NX10 and bracketing
Started Feb 6, 2022 | Discussions
Chuck Bagdade Regular Member • Posts: 229
NX10 and bracketing
Hello. I'm trying to set my NX10 to auto bracketing. I've set both areas, including +/- range, then click okay. But the camera only takes one shot. What am I missing?
Chuck
Samsung NX10
kypfer Contributing Member • Posts: 985
Re: NX10 and bracketing
What I've just tried on my NX5 :-
Press "Drive" button (top RH corner behind Green button)
Select "AEB"
Press "OK"
Press shutter
-: it worked … not sure what could go wrong
Don't forget to "unset" the drive mode when you're finished, unless you always want to take multiple exposures!
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP Chuck Bagdade Regular Member • Posts: 229
Got it! It works fine. Thanks for your help.
Chuck
doceyes Regular Member • Posts: 179
Chuck, BTW, do you have the instructional manual?
If not...
https://downloadcenter.samsung.com/content/UM/201302/20130202090154613/NX10_English.pdf
If yes, ignore my post! Regards.
 doceyes's gear list:doceyes's gear list
Pentax 645D Samsung NX1 Samsung NX500 Pentax K-1
Yup. That works! Thanks for the advice.
Chuck
