Infra Red technical details
Started Jan 26, 2022 | Questions
cvhmanchester New Member • Posts: 17
I wish to take IR images of faint graphite inscriptions on C19th prints. So I am considering converting one of my Olympus cameras (P5 or M5ii) to full spectrum by removing the IR cover filter (using a commercial service). Advice would be welcome. The OM help service was not able to provide anything.
Specifically:
Is the IR wavelength/ sensitivity of the sensors known? Is the IR wavelength/transmission of the 60 and 30 mm macro lenses known? Will the auto focus work with IR?
i.e. would it work? If so, which body would have better properties?
As an aside, are these details known for UV wavelengths, to which the conversion would also provide access?
Thank you
 cvhmanchester's gear list:cvhmanchester's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro +3 more
Elemental Photography Senior Member • Posts: 1,094
Re: Infra Red technical details
cvhmanchester wrote:
Specifically:
I have never seen an analysis of this data, so at least it's not known to me.
I have shot infrared with a 720nm filter on the Olympus 60mm lens. It does transmit infrared light, and my non-scientific understanding based on using a range of lenses on different IR/full spectrum cameras over the years is that I've never seen a lens be the limiting factor on infrared wavelength capture. This is anecdotal, not rigorously tested.
Autofocus works fine.
It should work for near infrared (i.e. near 720nm and a bit longer). It won't work for far infrared/thermal imaging.
From personal experience, it is nearly impossible to capture UV wavelengths with modern lenses- their designs and coatings block nearly 100% of UV from hitting the sensor. I've been trying to capture UV light with a full-spectrum converted sensor for years and I have yet to find an affordable way to do it, with the most promising solutions being scientific lenses specifically designed for UV transmission. Even the B+W Ultraviolet Pass filter I've used has transmitted far more IR than UV, to the point that the weak IR completely swamped whatever UV light may have made it through.
Thank you
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic GH5 +8 more
maggiemole Senior Member • Posts: 1,988
Specifically:
Thank you
It always disappoints me that dpreview does not have an infrared forum. However for what it’s worth I have been shooting IR with both Olympus and Panasonic converted cameras for several years. I use a fairly full range of filters covering about 450 to 950nm and they perform equally well on all my lenses. The lenses include the Olympus 30mm macro but not the 60mm macro. Certainly auto focus works correctly with IR. I don’t know what you mean by a body having better properties?
Whoever you choose to do the conversion will tell you more about the sensors than I can, but selecting full spectrum means you don’t need to specify a wavelength for your sensor, it is all taken care of by the external filter.
If you are based in the UK, I can recommend Protech Repairs as a very helpful company who will explain the details to you, in order to help you make any decision. In the US, the big name is Kolari but I have only used their sales service for filters.  I’m afraid I can’t help with your specific application but either of these companies should.
Avoid UV, It needs special sensors.
You might also ask for advice from one of the infrared Facebook pages.
Good luck!
Maggie
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
JeanPierre Martel Veteran Member • Posts: 3,304
All sensors block IR rays over 1300nm. Between 720nm and 1300nm, 96% of the sun’s IR rays are between 720nm and 950nm. In other words, less than 5% of IR rays are over 950nm.
Not all μ4/3 lenses can autofocus on an IR camera. The Lumix 20mm can’t on my wide-spectrum IR camera. But the Lumix 30mm macro lens and the M.Zuiko 60mm macro lenses work perfectly.
Any body camera should work.
If you were doing _colour_ I.R. as I do, you would see that the colour obtained with Olympus lenses are not _exactly_ the same as the colour obtained with Panasonic lenses, probably because they use different mineral coatings.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
elmanhansen Regular Member • Posts: 114
I have converted a PANA G1 and a GH2 to IR cameras. Not full spectrum but to wave lenghts around 700 nm. I did not want to use external filters. The bulk of my IR work is BW pictures - but I do also create colour (or fake colour) IR pictures. My main lens for IR work is a PANA 14 - 45 kit lens.
In addition to what has allready been said you should be aware of:
Some lenses do produce brighter centers in the picture. (hot spots)
I had a PANA 7 - 14 - and it is a hot spot lens. In many cases this can be modified in say Lightroom Classic, but it is better to use lenses that do not produce hot spots.
You have to know how to treat the pictures on your computer once you have  taken them. Search here on DPREVIEW. Look for i.e. IR and JeanPierre Martel. (he has an answer to you above mine)
Another good source is Rob Sheas web page. Search for him and IR on the WEB.
kbouk
kbouk Regular Member • Posts: 402
Lumix 20mm/1.7 (and also wider lenses) can focus on wide spectrum camera but all of these depends on the conversion and specifically the critical point is the adjustment of the sensor when service throw off the AA filter .
Cheers
Costas
 kbouk's gear list:kbouk's gear list
Leica Digilux 3 Olympus E-M1 Panasonic Lumix DC-S1R OM-1 Olympus Zuiko Digital 25mm 1:2.8 Pancake +14 more
Asla
Asla Senior Member • Posts: 1,101
Specifically:
Thank you
Hi!
https://www.dpreview.com/forums/post/63462514
I can't help you more. But apparently unmodified E-M5 can do IR, too. I've been tempted, but somehow missed buying even filter, not to mention sending camera for conversion...
A s l a
NFE Regular Member • Posts: 223
In addition to what others have said:
INFRARED
Ultravioletphotography.com has an infrared area with useful info: https://www.ultravioletphotography.com/content/index.php?/topic/712-sticky-ir-photography-cams-mods-lenses-lights-links/#comment-26624.  Unfortunately it does not address MFT lens performance.
I'd like to stress the IR hot spot issue.  This can be a real killer with some lenses, but plenty of lenses do reasonably well.  List of lenses known to hot spot, though it's not comprehensive:  https://kolarivision.com/articles/lens-hotspot-list/
Yes, different cameras, especially from different manufacturers, will give slightly different color infrared results.  The differences are probably mainly with the dyes in the Bayer filter matrix, but could also be caused by subtle differences in the IR transmission of the microlenses and the inner coverglass of the sensor.
UV
Ultraviolet photography is best for seeing subtle surface effects like faint scratches or inscriptions.  While it's hard to find common lenses with decent UV performance there are some out there that are usable. Refer to https://www.ultravioletphotography.com/content/index.php?/topic/1654-sticky-uv-capable-lenses/#comment-44959.  Personally, I mostly use an EF-mount 40mm f/2.8 STM as my walkaround UV lens.  I've also used the Sigma 60mm f/2.8 DN (on E mount but it was also made for MFT) for UV photography.  There are a couple of them in MFT mount on KEH right now.
UV-pass filters are expensive.  The best is the Baader-U but it's especially expensive and has a non-standard thread meant for use on scopes. It can be adapted but it's a bit of a pain.
The thick cover glass on MFT cameras doesn't make UV photography any easier, and will adversely affect the performance in outer regions of the image area for wider-angle lenses not made for that format.  That should not be a big problem with the 60mm since it's telephoto.
 NFE's gear list:NFE's gear list
Nikon D500 Nikon D850 Nikon Z7 Nikon Z6 Olympus E-M5 III +22 more
john isaacs Veteran Member • Posts: 8,444
Specifically:
Thank you
I had an E-PL6 converted by LifePixel. You can check their website:
https://www.lifepixel.com
and ask them.
OP cvhmanchester New Member • Posts: 17
Once again DPReview members have come up with an excellent range of useful answers.
I shall put a toe in the water by trying a 720nm filter on my (unconverted) E-M1 ii, starting by checking hotspots on the macro lenses I have, 2 Olympus, a Canon, and a Nikon.
Thank you to you all.
SterlingBjorndahl Senior Member • Posts: 2,642
Yes to LifePixel.com
Their web site also has quite a few articles discussing the technology. Well worth spending some time reading up. Also the DPR "Photographic Science and Technology" forum, https://www.dpreview.com/forums/1061
Sterling
Lens Grit
 SterlingBjorndahl's gear list:SterlingBjorndahl's gear list
Olympus Air Panasonic Lumix DMC-GX85 Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix DMC-FZ50 +18 more
I doubt that an unconverted camera will allow much 720 nm IR light to pass though . . .
But give it a try if youy allready have the filter.
