Moving from an X-E3 to an X-E4, all for a lens
Started Feb 3, 2022 | Discussions
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Re: Moving from an X-E3 to an X-E4, all for a lens
HeavyDuty wrote:
Phil1 wrote:
Have you looked into the fuji-made M mount adaptor for your Leica lenses. It seems to have some (limited but perhaps useful) communication betwen the camera and the lens?
Phil
I have, and have owned one for years now. I don’t enjoy using it because my Leica M lenses end up odd effective focal lengths.
With the X-E4 you can put in the actual name of the lens and you can set the focal length to whatever number you want, and you can have several of these entries in the camera and then just pick the one you want to use.  It is very convenient now.
In past years there was maybe one or two focal lengths you could change, and there was no way to put in the name of the lens.  So, things are much better now!
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
Les Lammers
Les Lammers Veteran Member • Posts: 4,247
HeavyDuty wrote:
Tom Schum wrote:
HeavyDuty wrote:
Enter Cosina-Voigtlander.
I’ve had quite a few C-V LTM and M mount lenses over the years, and I like their optics and mechanical build. When they announced the chipped 35/1.2 Nokton in native X mount, my ears went up…
I have the X-E4 with 27mm. That Voigtlander is looking pretty attractive to me right now, too.
I kind of wish my credit cards had little feet and could run away when I get in these moods!
I know the feeling! What I like about images I see from the Nokton are the two distinct characters, one wide open and one stopped down. It fits my shooting style.
I bought the Nokton and then an XE-4. The chipped Cosina lens is excellent. It's more compact than the Fuji 34 f1.4 It's a huge seller in Japan and I think there will be more to follow.
 Les Lammers's gear list:Les Lammers's gear list
Ricoh GR Digital III Ricoh GR IIIx Fujifilm X-E1 Fujifilm X-H1 Fujifilm XF 18mm F2 R +6 more
OP HeavyDuty Veteran Member • Posts: 3,035
Tom Schum wrote:
HeavyDuty wrote:
Phil
I need to find mine and try again!  I do have a couple of non-Leica M and LTM lenses I should try on it for fun.
Ken in New Hampshire
Railroad Action: http://www.pbase.com/kjford
Candids: http://www.pbase.com/kjford/other
 HeavyDuty's gear list:HeavyDuty's gear list
Nikon Z9 Nikon Z 24-70mm F2.8 Nikon Z 70-200 F2.8 VR Nikon Z 14-24mm F2.8 Nikon Z 50mm F1.2 +15 more
Mr Bolton Senior Member • Posts: 1,468
Tom Schum wrote:
HeavyDuty wrote:
Phil
Wow, are you saying you can store custom focal lengths for each lens by name?  And if so, can you put the ability to select them into the Q menu?
That is a very exciting feature!
 Mr Bolton's gear list:Mr Bolton's gear list
Fujifilm X100T Olympus OM-D E-M5 Fujifilm X-E1 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
michaeladawson Forum Pro • Posts: 18,313
It's too bad about the electronic data connections not fully supporting the X-E3.  I bought an X-E3 a few months back just to have a small camera for those times when I want to go small.  The X-E size is great for the small "Fujicron" lenses.
I was going to get the X-E4 until I found out it didn't have a rear control dial.  That was a deal breaker for me so I went with the X-E3.  This also saved me some money as well but that wasn't important.  It was that control dial.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
Tom Schum
I call this item from the "MyMenu" function.
When you have anything in MyMenu, and you hit Menu, then MyMenu will be the first thing to come up.  It is easy to get to the regular menus after that.
I have 7 items in MyMenu at the moment.
I have this as the first item in MyMenu in my X-E4, and there are 6 fields to select from.  Each of the six allows you to put in the lens name in words and numbers, such as "Rok 85 f1.8", and the lens focal length, in this case 85mm.  It is an absolutely wonderful feature.  Just select the one that matches the lens you are using.  This all goes into the EXIF of every shot.
I haven't tried it in the Q menu.
Tom Schum
Tom Schum
Sounds like you're going to have lots of fun!
I just realized I have a similarly awesome lens already, the Mitakon 35mm F0.95 Mark II.  So I won't be buying the Voigtlander.
Tom Schum
I’m not missing the rear dial at all - that’s the shutter speed dial for me, and I prefer using the top deck dial.
I just looked in the My Menu settings on the X-H1 and it allows lens modulation optimizer to be turned on or off (whoopie) but no focal length settings.  Boy, there's an easy to add firmware upgrade that I could request..
Tom Schum
I downloaded the X-H1 manual and new features guide, from here:
MANUALS:camera | FUJIFILM X Series & GFX – Global (fujifilm-x.com)
Looks like the X-H1 allows selection of some canned focal lengths and a couple of user-settable focal lengths, but there seems to be no capability to put in the lens name.  Maybe a real X-H1 owner can confirm this...
Also, I don't see in the manual which functions can and cannot be assigned to MyMenu.
Tom Schum
OrigamiCactus Contributing Member • Posts: 667
I had the XH2 and the focal lengths worked fine, although as you said, no lens names, and only 2 custom focal lengths. I'm pretty sure that it was also possible to add it to add it as top menu item in My Menu (not to be confused with Q menu).
Mr Bolton, is your firmware up to the latest version?
 OrigamiCactus's gear list:OrigamiCactus's gear list
Fujifilm X-Pro3 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR +1 more
Yes, that sounds right.  What I mean by no focal length settings, is none that can be named and saved to a My Menu item.  Sorry, that was unclear.
My camera's firmware is..  however my own firmware might need updating at this point
