OP
MiguelATF
Contributing Member
Re: In praise of the lowly Olympus 75-300mm
6
UrbanHobbit wrote:
This one is on my shortlist! I have seen many reviews here, as many positive as negative it seems. It seems like half the issues may be the challenge of shooting a long lens, in this case unstabilized and with less generous aperture to play with.
For my purposes a lens like this would be for daily urban birding, and I think that would give me plenty of opportunities to practice. My current daily carry is an adapted EF Tamron 18-400, which I find versatile and sharp for slow/static subjects when I have more than a moment to set up a shot. Adapted (Viltrox mainly), the Tamron does not acquire focus fast enough for sudden bird moments, and BIF tends to be about 100% spray-and-pray. The Tamron is not a huge lens, but adapted it is just barely jacket-pocket portable. (I can just barely cram it into the cargo pocket of a shooting jacket, which I suppose is an ironic adaptation of gear from another form of birding).
I tried the Olympus 12-200, but found it lacking in range and corner performance. That leaves the 40-150 Pro with a teleconverter, if I want to stay in-brand with my E-M1 IIs and take advantage of stuff like ProCap L. I’m not quite ready to commit to the 300 f/4, and anyway the 40-150 Pro is right at the line everyday carry for me. The impending 40-150 f/4 unfortunately won’t be taking teleconverters, apparently.
Thanks for posting your impressions and samples!
I mentioned in my original post that this is my 2nd 75-300mm. My first was also excellent, but I used it mainly on a GX9 body and it felt rather unbalanced and unwieldly. This time around, I am using it on an E-M1.1 body, and it feels like a different lens. AF (autofocus) feels quicker, and the lens feels better 'balanced' on the E-M1 body. I realize these are unscientific and subjective impressions, but there you have it. I suspect that faster shutter speeds may be one way of combating the difficulty of holding such a light lens completely steady when shooting at the 300mm end.
Incidentally I read all the positive and negative reviews first, before buying it, and a surprising number of people complained about 'softness' at the telephoto end. Maybe it's a copy to copy issue, with some random copies of the lens being softer and others sharper, but so far in my experience it's not 'soft' at all. My lens is v.II and most of the time it locks on focus quickly; but on other occasions it hunts or simply focuses on the wrong focal plane (a curse of many AF lenses in my admittedly prejudiced opinion).
My bottom line: the lens is a compromise (as many lenses are), it does a lot of things very well, others not so much. But (knock on wood) my copy is giving me results that are much better than I hoped for.
