Flash for NX-10?
Started Feb 1, 2022 | Discussions
Chuck Bagdade Regular Member • Posts: 229
Flash for NX-10?
Hello. I'm trying to find a flash unit that will work with my NX10. Are there any "real" units, with tilt/swivel, that are available? Thanks for your help.
Chuck
Samsung NX10
kypfer Contributing Member • Posts: 985
Re: Flash for NX-10?
My NX11 manual refers to the SEF20a and SEF42a OEM flashguns which are probably what you'd want, unless you're prepared to work manually, in which case a generic (non-dedicated) gun of appropriate power should be adequate, the hot-shoe on the NX cameras seems to be of a "standard" size.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP Chuck Bagdade Regular Member • Posts: 229
Thanks. I'll see if I can track one down.
Chuck
Unfortunately the larger unit is unavailable- except for one on eBay for $400. No thanks.
Chuck
If you didn't like that one you certainly won't fancy this https://www.ebay.co.uk/itm/224820645356?hash=item34585acdec:g:AGQAAOSw4wxh-1uF
Where do these people get their ideas from?
markyboy81 Veteran Member • Posts: 4,778
🤣 no idea!!
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
You could have better luck with Metz. They produced fully functional (TTL) flashes for Samsung NX cameras (do pay attention that they are not for GX).
FWIW I bought a reasonably priced second hand Metz 44 af-1 from Poland and it works great (it has swivel which is not on SEF42A).
+1 for Metz, I have the 26 af and it's great. Unsure if it does everything the op wants though.
Thanks for the Metz idea. I'll check them out.
Chuck
