[Panasonic G7 Help] Viewfinder is not working
Started Jan 13, 2022 | Questions
markgergerome New Member • Posts: 1
Hello. I recently got my G7. However, it's viewfinder isn't working. I tried clicking Fn5 to different modes and the VF is showing no light. I checked the settings and the Fn5 is correctly assigned. Also, the Eye sensor only has two settings to tweak but adjusting these led to no result. Fyi, I've updated the body and the standard lens to latest firmware.
What could possibly be the problem?
Panasonic Lumix DMC-G7
alcelc
alcelc Forum Pro • Posts: 19,006
Re: [Panasonic G7 Help] Viewfinder is not working
fn5 is the default control to select evf, LCD or Auto evf/LCD switching mode.
If fn 5 has not been changed to other control, likely you have a defective evf. Return it if you can.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
Keit ll Veteran Member • Posts: 5,172
Are you talking about the G7 or GX7?  The movement facility on the GX7 can cause a ribbon cable failure.
alcelc
I think OP was talking about G7 since likely fn5 should be its default evf/LCD switch. GX7 has fn4 for similar control on default.
Albert
