How is this SD1m portrait photo shot ?
Started Feb 1, 2022 | Discussions
adrianashoots Forum Member • Posts: 66
I found on this page some very nice photos of Sigma SD1
https://m.eprice.com.tw/tech/talk/1187/17202/1/
https://timgm.eprice.com.tw/tw/dc/img/2011-05/23/17202/oscar210_5_Sigma-SD1_2415914c6d0ac5f92b2ee209f74dcde8ori.jpeg
How it is this Merrill photo shot ?
The skin looks smooth, and colors are pure. Not leathery, dry in any way, but healthy.
 adrianashoots's gear list:adrianashoots's gear list
Sigma DP1 Sigma DP1s Sigma DP2s Sigma DP2 Merrill Sigma DP3 Merrill +7 more
Sigma 105mm F2.8 EX DG Macro Sigma SD1 Sigma SD1 Merrill
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: How was this SD1m portrait photo shot ?
How was this Merrill photo shot ?
Date 2011-01-11 17:18:07 -04:00
Make SIGMA
Model SIGMA SD1
Focal Length 105.0mm, 157mm (35mm equivalent)
Aperture ƒ/7.1
Exposure Time 0.017s (1/60)
ISO equivalent 100
Flash Fired Yes
White Balance Auto
Orientation Normal
Software Adobe Photoshop CS3 Windows
Exposure aperture priority (semi-auto)
Exposure Bias 0.00EV
Metering Mode Center Weight
Focal Length 105.0
Color Space sRGB
Exposure Mode Auto Bracketing
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
ole kekkonen
ole kekkonen Contributing Member • Posts: 607
Re: How is this SD1m portrait photo shot ?
in a studio?
xpatUSA
5
Most of the skin is out of focus which is why it looks smooth with not much detail:
GIMP edge detection filter - black equals no edge equals out of focus,--
It's all in the numbers ...
ole kekkonen
Ted@ that's a nice filter
here's a sharper one but not much space to the left or right in the histogram.
shot with a fill flash
allineedislight Senior Member • Posts: 1,309
You can do nice portraits with a Merrill sensor. Here is one from the DP2M:
https://www.magezinepublishing.com/equipment/images/equipment/DP2-Merrill-4038/highres/sigma-dp2-merrill-portrait-from-raw-SDIM0080_1352285530.jpg
taken from:
https://www.ephotozine.com/article/sigma-dp2-merrill-camera-review-19831
However, this requires that your models have perfect skin - young female models with makeup or children with clear skin.
Any imperfections, marks, freckles etc will show up with unforgiving detail..
Also with the Merrill it is absolutely crucial to get the colour right, otherwise the models with look a bit sick (greenish) or leathery (too yellow) or sunburnt (too red).
For example, for my DP2M starting with daylight white balance I need to dial in -2G Green (= +2M Magenta) to correct for the inherent slight green cast and then -4Y Yellow (i.e. +4M+4C) to remove the yellow cast. So in total +6M+4C adjustments. That is my current default with daylight WB and that gives a normal looking skin tone - not too yellow and not too red. On top of that I dial down sharpness to -1 and chroma noise reduction to the lowest level.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
ole kekkonen
Also with the Merrill it is absolutely crucial to get the colour right. For example, for my DP2M starting with daylight white balance I need to dial in -2G Green (= +2M Magenta) to correct for the inherent slight green cast and then -4Y Yellow (i.e. +4M+4C) to remove the yellow cast. So in total +6M+4C adjustments. That is my current default with daylight WB and that gives a normal looking skin tone - not too yellow and not too red. On top of that I dial down sharpness to -1 and chroma noise reduction to the lowest level.
sorry for sounding rude but I am so tired of the critics in here and now it goes over you.
any examples there you mind sharing??
or are you just another one with no legs telling how to run?
5
didn't I share an example of a good DP2M portrait shot?
Not sure what you mean but I just shared my personal settings how to get rid of the greenish-yellow look.
you can try it out yourself with your own DP2M, and let us know whether you agree.
and no, I am not posting family pictures here on dpreview, sorry.
ole kekkonen
atom14
atom14 Veteran Member • Posts: 3,301
Adriana, are you saying this was contrary to your expectations? I must say that in my casual portrait shots with the SD1M, this has not struck me as a quality. Detail, yes, but the other attributes...?
Ole, please resist the temptation to also give me a clip under the ear for not posting a shot My reply to Adriana was just meant to be "counter-qualtitative"
borissimo86 Regular Member • Posts: 289
It looks great if you don't look very closely. Along her jawline and neck, you can see posterization and the typical magenta edges and blotching of the SD1. In parts that are well-lit, however, the camera does a wonderful job.
OP adrianashoots Forum Member • Posts: 66
Thank you for your ideas and experiences, I  will try this
Indeed I was surprised, my impression is that the merrill sensor generation is criticized / disliked for rendering skin, that details are exaggerated like in a "contrast" "definition" filter, making the skin look dry and not fluid.
Some ideas been:
-to increase noise reduction in Sigma Photo Pro to maximum
-to use the color mode "Portrait"
-negative fill-light
-some say, always doing filters in post processing and post editing
-correcting colors with a color profile
Scottelly
Scottelly Forum Pro • Posts: 18,026
She sure is beautiful, huh?
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Wow u great 🙏☺️ And I have the same lens ☺️ and sometimes focus problems can be perfect
Scottelly
Some ideas been:
Don't forget to set Sharpness all the way to the left ("lowest" setting).
There are articles about processing portrait photos from Merrill cameras.
Scottelly
Ted, I'm sorry to disagree with you, but it sure looks to me like most of the skin would be in focus. Just look at the hair that is showing as in focus in your image, and on the left side that hair is obviously behind her cheek, while the hair on the right side is obviously in front of her face, so in front of her cheek. It looks to me like the focus is perfect on her eye, making most of her cheek, nose, chin, lips, and some of her hair in good focus, but for some reason your image is showing mostly just some of her hair, lips, and eye in focus, when we know that most of her nose has to be in focus, because all but the tip of her nose is behind the hair on the right, and in front of the hair on the left. Most, if not all of her cheek falls into the same plane of focus, yet your image makes it look like neither her nose nor her cheek are in focus.
ole kekkonen
atom14???
Yes thank u
