kenw
Had 4 - Lt. Landscp., Hvy. Landscp., Lt. Portrait, IR
I had actually over time evolved into four m43 "systems":
- "Heavy" landscape, primarily for twilight shots not too far from a vehicle. E-M5II, 8-18/2.8-4, 12-40/2.8, 35-100/2.8
- "Light" landscape, primarily for hikes, GM1, 12-32, 35-100/4-5.6
- "Light" portrait, primarily for family outings, GM1, 15/1.7, 42.5/1.7
- Infrared, 830nm E-M5II, 14-45, 45-175
The "light" systems are fairly obvious to understand. The "heavy" landscape could probably have used the 12-100/4 but I already had the other lenses before it was announced.
The main annoyance was that the infrared one couldn't be rationalized well. The higher quality visible lenses typically are abysmal performers in the IR so I ended up with two lens kits. Using external filters is a pain across many lenses so I ended up with two bodies rather than a single full spectrum body. I actually would have preferred an IR or full spectrum converted GM1 since really much of the opportunity for IR is on my midday hikes but the GM1 stinks for conversion because it has an IR LED to monitor the shutter so you can only use it in 10 bit rolling shutter mode if converted.
These days things have sorted out differently:
- "Heavy" landscape, Nikon Z7, 14-30/4S, 24-200/4-6.3
- Hiking & IR, full spectrum ZS100
- "Light" portrait, GM1, 15/1.7, 42.5/1.7
I've really enjoyed the Z setup for landscapes. The way I pack it takes up just about as much space as the m43 system it replaced - but of course if I were to more optimally pack the m43 system and switch to the 12-100/4 it would have come out a bit smaller still.
I love having both visible and IR along on my hikes now and in even a smaller package than before but a compact super zoom lens is a bit of a let down compared to the wonderful 12-32 and 35-100/4-5.6. Sensor is fine of course, that 20MP 1" sensor gives the m43 sensors a run for the money, but the lens can be frustrating at times.
The GM1, 15/1.7, 42.5/1.7 is of course one of those unique m43 kinds of kits nothing else can quite do so small. Unfortunately with two years of COVID we haven't had many family outings to use it on for awhile. But it is waiting there to be used!
What I'd really like is a GM1 follow on of some sort with a nice 20MP sensor with 12 bit electronic shutter (or no IR LED shutter monitor) that I could full spectrum convert to use with the 12-32 and 35-100 for day hikes. I think I'd make the trade for the slightly bigger kit to get away from some of the ZS100 frustrations.
Anyway, it was interesting that over time I ended up with so many nearly independent "kits" - the GM1 body was the only thing shared between two of them. The fact there was so little overlap in usage was one of the reasons I branched out both to bigger and smaller sensors as my different kits evolved. I wasn't really losing anything by moving outside the m43 system for those cases.
Ken W
See profile for equipment list
