NO EFCS in M6 II: a real shame
Started Jan 14, 2022 | Discussions
AKRover Regular Member • Posts: 289
Re: NO EFCS in M6 II: a real shame
Here is some of what I don’t know (the complete list appears to be endless). I don’t know anything about the velocity profiles of mechanical shutter curtains. I don’t know the distance between the sensor and the individual curtains on any shutter on any camera. I don’t know how any of the existing EFCS cameras time the row resets on the sensor. I don’t know if they use dedicated timer circuitry (which could be either analog or digital) or the internal microprocessor with software based timers. I don’t know anything about the specifications of the internal microprocessor. Without knowing any of that, I also don’t know much about exposure consistency across the frame which always varies with shutter speed in an EFCS implementation. With what I know that I don’t know, plus a lot that I do actually know, I can see a number of potential reasons why Canon didn’t give us EFCS in the M6II. Given my lack of understanding of the system, I certainly wouldn’t assume that Canon was forgetful, stupid, nor somehow evil in that decision.
 AKRover's gear list:AKRover's gear list
Canon EOS 5D Mark III Canon EOS 1200D Canon EF 50mm F1.8 II Canon EF 100mm f/2.0 USM Canon EF 200mm f/2.8L II USM +8 more
ThrillaMozilla Veteran Member • Posts: 7,665
Re: Something interesting, maybe...
nnowak wrote:
Greg Zillgitt wrote:
I checked a number of manuals, including the M50, R, R6 and 90D. The only one with that verbiage was the 90D. Since it's a close cousin to the M6 II (same image processing electronics, and released at the same time) I'm not surprised.
What is interesting is that the 90D does have 3 shutter modes, including EFCS. I wonder why Canon chose not to implement that firmware code in the M6 II? Cost would have been negligible I would think. Were they afraid of the M6 II cannibalizing 90D sales?
It is more likely that the two cameras are just using different shutter mechanisms and the M6 II is physically incapable of implementing EFCS.
Indeed they must have different shutters, because the M6II shutter is capable of faster bursts.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
thunder storm Forum Pro • Posts: 10,139
MAC wrote:
wddxnyr wrote:
I turned off IS in all my tests.
ok, good to know
just for your info:
I tested my 100L that has 4 stop IS -- and there is no shutter shock on my M6Ii at ss 1/60 and 1/80 and above -- the better IS systems -- heavier and more robust like the 100L are not as impacted is my conclusion
It is the small stuff with IS and rubber bands...
It is these smaller IS system in the m zooms that can be impacted
My 55-250 stm I tested has shutter shock at 1/60 and 1/80 but is fine ss 1/100 and above
I'd just say -- know your gear --
I think that's too much to ask for for such a small less than 1000 euro camera. It even cannot be found in the manual. Canon produces only 2 ef-m lenses without IS. Should we adapt expensive BIG and FAT  EF  L  lenses to this compact little camera without internal viewfinder to keep it as compact as possible to get rid of e-shutter?  Common.....
It's a design flaw, and nothing else.
and switch to e-shutter when in the impacted range
generally, with motion I switch to mechanical and ss 1/180 and above
with static subjects -- e-shutter on m6II is a big benefit
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
MAC Forum Pro • Posts: 18,487
thunder storm wrote:
MAC wrote:
ok, good to know
just for your info:
I'm not making excuses for it
I wish I didn't have to know the gear for this issue
true - it is a flaw that they have never admitted to -- therefore, we must know thy gear
that is an interesting statistic -- but the other M's have EFCS -- maybe the M6II was just released as a one off flyer
no, but since there is a design flaw, shouldn't we adapt to what we have?
Common.....
how many times did you tell me you'll just have to use e-shutter in the known trouble range
I'm not making excuses for them -- I'm just stating that since they did this, and don't at least give us firmware to shift between e-shutter and m-shutter in trouble zones, then we must adapt to what they gave us
I guess it is, but at least they could give us firmware to make the design flaw easier to use.
I'm not defending them -- I'm saying know your gear so you can adjust
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Ok
lumenite Senior Member • Posts: 1,208
MAC wrote:
wddxnyr wrote:
For this specific feature, I much prefer Sony's implementation. Their apsc sensors are also quite slow, but Sony still allows it. Having this option is certainly better than no option.
Having e-shutter that goes up to 1/16,000 rocks
i don’t think the m50II is a good solution for 1.4 primes in direct sunlight where you would need an ND filter
my RP has the problem of cut off bokeh with F1.4/1.2 primes above ss of 1/1000 starts to become noticeable
so even though there are some considerations when using m6II - I’ll take it for the positives
The reason bokeh is cut off above 1/1000 is because of EFCS, not because of electronic shutter, isn't it?
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
yes, it is ridiculous Canon designed the RP this way
that said - I knew this going in and bought my RP mainly for the RF 24-105 F4L which issues are not seen since shutter speeds are slower
you could see some bokeh issues with f1.2/f1.4 lenses used wide open outdoors at high ss but I'm not buying those expensive puppies for the RP
Canon knows how to dumb down
Will they ever launch the camera I want - an m5II with IBIS and EFCS - probably not
Makes more sense than the M6II without EFCS.
Cut off bokeh is only an issue with expensive large aperture primes, not with the RF 35&85mm IS stm lenses, only at faster shutter speeds. The RF f/1.2 primes are the only lenses being able to create cut off bokeh.
You can even work around it with ND-filters.
Not a whole lot of customers would want to do that I guess.
Yeah, but the most important spec of the RP is price, and another one is size, so it's kind of justified in my opinion. To my eye no EFCS on the M6II is a bigger problem.
Not going to happen. It's R5 or only 20Mp or slow AF and no IBIS, or fast AF no IBIS no EFCS or no IBIS no full mechanical. Pick your poison.
I hear you
but given the choice of m6II with e-shutter and no EFCS and M50II with EFCS and no useable e-shutter, and considering the great F1.4 primes, I'd choose M6II over M50II
I hear you
yep, but yuk
I might have wanted to, but they threw cold water on it
yep - I paid $850 for mine
yep - I can take both m6II and RP in one of my bags when I need the combo
I dunno
no useable e-shutter on RP is a bigger issue for me
too expensive
or only 20Mp
to few mpxl
ridiculous in this day and age
or fast AF no IBIS
no excuse for no IBIS
no EFCS
crazy that they left out
crazy again
Pick your poison.
technically possible -- dumbing down -- crazy poison
but I've never bought a camera that didn't have compromises -- it is understanding them before you buy -- and they don't teach you these things -- I had to learn on he forums
JustUs7 Senior Member • Posts: 4,327
It’s not perfect, but a workaround is a two shot focus bracket.  Allows you to use any mode in a true silent shutter.  You end up with two of everything with slightly different focus, but if you have to be silent and have to use your settings and only have the RP - there you go.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
Sorry to hear that. Just get that RF 85mm f/1.2, use a filter, or upgrade to the R.  You won't need more than 4 stops from it to compensate for both cut off bokeh and  the max of 1/4000th. Used Rs aren't crazy expensive, that's another option. The Soft focus version is darker due to the soft focus feature, so that could be helpful too.
The filter is still the best option to my eye. Personally I like the drop in filter adapter with my EF glass. At the end of the day 1/8000th full mechanical isn't always gonna cut it either.
I'm hearing you, may be worth a try when I have enough dof like using my RF 24-105L
not sure I'd do that with the thinner dof of my RF 85 f2 IS
thanks for the suggestion
hmm, believe it or not, I like the RP's classic Canon colors and SOOC look
will not happen for me -- I hate filters
I wouldn't buy an R now that I have my M6II
I changed my whole thinking since getting the m6II + M32 + DXO PL5
I have ss 1/16,000 with my M6II and m32 at f1.4 -- works for me
Yeah, I get that. M50 had it too. R5 is also great. The R and M6II are not in the same league.
O.k.
O.k. Makes sense.
Problem solved.
