Canon telephoto tripod mount collar ring size
Started Feb 3, 2022 | Questions
julyas43
julyas43 New Member • Posts: 17
I've been thinking about purchasing either a 70-200mm f4L IS USM or a 70-300mm f4-5.6L IS USM second hand (my mind leans more toward the 70-300 though). They both didn't come with a tripod mount collar ring from the factory, but I've seen one 70-300 in the ad with it bundled in. I'm now still saving up and afraid when I have the money that one with the collar ring will already be sold, so just in case, what’s the collar ring mount diameter for either of them?
 julyas43's gear list:julyas43's gear list
Canon EOS 60D Canon EOS RP Canon EF-S 18-200mm f/3.5-5.6 IS Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F4L IS USM +5 more
KenMT Regular Member • Posts: 185
Re: Canon telephoto tripod mount collar ring size
 KenMT's gear list:KenMT's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM Canon MP-E 65mm f/2.5 1-5x Macro Sigma 12-24mm F4.5-5.6 EX DG Aspherical HSM +7 more
Vladyslav Kosulin Senior Member • Posts: 2,362
Internal diameter is not all that matters. The collars may have different width, internal surface shape (flat ot conical), edges, and even rims inside. You will need to buy a collar that matches the lens you bought.
Vlad
 Vladyslav Kosulin's gear list:Vladyslav Kosulin's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F2.8L III USM Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM +4 more
msowsun
msowsun Contributing Member • Posts: 740
For the EF 70-200mm f/4 you need a Tripod mount ring A or A II.
For the EF 70-300mm L you need a Tripod mount ring C.
Here is a list of the various Canon Tripod Rings and what the lenses they actually fit: (W) means white, (W II) means new white color, and (B) means black
A (W) inside diameter : 65.25mm
A II (W) inside diameter : 65.25mm
A II (W II) inside diameter : 65.25mm (new white color)
A (B) inside diameter : 65.25mm
B (W) inside diameter : 78mm
B (B) inside diameter : 78mm (72mm with black insert adapter for EF 100mm f/2.8 USM Macro)
C (W) inside diameter : 81.5mm
C (W II) inside diameter : 81.5mm (new white color)
D (B) inside diameter : 68.5mm
"A" fits 70-200mm 4.0L , 4.0L IS, 200mm 2.8L, 300mm 4.0L, 400mm 5.6L, 80-200mm 2.8L (W II) 70-200mm 4.0 IS II (matches new white color)
"B" fits 70-200mm 2.8L, 2.8L IS, 2.8L IS II, 35-350L, 100-400L, 100mm 2.8 USM Macro, 180mm 3.5 Macro, MP-E 65mm 2.8 Macro
"C" (W) fits 28-300L (WII) fits 70-300mm L (matches new white color)
"D" (B) fits 100L Macro
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
