Re: Performance of a much more expensive lens
SonyX wrote:
Jeep_Joseph wrote:
Hey my man, im gonna be honest. If this many people are explaining your wrong, you are probably wrong. I build lenses for a living, I can assure you I know my way around a lens
My dear "Teenage pro photographer", I'm not wrong, no matter what "many people" are explaining. I can assure you, BS about 40-150/2.8 and 120-300/2.8 is pure nonsense. There are Nikon engineers, who build lenses for living, I'm sure they know better what they are doing and what is performance of their lenses.
Just like FT Olympus 150/2 or 90-250/2.8, put 120-300/2.8 via adapter on your m43 body, and you will see, they are completely different lenses. 120-300/2.8 can be used with z9, so it is effectively 45mp 120mm f/2.8 to 20mp 440mm "f/4" lens. Your new toy is not even close to it's performance.
Utter nonsense. The m43 sensor will simply ignore the excess image projection so the 120-300 will work like a 240-600mm f2.8 lens. The smaller angle of view will create an apparent DOF of a f5.6 FF lens.
The lens remains a f2.8 lens because for portion of the projected image collected by the sensor, the photons per area remain those equivalent to those from a f2.8 lens.
If the rainfall is 30cm on a rainy day, the water you collect will be 30 cm deep, whether you use a cup or a swimming pool.
If you use 1 cup of pancake mix to make one pancake, and use another 1 cup to make a 4x bigger pancake, the first pancake will be 4x thicker than the second. This is the difference between a f2.8 m43 lens and a f5.6 FF lens, even if they have the same sized front element (1 cup).
And if the first pancake is fed to a child and the 2nd to an adult with a 4x bigger mouth, both will eat the same quantity of pancake mix per bite. The mouth is the sensor size.
I'm explaining it to you in terms you will probably understand because you clearly do not understand photographic terminology, although I'm sure you can press buttons.
Although it's more likely that you do, but your arrogance and sunk cost fallacy doesn't let you admit it.
Until you understand the limitations of your gear, you will never be as good a photographer as someone who does.
Wildlife photography in central and western India, and the Pacific Northwest. Mostly Micro Four Thirds with some Nikon F.
