What are these waves in the sky visible on some .ORFs ?
Started 6 months ago | Questions
stokey Contributing Member • Posts: 550
I occasionally observe wavy lines on photos with blue sky. They are visible only on raw files not on OOC jpgs or jpgs output from OV3. Anyone know what causes this effect ?
.ORF
.JPG
 stokey's gear list:stokey's gear list
Olympus OM-D E-M10 II Olympus E-M1 II
David
David Contributing Member • Posts: 534
Re: What are these waves in the sky visible on some .ORFs ?
.ORF
.JPG
Have you tried using the newer Olympus Workplace to read your RAW file and does it show the same effect with the correctly set color space for displaying ORF RAW for your display?  And in what color space did you set for your display which you use to view your RAW file?
 David's gear list:David's gear list
Nikon Coolpix AW110 Panasonic ZS100 Olympus PEN E-P5 Olympus E-M5 II Panasonic Leica Summilux DG 25mm F1.4 +12 more
OP stokey Contributing Member • Posts: 550
Same effect observed using Olympus Workspace v1.5 and also Irfanview, colour space is sRGB.
Bob
19andrew47
19andrew47 Forum Pro • Posts: 43,160
Which lens? Panasonic lens will at times display banding on Olympus bodies. My 20 mm f/1.7 Panasonic does.
I see posterization in skies at times when the exposure is not correct at the time the image was taken. It does not resemble that banding though.
You have two bodies listed in your gear.  Does it occur for you with both bodies?
Andrew
RSTP14 Veteran Member • Posts: 5,479
My guess is the RAW is in AdobeRGB and you are displaying in sRGB, and the sRGB doesn't have the colors to display all the gradations in the sky. The in-camera JPEG would be sRGB.
Roger
 RSTP14's gear list:RSTP14's gear list
Olympus OM-D E-M10 OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
pop2eye Forum Member • Posts: 73
5
Bob
Irfanview does not actually open and process the ORF raw file. It only opens the small (usually 3200x2400), low-quality JPEG preview image that is embedded in the ORF file. I think the banding you are seeing is from the JPEG artifacts in the highly-compressed preview image.
 pop2eye's gear list:pop2eye's gear list
Olympus OM-D E-M10 Olympus E-M5 III Olympus 12-40mm F2.8 Pro Olympus TG-6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +2 more
Andrew
In this instance E-M5.3 + P8-18, also seen with E-M10.2 + O9-18.
Bob
pop2eye wrote:
Bob
Could well be so, but what about OW and OV3 ?
Bob
I wasn't aware that one could set the camera to apply different colour spaces to the RAW and JPEG.
Bob
acfo Senior Member • Posts: 1,356
.ORF
.JPG
The effect is called Colour banding .
 acfo's gear list:acfo's gear list
Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
drj3 Forum Pro • Posts: 12,379
stokey wrote:
pop2eye wrote:
Bob
Bob
On OV3, Tools, Options, Advanced Settings, change RAW image Quality from Standard to Display at highest quality and see if it still occurs
on WS - do not check - Photos - Display RAW images with Priority on Speed and the actual display may depend on GPU on your computer.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
19andrew47
In trying to look this up I came across some forum talk on banding caused by use of the electronic shutter modes.  Are these with the mechanical shutter?  The sample images I saw there had much smaller bands than displayed in your posted image so possibly not the same cause.
Andrew
Thank you, that does the trick. You win 1st prize Mr drj3, but could you explain in a little more detail what WS does to produce this effect when "priority on speed" is selected ?
Bob
pannumon Veteran Member • Posts: 3,888
I am pretty sure that when priority is on speed, it simply shows the low quality JPEG-file that is embedded to the raw file. This is much much faster than showing the actual raw image, which needs to be processed before it can be viewed.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
Bob
It is using a much lower resolution (imbedded jpeg) in order to speed the display when priority is set to speed.
drj3
Guy Parsons
Guy Parsons Forum Pro • Posts: 38,211
Bob
Setting the colour space to sRGB or to Adobe RGB only has an effect on the camera jpeg. The raw file has no colour space but has the jpeg setting stored within its exif data. A raw converter may by default use that stored colour space setting, or the user can choose another colour space during the raw conversion.
Just for fun I opened a raw file (my camera jpegs are set for sRGB) and in Affinity Photo as an example I can choose any of 34 colour choices to use for output. Naturally the default is sRGB IEC61966-2.1 which I have to assume is the one found in the raw file exif data.
The Affinity help file says this...
About color space
Each output device, for example, your display or printer, is only capable of producing a certain range of colors. A color space is a specific implementation of the color model used to define the color gamut (i.e., the range of available color). For example, Adobe RGB, sRGB, Apple RGB, and so on, are all unique color spaces for the RGB color model. Different color spaces are also available for CMYK and Lab color models.
Each output device, for example, your display or printer, is only capable of producing a certain range of colors. A color space is a specific implementation of the color model used to define the color gamut (i.e., the range of available color). For example, sRGB, Apple RGB, and so on, are all unique color spaces for the RGB color model. Different color spaces are also available for CMYK and Lab color models.
In order for a device to know which color space to use, it looks at the assigned color profile. You can choose your color space by assigning a color profile to your document.
Which color space should I use?
Which color space you choose depends on what you're doing and the color model you're choosing to operate in.
If you're unsure of what color space to operate, it's advisable to stick with the default sRGB IEC61966-2.1 profile if using the RGB color model.
Sony RX100 VI Olympus PEN E-PL1 Olympus PEN E-PL5 Olympus PEN E-P5 Olympus OM-D E-M10 II +10 more
Bob
So I'm editing my photo based on viewing a very low resolution image ?
Guy Parsons
stokey wrote:
Bob
To speed up things, many programs default to initially showing that horrible embedded jpeg before they (slowly) process the real raw data and finally show that instead.
Hopefully when editing the raw file you are actually editing the raw file and when outputting the result it is the jpeg from the raw file.
The freebie FastStone Viewer by default uses the embedded jpeg simply for speed reasons, the user needs to change the Settings so that it uses the raw data instead.
