Samsung NX Opensource files re-uploaded
Started Feb 4, 2022 | Discussions
foot Veteran Member • Posts: 4,805
I don't know...but this github on modding the NX500/NX1 is pretty specific
otto k wrote:
Hi, not all NX cameras run on Linux, my findings are only for NX500 (but do apply to other, but not all, models).
I don't know...but this github on modding the NX500/NX1 is pretty specific...
"This is a repository hosting information for those interested in altering the functionality of their Samsung NX500 and NX1 cameras.
These cameras run a full blown Linux distribution (Tizen) with shell, X, networking stack, debugging and testing tools - the works. This enables us to alter functionality of the cameras and ... well - just play around - it's fun! Seeing xeyes on your camera is such a heart warming experience
https://github.com/ottokiksmaler/nx500_nx1_modding#:~:text=These%20cameras%20run%20a%20full,and%20testing%20tools%20-%20the%20works.
curious...do you have other sources that say it's something else?
 foot's gear list:foot's gear list
Sigma dp2 Quattro
shutterbugnx
shutterbugnx Regular Member • Posts: 168
Re: Samsung NX Opensource files re-uploaded
ge0rg wrote:
I'd love to be able to unpack that and to understand which OS this tiny beast is running.
I wonder if the firmware has code to unpack itself near the beginning.
 shutterbugnx's gear list:shutterbugnx's gear list
Panasonic Lumix DMC-ZS60 Olympus PEN E-PM1 Sony Alpha NEX-7 Samsung NX2000 Fujifilm X-M1 +46 more
shutterbugnx
Re: I don't know...but this github on modding the NX500/NX1 is pretty specific
You're replying to Otto.. with a link to Otto's repository?
It's possible to execute scripts on NX mini, for example, but I couldn't get it to do much else than display text on the screen. It doesn't have Linux.
Here you can see some research on what operating systems various Samsung cameras are using: https://github.com/ge0rg/samsung-nx-hacks
ge0rg Forum Member • Posts: 51
I'm not very good at ARM disassembly, and there are no obvious headers in the firmware.
Older models (DV300F, WB2000/WB210F) package an ELF file in the firmware update ZIP,  it's just prepended with a 512 byte header. You can strip that header and use a regular ELF decompiler (I'm looking at the code with Ghidra) for them. There is also a bit of earlier reverse engineering work on them from the ancient past:
https://chdk.setepontos.com/index.php?topic=9465.0
https://web.archive.org/web/20130624174229/http://www.unternet.org/wiki/Firmware/Camera/Samsung_WB2000/FWUP
https://github.com/jam1garner/wb35f-research/
Unfortunately, the NX mini/3x00 bin file neither looks like those ELF files nor like any of the other NX series firmware files. There is no obvious signature at 0x000 or 0x200, so I feel lost.
Maybe I can find a broken/used 3000 and somebody who can desolder and read out BGA, but this is a huge amount of work.
 ge0rg's gear list:ge0rg's gear list
Samsung NX300 Samsung NX mini Samsung NX500
How do you do that? I haven't found any traces of any kind of code execution, and just a few vague hints regarding dev/CS modes.
I'd love to complete the entries on NX mini and NX 3x00, and I'd also love to understand what makes them tick.
Opps! My bad! My apologies Otto!!!
Opps! My bad. Didn't know that...
so reading that link, I found:
"These cameras run a full blown Linux distribution (Tizen) with shell, X, networking stack, debugging and testing tools - the works. This enables us to alter functionality of the cameras and ... well - just play around - it's fun! Seeing xeyes on your camera is such a heart warming experience :)"
as I read it, it clearly states that the NX500 uses Linux
I don't know anything about the NX mini
Sigma dp2 Quattro
JankHua New Member • Posts: 10
Thank you for your efforts.
 JankHua's gear list:JankHua's gear list
Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 16mm F2.4 Pancake
5
So I got a half-broken NX3000, disassembled the body (thanks iFixit!), and removed the paper sticker from the main CPU.
It turns out to be a Milbeaut MB86S22A SoC from Fujitsu/Socionext, and it seems that the company is still operational. I've documented what I found so far at https://github.com/ge0rg/samsung-nx-hacks/wiki/NX3000-Hardware-Information#cpu-details and it seems to be a very deep rabbit hole. The "M-7M" in M7MU stands for Milbeaut 7th generation: https://web.archive.org/web/20140627105054/http://jp.fujitsu.com/group/fsl/en/release/20130904-1.html
Apparently, other vendors also used the SoC, and it's also a secondary chip on the Galaxy K Zoom.
牛逼
freedom21
freedom21 Forum Member • Posts: 81
Can you add, manual levels volume, when you connect a mic to the NX30? That is, the ability to disable the AGC - Auto Gain Control? Thanks
“The truth will set you free, but first it will p* you off.” - Flip21
hunkreborn
OP hunkreborn Junior Member • Posts: 27
This is something that I've been trying to do for a while now.. I've already bricked one of my Nx30 main boards, 2 more to go... oh well.. I wish I was able to mod the NX Mini and NX300 to output clean liveview over the HDMI. Or 2k24p recording on the NX30 🥲.
Anyway, Samsung released the source code for the firmware compiler and the firmware package itself, the problem is that the camera runs a version of Tizen OS, and it runs a program called "di-camera-app-nx30", unfortunately most of the user level functions are all bind to this package, which can not be easily modified.
Maybe someone with a deep knowledge on Linux programming could reverse engineer the package and build a compiler, who knows... All we can do right now is unlock hidden configurations and run side programs, like autobackup or SD encryption.
Fast hands. Sharp eyes. Manual focus.
 hunkreborn's gear list:hunkreborn's gear list
Sony Alpha DSLR-A200 Sony Alpha NEX-7 Sony SLT-A77 Samsung NX2000 Samsung NX30 +17 more
Teext New Member • Posts: 1
Nice to see that you are still working on with NX system
Have you found any clue in those open source files or service manuals how to get access in developer menu with NX1 in firmware version 1.41?
This is not going to work with the source-code access that we got. As was already pointed out, the `di-camera-app` binary that's doing all the magic camera things, and the respective source code, and the respective documentation of the proprietary CPU registers, are not part of the Open Source packages. All that remains is to do some heavy reverse-engineering of it to identify changes from the previous version, and that requires significant dedication and time!
Artur - Brasil New Member • Posts: 9
Hi, I can't anymore send email with my photos.
The camera shows a strange site in chinese instead of email upload forms...
Any sugestion to fix this?
shutterbugnx
I recognize that site, it's Naver and the writing is Korean. There's no direct replacement for the emailing functionality as far as I know, but this may be of interest https://github.com/ge0rg/samsung-nx-emailservice
foxnoodles New Member • Posts: 11
This might be unrelated but is there way to disassemble / reassemble NX10 and NX11 firmware?
NX10 / NX11 Firmware decomposition
I'm currently doing a bit of firmware archaeology on the NX series, and it doesn't look like there is any sort of filesystem in the NX10/NX11 firmware, it's probably just one application that's loaded directly from the flash.
It seems to be powered by the uITRON real-time OS, but there is not much to be found out about it. NX200 is the first one that seems to use any sort of file system with dedicated files in it, but I haven't identified its format either.
Overview of the different NX camera generations: https://github.com/ge0rg/samsung-nx-hacks#device-support
Re: NX10 / NX11 Firmware decomposition
So basically I'll have to find some sort of "resource hacking" software for binary files and try to extract the images. Damn.
