NO EFCS in M6 II: a real shame
Started Jan 14, 2022 | Discussions
Iyou1 Regular Member • Posts: 111
I can confirm that shutter shock is a serious issue at some shutter speed.
This is an example of my tests with the 15-45mm. It's mostly the same story with the 55-200 and the 28mm macro.
EF-M 15-45mm at 45mm, f/6.3 , 1/80s. E-shutter on the left. On tripod with delay.
Is adding EFCS option via firmware update possible? Is it hardware related at all?
If it is possible, I really wish M6 II owner can contact Canon via phone and emails and give them the complain. Just maybe, they might add it.
I know this is 2022 already and a update seems very unlikely. But I really think this is not acceptable because: every other EOS M has EFCS; the lack of EFCS is never informed.
Canon EOS M6 II
Sittatunga Veteran Member • Posts: 5,406
Re: NO EFCS in M6 II: a real shame
It was pointed out in dpr's review of the camera two months after the camera was launched, and it's been mentioned in at least a dozen threads here in the last three months.
EFCS was originally a cost-cutting measure to do away with half the shutter assembly.  The M6II is the first EOS M to have a complete shutter.  Maybe the Mark iii will offer EFCS, who knows?
OP Iyou1 Regular Member • Posts: 111
I read the review but I didn't expect it to be so evident. They said there is some slight shutter shock. As you said, many users' tests show that the impact is significant.
MAC Forum Pro • Posts: 18,487
Did you turn the IS OFF on tripod with the mechanical shutter?
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
JustUs7 Senior Member • Posts: 4,327
In reading up in this, I understand it to not be true shutter shock, but rather the small IS assembly in image stabilized lenses. Even with the IS off and mounted on a tripod, it’s essentially held in place by springs and so it can impact image quality at shutter speeds between 1/10th and 1/200th on both the 15-45 and the 55-200. I have not seen tests on the 18-150.
Non-stabilized lenses like the 32 f/1.4 do not suffer from the issue at any shutter speed.
https://www.canonnews.com/canon-eos-m6-mark-ii-analysis-of-shutter-shock
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
Yes I also tested the 32mm and it's fine. Still I don't think this is a valid excuse to omit EFCS.
I turned off IS in all my tests.
ok, good to know
just for your info:
I tested my 100L that has 4 stop IS -- and there is no shutter shock on my M6Ii at ss 1/60 and 1/80 and above -- the better IS systems  -- heavier and more robust like the 100L are not as impacted is my conclusion
It is the small stuff with IS and rubber bands...
It is these smaller IS system in the m zooms that can be impacted
My 55-250 stm I tested has shutter shock at 1/60 and 1/80 but is fine ss 1/100 and above
I'd just say -- know your gear  -- and switch to e-shutter when in the impacted range
generally, with motion I switch to mechanical and ss 1/180 and above
with static subjects -- e-shutter on m6II is a big benefit
Just to add a bit, e-shutter should be fine except in certain lighting where banding can be an issue.
If you’re in circumstances were distortion from rolling shutter is and issue due to motion, you probably want higher shutter speeds anyway, where shutter shock will cease to matter.
That said, I agree that the top of the line M camera should have EFCS as an option.  Then there’s the opposite complaint with the RP where full mechanical isn’t an option, silent shutter is only available in a scene mode (unless you use a focus bracket work around trick), otherwise it’s only EFCS.
I agree. Another thing is no continuous mode in e-shutter. Very annoying. It's for protecting their higher end products only. People have hacked into M50's firmware and unlocked manual control e-shutter and continuous drive manual e-shutter.
See magic-lantern forum
It's almost certain that M6 II can be done the same (both are digic 8). But it's beyond my ability right now.
nnowak Veteran Member • Posts: 9,075
No, it is protecting Canon from a lot of user complaints.  The readout speed of the 24mp sensor is reallllllly slow.  Trying to photograph anything moving with the e-shutter would lead to a lot of rolling shutter distortion.  The M6 II is better in this regard, but still not great.
For this specific feature, I much prefer Sony's implementation. Their apsc sensors are also quite slow, but Sony still allows continuous drive with e-shutter. Having this option is certainly better than having no option.
wddxnyr wrote:
For this specific feature, I much prefer Sony's implementation. Their apsc sensors are also quite slow, but Sony still allows it. Having this option is certainly better than no option.
Having e-shutter that goes up to 1/16,000 rocks
i don’t think the m50II is a good solution for 1.4 primes in direct sunlight where you would need an ND filter
my RP has the problem of cut off bokeh with F1.4/1.2 primes above ss of 1/1000 starts to become noticeable
so even though there are some considerations when using m6II -  I’ll take it for the positives
Greg Zillgitt Senior Member • Posts: 2,854
Something interesting, maybe...
On page 302 of my camera manual, in the section on "non-Canon flash units", it says "when shooting with an external Speedlight, set Shutter Mode to an option other than Electronic."
I found that phrasing interesting. As of firmware 1.1.1  the only Shutter Mode options are "Mechanical" and "Electronic", so why not say "set Shutter Mode to Mechanical" - unless you were allowing for a third option, perhaps to be introduced in a future firmware update?
I'm not excited by the prospect for two reasons: 1) the M6 Mk2 is already long in the tooth, so if it were to happen it probably would have happened by now, and 2) EFCS is overrated, IMO.
 Greg Zillgitt's gear list:Greg Zillgitt's gear list
Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF 50mm F1.8 STM +4 more
Re: Something interesting, maybe...
Don’t get too excited. Generic language so they can copy and paste to all their camera manuals regardless of mechanical or EFCS.
ThrillaMozilla Veteran Member • Posts: 7,665
What is this? A photograph of a video screen? A photograph of a screen-printed target? Or what?
I'm pretty sure this is not a valid comparison of two images.
It's oddly blocky. (Not pixelated, but blocky.) And the one on the right has noticeable lateral chromatic aberration. A mechanical shutter does not create chromatic aberration. The photo on the right was not created in the same way as the one on the left, and was apparently not centered in one or another lens that was used to make the photo. We don't even know if it was in focus.
I know the EF-M 15-45 is subject to shutter shock. I have written about it myself. But this is not very good evidence either way.
By the way, there is an easy way to mitigate the shutter shock. I don't routinely bracket exposures any more. Thanks to the live 3-color histogram, that is less necessary than it used to be. And for action photos with a repeating shutter, I would use high shutter speeds anyway, and the shutter shock is not visible at high speeds.
I wish the shock were not there, but it's not the only camera ever to suffer from this problem. Some very expensive flagship cameras have suffered from serious to severe vibrational artifacts in recent years.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
I checked a number of manuals, including the M50, R, R6 and 90D. The only one with that verbiage was the 90D. Since it's a close cousin to the M6 II (same image processing electronics, and released at the same time) I'm not surprised.
What is interesting is that the 90D does have 3 shutter modes, including EFCS. I wonder why Canon chose not to implement that firmware code in the M6 II? Cost would have been negligible I would think. Were they afraid of the M6 II cannibalizing 90D sales?
It is more likely that the two cameras are just using different shutter mechanisms and the M6 II is physically incapable of implementing EFCS.
https://media.the-digital-picture.com/Sounds/Canon-EOS-90D.mp3
https://media.the-digital-picture.com/Sounds/Canon-EOS-90D-Burst.mp3
https://media.the-digital-picture.com/Sounds/Canon-EOS-M6-Mark-II.mp3
https://media.the-digital-picture.com/Sounds/Canon-EOS-M6-Mark-II-Burst.mp3
they probably are different shutters
Sounds like EFCS on the 90D.  Single click vs double click on the M6II.  What does full mechanical sound like?
