500D changing settings
Started Feb 5, 2022 | Discussions
Jsake
Jsake Contributing Member • Posts: 579
I recently acquired a 500D, mostly as a demonstration and learning tool. it appears that when looking through the view finder, you can only change settings after a half press of the shutter brings up the meter and settings display along the bottom. this disappears after a few seconds, and attempting to change shutter speed etc has no effect until the display is brought back my a half press of the shutter.
Can this behaviour be changed? is there a setting to allow a permanent display in the viewfinder?
 Jsake's gear list:Jsake's gear list
Canon EOS 500D Panasonic GX850 Sony a7R III Panasonic Lumix DC-S5 Sigma 35mm F1.4 DG HSM Art +13 more
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3)
stevet1 Senior Member • Posts: 1,300
Re: 500D changing settings
Jsake,
On my Canon 850D, the autoexposure lock only lasts for six seconds.
I don't know if that is a feature of all Canon cameras.
If I want to permanently hold that lock, I have to press and hold another button.
My AF button serves that purpose. My depth of field preview button works as well also.
To have a permanent display of your settings you may have to rely on your Live View screen until you get ready to take your picture.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Jsake
OP Jsake Contributing Member • Posts: 579
Jsake,
Steve Thomas
I had a look through the menu to see if there was an option to always display meter and settings in the viewfinder but couldn’t see anything. I suppose live view will work for just displaying the settings and how they change.
for practical use of the OVF it does make it somewhat slower to operate when you have to complete a half press on the shutter before being able to change exposure settings
jonby Regular Member • Posts: 402
Unfortunately, no I'm pretty sure there isn't any way to show the settings in the VF for longer. It's the same on most Canon DSLRs, even the 5D series. You have to go up to the 1D series to get the option to display them for longer! This has always been a bugbear of mine - it really baffles me why they thought this was a good idea.
This is one reason why I always set these cameras for back button AF. Otherwise it performs AF every time you half-press the shutter button just to view/change the settings.
On the 550D (and I think the same on the 500D), there is a bit of a workaround (though not a solution). If you have the settings screen on the rear LCD active whilst looking through the viewfinder, you will be able to change settings, even though you can't see them changing in the VF. If you are familiar with the direction of the dial, and understand third-stops etc. then you can do it fairly confidently by feel. It's not ideal because the glare from the screen can be distracting, but if you turn the brightness down a bit or use the 'night' display mode it's not so bad. On the 550D you have to disable the eye-sensor and turn the LCD on manually to achieve this. It's a menu item called 'LCD auto off'.
I think Canon's philosophy here was to lock the settings when they are not displayed anywhere on the camera. A consequence of there being no top-plate LCD is that they lock very frequently.
guinness2
guinness2 Veteran Member • Posts: 4,617
Hi, without any offense, I think you get it wrong.
You can change exposure etc settings anytime, but you can see that change immediately on the back screen, when lit or on the top LCD panel (when present) You will see it later in the viewfinder, after half press before actuation, anyway.
Additionally, I believe , that you see the change in the viewfinder for a while,  too, when you rotate the respective wheel, but I am not sure , pls check.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
Jsake
You can change exposure etc settings anytime, but you can see that change on the top LCD panel , (when present) or on the back screen, when lit, immediately, or later in the viewfinder, before actuation, after half press.
the problem with that on the 500D is; if you take your eye away from the viewfinder and change the settings while looking at the rear LCD,  you can’t see the meter or composition. the meter displayed on the LCD appears to just be for displaying your exposure compensation setting, not the actual exposure. thus when you change shutter or aperture, you still have to go into the viewfinder and half press to bring up the actual meter. it’s not the end of the world as i bought the camera basically as a demonstrator to show people how a DSLR works… just  seems like quite an obvious frustration that could easily have had a menu option to change. although saying that i hear this model is compatible with magic lantern so maybe i could look into that?
guinness2
Maybe I didn’t get it correctly, but look here, the shutter speed and f-stop are visible in the top left corner , or not ?
https://www.dpreview.com/reviews/canoneos500d/5
Canon EOS Rebel SL3
