Image Stabilized lenses - how many stops?
Started Feb 8, 2022 | Discussions
mobi1
mobi1 Contributing Member • Posts: 933
Typically how many stops an image stabilized lens can compensate in a camera with no IBIS?
For example, common kit lens 12-32 mm f3.5-5.6 which has OIS.
Conversely, does this lens at 14 mm with f3.6 behave similarly against Panasonic 14 mm f2.5 since the latter not having IS?
Panasonic Lumix G 14mm F2.5 II ASPH
BBbuilder467 Veteran Member • Posts: 7,057
Re: Image Stabilized lenses - how many stops?
With a 14-45, I average 2 to 3 stops slower than without IS, but I've always been able to hand-hold at 1/ actual focal length, even with adapted lenses in that range.
I don't see the gain at the wide end as much as the long end. I get about 1/8th second regardless of the focal length.
For some reason, I need 1/30th with the 9-18, but the camera defaults to that shutter speed, so I don't really notice the lack of IS. I need shutter speed to avoid motion blur more than IS for camera shake.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
This one a bit poorer than others, I have used it on my E-P5 and experimented with OIS only. It seems to deliver about 3 stops at 32mm and struggles to deliver 2 stops at 12mm.
Other lenses like the old Panasonic 14-45mm about 3 stops whatever the focal length and the same for the Panasonic 45-150mm.
So far haven't checked the Power OIS of the 35-100/2.8 but it "feels" like maybe 4 stops at a wild guess. It seems to handle slow shake better than the Mega OIS.
Can't answer that one.
Naturally I use the IBIS of my E-P5 as that always delivers about 4.5 stops and on good days for me I have reliably achieved 5.5 stops. I budget on 4 stops for a conservative reliability.
alcelc
alcelc Forum Pro • Posts: 19,003
What is your camera?
2 things to consider.
1) If you are shooting with a non DUAL IS/ non IBIS Panny body, you would only have interest to know the OIS effectiveness of 12~32.
Since under the IS policy of Panny, we can either use the best IS or nothing. i.e., No option to choose using which IS.
On a non IBIS/UUAL IS Panny body (e g. G7, GX1, GX850, GF10, G100), we shall use either OIS or no IS. For IBIS/DUAL IS Panny bodies, for the DUAL IS compatible 12~32, we shall use DUAL IS or no IS.
As per my home testing, 12~32 on GX85, a DUAL IS setup, I can expect around 4 stops of effective stabilization.
2) When I put on a larger lens for improved ergonomic/better balance, e.g. 12~35 f/2.8 or 45~150 on GX85, I could expect 5 stops of effective stabilization. This is also a DUAL IS setup. Hence, the setup, says a deeper front grip G85/G95 might give slightly more effective stabilization than on the flat front GX85. The tiny 12~32 vs a larger lens for similar effect.
I have not tested the effective stabilization of 12~32 on a non DUAL IS body. But had tested 14~45 on GX85 for a lens OIS only setup, it is around 3~3.5 stops @45. As 12~32 is smaller (less good on balance), but wider (IS will play a less role), and not sure what body you will use it, I guess 12~32 could be in similar effectiveness, or if worse will only marginally at most within 0.5~1 stop, as 14~45.
As per my home testing on sharpness of my lenses, my copy of 12-32 should be among the best in the pack on wide open (among 7~14 f/4, 12~35 f/2.8, 14~45 f/3.5~5.6, 14~42 f/3.5-5.6 mk-I, 14~42PZ f/3.5-5.6, 14~140 f/3.5-5.6, 15 f/1.7). 14 has to stop down to f/8 to match with the sharpness of the others.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
mobi1
OP mobi1 Contributing Member • Posts: 933
I use non IBIS cameras (GX800/G100) hence the question.
alcelc
So, the flat front GX850 or the G100 which has a bigger hand grip at the front?
Albert
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
I have the 12-32 and the 14mm f2.5
When I use each on an Olympus body and turn the IBIS OFF and only use OIS, I find that I can get about 3 stops advantage with the 12-32. So, the aperture advantage of the 14mm is mute.
I also had the 14-45. For stills, it was OK OIS wise but for video, I just could not hold it steady. Whereas, at the same time with my 12-32, I had no problems holding it steady.
I have shaky hands, so you may do better.
The 12-32 has a two-stage OIS whereas the 14-45 only has one.
I think that the newer Panasonic OIS lenses will work better than the older ones. This is a problem with the 45-200 MkI. The OIS is poor. However, mount this lens on a body with IBIS, and it works very well. I use this lens with my EM5II.
The Panasonic Leica lenses with OIS work very well and can rival Olympus's IBIS.
Allan
