2181 adjustment program
Started Jan 24, 2022 | Discussions
johnapp Regular Member • Posts: 423
Does anyone know where I can get this program??
sybersitizen Forum Pro • Posts: 24,266
Re: 2181 adjustment program
There's a link on this page:
http://thesybersite.com/downloads.htm
OP johnapp Regular Member • Posts: 423
Thx , I found that site the other day , but maybe you can help me. I ran that program but the dynamic library links wont load. Tried put them in windows system 32 no luck. is the something missing out of the program??And if so could you help me find it ? thx
Nothing is missing, but you need to download and follow the instructions in the Service Manual Repair Guide for your camera, which is also available there. They are very explicit as to how to set up the software.
But the software is ancient, so it might not be compatible with recent Windows versions. If it still doesn't work with your version, you could try running the EXE file in a lower Compatibility mode, but that won't help if the DLLs aren't compatible.
The repair guide lists these as the system requirements for the adjustment program:
Windows 98/98SE, 2000 Professional, or XP, 40MB RAM and 15MB disk space.
tried it in  a dedicated xp machine still same message . Yes I did download instructions from the same website. Gonna try it in ME operating system. Ill report back.thx again
No Luck the dll don't want to load no matter where I put them whether they are in system 32 or system they cant be seen. doesnt matter ME XP or WINDOWS 8. Do have any clues for me?Ifeel like it is missing an ini file
Regarding the file locations, I can only refer you to the repair guide instructions.
As you can see in the repair guide, there was no INI file on the original CD, but you're supposed to put the ram.bin file on a card in the camera.
All I know is that it worked for me years ago under one of the old Windows versions, but I don't keep old versions around and I no longer own either of those cameras.
Yes I TRIED  that putting the ram.bin file in the root  of the cf card and held the lens lock button and with the switch on inserted the battery , with no success .
do you still have the cd rom?
I never had it. I downloaded my files years ago when they were posted on dyxum.com
I see well I have see about registering these dynamic library links. thx again.
UPDATE
I finally figured out how to use this Program, so here it is. First down load iit from sybercitezen  above, 2 put the  2186.dll and the 2181.dll in both the windows system folder and the system32 folder .3 open the usb folder and put the uusbd.dll into the windows system folder and the system32 folder. Oh one other thing is you need a 32 bit operating system with XP.        I needed to use this program so that I could reset the clock to default, this is the only way. The trick is you set a different destination, and that in turn resets everything. By doing this is like a hard reset. And this in turn allows the camera to go into sleep mode and then when you wake it up the shutter works again, just don't set the clock and it will work indefinitely. This is how you fix it if you dropped it and it wont fire or turn off for that matter. I hope this helps someone out there. In theory it should work on the 7d also        CHEERS
Re: UPDATE
It's nice to know the program is still useful for something if you have an old operating system. It's also the only way to see the shutter count that's recorded in the 5D. As I recall, the 7D shutter count is not recorded at all.
Re: UPDATE
That is good to know. but I achieved what I wanted and an afraid to louse it up delving in any further. I put that information up so someone else could use it, as there are no clear instructions on how to. But thx for keeping it alive on your website.
