Re: Samsung NX Opensource files re-uploaded
Piet22 wrote:
hunkreborn wrote:
US$80,00 for a pack of 4 dead NX30 bodies. Fixed 2 of them already.
I also have a dead NX30.
How did you repair the 2 dead NX30's? Was there a common problem?
Thanks for replying, regards Piet
Well, I bought the service manual in samsungparts.com (they suck by the way, as you HAVE TO PAY for shipping and WAIT for a CD containing the manual!!! A 30mb PDF! it ended being something like US$40,00 and a 7 day wait) I had to check each component in the board that could make the body become dead, one of them had a problem in the power line, I found 3 dead SMD caps, after I replaced them and the camera simply worked, but it still broken as it wont charge from USB. Not a real problem to me, so I didn't bother to risk making it worse by trying to fix this, probably the charging IC is dead. Its microscopic and really hard to replace, so... This is the one that I kept with me.
The one that I sold had a real simple problem, the board that handles all the cap charging for the in-body flash system was toasted, the cap was blown. This one had a real new body, like really brand-new! I just swapped the board using parts from another NX30 and it worked like new. As it was 100% functioning, I sold it to recover the invested money.
Do you have a clue about the problem in your NX30? If it doesn't turns on, check the flash-cap board, its beneath the palm rest. Be extra careful, to remove the palm rest you must remove 2 screws hidden behind the main board and one in the bottom of the camera. The command board connects to it using a really weak flex cable. I say this because I broke the first one that I tried to teardown before the service manual arrived.
Check for extra-heated elements in the board also, usually components that heat a lot in a small window of time are the cause for dead boards.
I still have 2 boards to play with, I'll try to fix another one, but there is one that I'm pretty sure its a lost cause because the ram chip is frying withing seconds. Unfortunately neither I have the equips and experience to replace BGA chips, nor I have a ram module that fits the camera. Usually I would remove it from a DDR2 Ram, but all of which that I have are rectangular shaped mem chips, Samsung NX uses a square one. So... Paper weight!
Anyway, good look trying to fix it. Its not really hard, it just requires a lot (I mean a LOT) of time and testing stuff. After a while it becomes really intuitive. And be really gentle with the flex cables, I think Samsung NX's flex cables are the weakest that I've ever worked with!
Fast hands. Sharp eyes. Manual focus.
