For PCGF10 that is about 0.4%. Whereas Aluminium parts can be machined to very tight tolerances, without having to allow for an average shrinkage of the finished part.
MOD Tom Caldwell Forum Pro • Posts: 46,355
UrbanHobbit wrote:
I also have wondered about this. My assumption is that it is due to the extra (large) glass needed to deliver the wide end. I look forward to better answers from those more knowledgeable in lens design.
There is actually not that much glass in there to explain the weight:
ED glass (blue) is heavy, but there is not that much of it by volume. Also, Oly pro lenses use only metal on the outside rings for good looks. Inside it's plastic. So why so large and heavy, I do not know. Maybe the IS system?
Why does it have to be only one thing? The best explanation is a combination of the metal shell, glass elements and electronics inside the lens.
Weight doesn't just magically appear.
Plus a serious size lump of lead to give it good weighting. None of this flim-flam plastic stuff that would blow away in alight breeze….
Frankly I have not noticed the weight. The lens IS is great and makes my GM5 into a stabilised camera when  mounted on one (which happens frequently).  Nice versatile combination.
Tom Caldwell
j tokarz Senior Member • Posts: 1,388
I also have a nikon Z24-200, full frame. And it feels lighter. (the nikon that is).
SterlingBjorndahl Senior Member • Posts: 2,642
It's the price we pay
I think the only lens in the family that can compare with it for solid performance across the whole zoom range is the old 4/3rds Pana-Leica 14-150 f/3.5-5.6, a "bag full of primes". It weighs about the same as the Oly 12-100, and has a 72mm filter ring. I think one has to put up with that much weight for that kind of quality; it's the laws of physics and the technology we have available nowadays.
If I'm doing a lot of hiking and climbing I leave the 4/3rds 14-150 at home and take the Panny MFT 14-140 - I can easily see the reduction in quality, especially the slight smearing in the corners at 14mm, but most of my audience can't tell the difference so I may as well save my neck. My main body is a GX85, so the 14-140 balances much better on it than the monster 4/3rds 14-150.
If I get the new OM-1 I may replace the 14-150 with the 12-100; the extra width would come in handy at times, and I don't really need the extra reach all that often for walkabout shooting. But I still shoot with some old 4/3 DSLR bodies once in a while for fun, so I'm not quite ready to make the switch yet.
Sterling
Lens Grit
 SterlingBjorndahl's gear list:SterlingBjorndahl's gear list
Olympus Air Panasonic Lumix DMC-GX85 Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix DMC-FZ50 +18 more
jpzundel Regular Member • Posts: 174
The Oly 12-100mm f4 is the only lens I use in walking around on trips :
- since 2017 on multiple trips: China, Greece, Israel, Italy, France, Germany, Switzerland...
- Tens of Thousands of Photos
Why:
- Generous wide angle of 12mm (24mm FF)
- Meaningful tele 100mm (200mm FF)
- Corner to corner sharpness
- All with no shake, though I have Parkinson
- Complete photo equipment with its hood, polarizing filter, an E-M1 III, 4 batteries, charger and cable, in one Lowepro Camera Box (20 x 9.5 x 16.5 cm)
Reading specs is useful, but using the lens tells you all.
 jpzundel's gear list:jpzundel's gear list
Sony RX100 Panasonic Lumix DMC-LF1 Olympus E-300 Olympus E-510 Olympus E-M1 +8 more
