Oly 12-100 f4, why so heavy?
Started Feb 14, 2022 | Discussions
Skeeterbytes Forum Pro • Posts: 23,186
Re: Different rendering:
Now that's science!
Whatever secret sauce is required to make an 8x zoom this good has its costs I guess, in complexity, price and weight. Also, constant-aperture zooms seem to routinely be heavier than their variable counterparts. OIS must add weight as well.
Had they made it internal zoom then it would be larger than the current lens collapsed, probably heavier yet.
Interestingly, it's slightly lighter than the four-thirds 12-60/2.8-4 SWD lens that was my to-to standard zoom for that system, and which I adapted to m4/3 before the 12-40 arrived, maybe why I don't think of the 12-100 as heavy now. It's not the best match for a Pen F; the 12-45 is perfect there. The 12-200 is lighter than the 12-100, perhaps verifying that constant-aperture and OIS have an affect on weight.
So many choices among standard zooms, you'd think everybody can find their "just right" lens.
Rick
ETA to refresh my memory, looked at filter sizes, closely related to the front element and while the 12-100's is 72mm the biggest competing standard m4/3 zooms are a far smaller 62mm. The heavier still 4/3 12-60 has a 72mm filter.
Atho
Atho Senior Member • Posts: 1,207
Re: Oly 12-100 f4, why so heavy?
Adrian Harris wrote:
I shoot with both Panasonic and Olympus, love both and happily Intermix lenses and bodies.
For general walk around my single go-to lens is the Panasonic 14-140 MK2. It is a very good lens in that it is really light, covers a superb range and it quite sharp.
However it slightly falls short of my ideal requirements. Ideally I would prefer starting at 12mm, a slightly faster long end of the zoom, a constant aperture, and slightly better optics - as although the Panasonic 14-140 MK2 is good, it doesn't quite have the same micro contrast as the pro lenses.
I already have the Panasonic 12-35 & 35-100 f2.8 pro lenses, but do not want a 2 lens system for walk around.
Hence I thought the Olympus 12-100 f4 pro would be ideal
However on checking the weight and size of it against all my other lenses I was horrified
Using the ubiquitous digital kitchen scales and a ruler I was shocked to find that even the Olympus 75-300 was something like 20% lighter and smaller and the Panasonic 35-100 f2.8 was tiny and feather weight in comparison - and it's faster !!!
Why was it necessary for the Olympus 12-100 f4 to be so big and heavy?
I will say up front that it's size and weight has stopped me from even considering it as a walk around lens. Such a shame
... And is that why so many are available seconhand?
It is heavy but without compare. It is a 12-35 & a 35-100mm in a single body offering improved close focus and macro capability as well as 1.5-2 stops IBIS at 100mm.
I carry mine mostly with the lens resting on my forearm.
Olympus has no history of making light, high quality, short telephoto lenses apart from the 1245 f4 and which perversely doesn’t appear popular!
siemecs Junior Member • Posts: 32
In my opinion additional weight is also a built-in stabilizer.
Anyway, the lens is brilliant.
 siemecs's gear list:siemecs's gear list
Sony Cyber-shot DSC-R1 Sony Cyber-shot DSC-RX10 Sony Cyber-shot DSC-HX99 Olympus E-M5 II Olympus E-M1 II +4 more
OSPhoto Regular Member • Posts: 278
Is it supposed to be lighter? I don't know about designing lenses, so I can't say, but similar lenses without the same level of weather sealing and construction:
Olympus 12-100 f/4 - 561g
Nikon 24-200 f/4-6.3 - 570g
Canon 24-240 f/4-6.3 - 747g
Now equivalence wise, they will put more light on their sensors, but I'm assuming the construction and sealing is also adding weight. I'm not sure this is heavy at all for what it is.
The 12-45 f/4 is 254g, so adding a 45-100 f/4 along with it is adding 307g, is that bad? I have no clue, the Panasonic 35-100 f/2.8 is 357g, so it could be.
 OSPhoto's gear list:OSPhoto's gear list
Olympus OM-D E-M10 II Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro +5 more
larsbc Forum Pro • Posts: 18,282
The size/weight is also an obstacle for me as well.  However, I'll also point out that the 12-100 replaces both the 12-35/2.8 and 35-100/2.8 in terms of focal length so one could argue that you should be comparing its weight to sum of the 12-35 and 35-100.
Jon555 Veteran Member • Posts: 7,722
I found the 12-35 and 35-100 f/2.8 combination annoying with subjects that wanted focal lengths varying between 25-50mm, as you're stuck with the wrong lens attached a lot of the time. My solution was to get the 12-60 Leica and then carry the 35-100 too if I might need to go longer. I considered the 12-100 but the weight and the f/4-always meant I gave up the long end for f/2.8 at the wide end, which you're more likely to want indoors.
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
AikenMooney Senior Member • Posts: 2,401
tammons wrote:
rich_cx139 wrote:
As people say: glass and metal. Compare it to the Sony 24-105/4 similar diameter at the heavy end and 17/14 lens els/ groups compared to 17/11 for the 12-100 pro. Ok obviously different flange/range but what counts is the diameter of the front ie f no and FL
Same goes comparing 100-400 in m43 with tam/sig SLR 100-400- similar ish weights ( ok the pan is a bit lighter ) but all are similar input pupil dias.
The Sony is 663g and the pro is 561g. I would guess that the pro has a better build quality - more metal maybe.
Lovely lens but I am also put off by the weight - tend to stick to cheap kit lenses for extra reach and just the 12-40 pro for walk around.
One of the main reasons I have the Oly 12-100mm F4 and I have had it for many years, is the IQ and range. For quite a while, I did not have a fast lens for bokeh, and just backed off and would use the 12-100mm F4 between 60-100mm at F4. The bokeh is superb. And it dual syncs with Oly bodies. It is one of the best lenses I have ever owned.
I agree it is a superb lens with great dual sync. I had an Oly E1 & loved the Oly glass. In 2006 they had not gotten their IBIS yet, so I switched to Nikon & VR. In 1918 due to weight restrictions on airlines as well as getting older I switched back to Oly. I do not think the M1 II or III is heavy with the 12-100. My wife even feels it's not too heavy after using Nikon for years, but she had rather use the 14-150. Yes, it seems heavy on the M1x but that is not my choice for a walk around camera & lens combo.
IF not too heavy for you use it, if too heavy use something else.
Plus, the Nikon and Canon would need to be constant aperture to give the same value.
Rick
Rick
That too, so yea, for what it is, seems like the weight is in line with where it should be.
eques Veteran Member • Posts: 4,115
Heavy, big, slow. Yes, but...
Heavy, big and slow - my first impressions after seeing the first reviews. And expensive for all that, so not a lens for me.
Then I looked for a standard zoom lens to replace my 14-45 with a bit more reach and which is faster at the long end.
I used the 2.8/12-40 which is sharp and faster, but I didn't like the results. Can't explain, why.
I tried the PL 12-60, also faster at the long end and more reach. I was impressed with its low weight, but my sample was very soft off centre at around 45mm.
I thought about trying another sample, but got the 12-100 instead. It felt heavy, big, slow, but at least it was 1 stop faster at the long end, the much longer end. And it hardly ever left my GX8 after mounting it the first time.
It is slow with f/4, but OIS is great, so even on the Panasonic body I get very sharp photos at 1/8s, sometimes even at 1/4s, which is enough for me.
It is a little soft near MFD, but otherwise excellent, even the bokeh is boringly smooth.
And yes, there is no getting away from the fact it is heavy, probably because of the large front lenses that make it reasonably sharp into the corners at all FLs and beause of a rather solid built. BQ of the 2.8/12-40 and 2.8/40-150 is probably better, but it is still very good in the 12-100.
I carry the GX8 with the 12-100 dangling from 3 fingers hooked lighty in the grip of the GX8, all secured by a wrist strap. And it is stowed away in a small bag, sometimes together with the 1.7/20mm.
However it is big, too big not to draw attention of everyone, This is my major draw back.
So if you can get one second hand at a good price, get it. It might be sold by people moving to the Nikon Z5 with 24-200 - something I have been considering for some time, too. This combination is FF but in size, weight and price(!) very comparable to a MFT body with 12-100. And the 24-200 is not bad either and faster, considering the 12-100 is a constant f/8 in terms of FF.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
Re: 😂 😂 😂
5
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Yannis1976
I have recently got a used copy of the 12-100 and yes it’s heavy and more cumbersome on my EM5.3 vs the 12-200. IQ is very good but not something that blew me away. However what impressed was the ibis with that lens which allowed me to get night shots at low iso!!
Also for walking around there is also another solution, much lighter and smaller with same focal range but even better CAF. RX100 VI…
richmadeknives
richmadeknives New Member • Posts: 2
I do agree that it’s a heavy and large lens (relative for the MFT family).  However since I use it on my full sized E-M1X body it balances quite nicely.  The weight and size are worth it because of the excellent one-lens range (24-200mm), dual IS, and excellent image quality.  In my opinion it’s probably the best single lens in the entire MFT line-up across all manufacturers.  It is definitely the lens I’d pick if I had to choose to be on a desert island with only one MFT lens.  If OM would update the 40-150 f/2.8 to a newer version with built-in IS then I think that vII edition might steal the crown.  But for now I’d rate the current 40-150 f/2.8 as the 2nd best lens, followed by the Panasonic 35-100 f/2.8.
Albert Valentino Veteran Member • Posts: 9,770
The 12-100 is a bit heavier than I would like but the IQ is everything I want - across the entire range, plus dual stabilization, close focus…. the 12-100 replaced my 40-150 Pro and 12 - 40 Pro, there is just no compromise in IQ. I have said that the 12-100 alone is a good reason to shoot Olympus 😃
we all know, or will come to learn, that all gear is some sort of a compromise, be it size, weight, IQ, cost or….
I’m in my 60’s and take it, and my 8-18, with me camping and on major mountain hikes… those really are the only two lenses I really need.
12-100 around my neck for a 10 mile, 10 hour mountain hike
Truth never fears scrutiny.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
The higher the spec and performance, the greater the size and weight... in general a rule of thumb with lenses.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
Trolleyman Senior Member • Posts: 1,048
Couldn't agree more, I have tne 8-18 too and those two lenses cover everything I need.
One caveat to that is the 12-45 I use for my city travels when I want to be less conspicuous
 Trolleyman's gear list:Trolleyman's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus 12-100mm F4.0 +3 more
Photodog2 Senior Member • Posts: 1,918
Brilliant! Made my day :). I hope you're the first post that has more than 100 likes.
 Photodog2's gear list:Photodog2's gear list
Pentax K10D Pentax K-5 IIs Nikon D600 Sony a6000 Sony a7 II +9 more
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
6
victorav wrote:
tammons wrote:
Oly 12-100 F4? Because of the range and it's build quality which is mostly all metal.
Olympus uses plastic internally, with a metal shell. Although it's unclear how much metal is used.
The Pany Leica 12-60mm F2.8-4 is nearly half the weight with less range with a lot of plastic.
To me, after owning a using a lot of MFT lenses over the years, Oly pro lenses especially are built like tanks with quality of construction the main concern and weight as a secondary concern, while Panasonic seems to be more interested in saving weight, although both provide excellent IQ.
This is the 12-100/4-IS cut in half. We can clearly see that it is constructed just like any other Olympus Pro lens. There is not more metal used, the interior is almost entierly plastic.
The weight is most likely due to the front elements made with very heavy Extra low Dispersion ED glass. There is a lot of thick plastic though, which could partly be to blame for weight too.
12-100 cut
Yellow = focus lens, blue = IS lens
The moving lens groups
The DSA lens = Dual Super Aspheric
The IS mechanism does not look overly heavy, but certainly contributes to weight too
This is a very impressive lens. If it was not so big and heavy, I would definitely want one.
Original pictures and interesting comments by Mr Daichi Murakami from the former optical system development department can be found here. The article is dated April 2017:
English translation: https://dc-watch-impress-co-jp.translate.goog/docs/news/interview/1053285.html?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en
Original Japanese: https://dc.watch.impress.co.jp/docs/news/interview/1053285.html
I hope OMDS will continue going to the considerable expense of cutting lenses in half for demonstration purposes like this
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
victorav Senior Member • Posts: 2,751
12-100 cut
Woah this is very cool. Thanks for sharing. I suspect the combination of all glass elements and all the thick plastic parts contribute to the weight the most. I can see why they chose to use plastic internally. Then lens likey would have been much more bulky and heavy with an all metal build.
cba_melbourne
No, not necessarily. Other lens makers use thin walled metal inside, and plastic on the outside. Its less of a weight question than a cost question. Plastic is likely cheaper for mass production, intricately machined metal for smaller batches.
The reason the plastic sliding barrels on the 12-100 are so thick, is probably to support the weight of the front ED elements without flexing/sagging when fully extended to maintain alignment. This lens has considerable barrel extension, it is 158.5mm at its longest:
