Canon t6 (3.5 fps and 9af points) for wildlife
Started Jan 6, 2022 | Questions
photomaniac1010 New Member • Posts: 2
I'm wondering if I can use my Canon EOS Rebel t6 (18mpx 9af points 3.5fps) coupled with a 150-600 for wildlife photography, specifically bird photography. The af system seems limiting and the 3.5 fps is disappointing. I don't personally own the Sigma 150-600 but I can regularly get in in my hands from a relative. I'm 14 so my budgets limited. Would this setup be suitable for bird photography? Thank you so much!
Canon EOS Rebel T6 (EOS 1300D)
The_WB Contributing Member • Posts: 566
Re: Canon t6 (3.5 fps and 9af points) for wildlife
I have a Rebel T5.  Shot a marathon a number of years ago with a 55-250MM STM Canon lens.  Long story very shot, my results with the AF system (which is spec'ed identically between the T5 and T6) were bad.  The buffer fills quickly, the AF cannot keep up with the runners and the AF points are spaced far enough apart that runners fall in between focus points.  Lastly, there is NO autofocus adjustments that can be made with the camera to improve tracking, unlike higher end Canon models.
In short, I got some good shots, but many were just out-of-focus wastes of card space that ended their lives in the recycle bin.
mdmarqphoto Senior Member • Posts: 1,460
Still shots should certainly be doable, but birds in flight will likely be difficult.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
Sactojim Veteran Member • Posts: 9,105
You need to learn more on how to use the camera. Of course the T6 will work for wildlife, birds in flight, etc. People have shot successfully shot wildlife very well with lesser gear than the T6. Go back 10-15 years and compare specs to see what they were dealing with and images. I suggest you grab that lens and experiment to see what settings, technique work well for you.
Here's a guy who knows his gear and his images are up there with any $3,000 body. People giving you negative advice should be ignored. View any of his posts and you will see what I'm talking about. You can do it.
https://www.dpreview.com/forums/post/65821600
Digirame Forum Pro • Posts: 41,857
It should be fine.  I used the Tamron 150-600mm lens with my older Canon T3i (600D) cameras for years.  Now I'm using that lens with a Canon T7i (800D) camera.  Try it out and see.  Let us know the results.  It takes a while to get used to handling that large telephoto lens.
Sure if you had a newer camera like the Canon T8i (850D) or Canon 90D that would be better.  But we use what we have.  Remember that the best camera you have is the one that you are using.
Challenge yourself to get just as good of photos as someone else that uses gear worth thousands of dollars more.  Have fun taking pictures.
tdbmd Senior Member • Posts: 1,547
It will work fine.  I used a T3i for a number of years with for wildlife.  Go and have a great time!
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
YWG Senior Member • Posts: 1,364
I believe that is the same 18MP sensor I had in my Canon 7D1. I personally found that sensor to give excellent results even up at ISO 3200. I do have a fairly high tolerance for noise compared to others however.
That 9pt AF is pretty rudimentary. I had it on my 5D1 along with 3fps burst and limited buffer. I think it will be fine for static, perched birds but you may benefit from a tripod or monopod.
Getting shots in flight isn't impossible but certainly easier with a more advanced camera that give more buffer and burst speed. I would give it a try with your T6 first on the centrepoint, 3.5 fps, AI Servo. Look at it as a bit of challenge being conservative with your shutter presses for the critical moment. You will still develop core skills of framing, tracking that will play over if you get an upgrade.
 YWG's gear list:YWG's gear list
Olympus Stylus 1s Canon PowerShot G5 X Olympus E-M1 Olympus E-M1 II
PhotosFlight
PhotosFlight Contributing Member • Posts: 609
It sounds like you have the camera and you can get the lens, so give it a try.  You will need to practice, and a monopod will certainly help.    I keep a T3i at a second home along with an EF 70-300 Mark II (this is the more higher end version of the 70-300) and have gotten reasonably good results even when compared to the 7D Mark II and R6 using L series glass.
I think it is important to figure out what you can get with the equipment you have through practice and experimentation.  That is the only way you can really determine if you need to upgrade.
I've invested a lot in equipment but only after I was determined through practice that I could not get the results I wanted with what I already had.
Give it a go and let us know how it turns out.
 PhotosFlight's gear list:PhotosFlight's gear list
Canon EOS 30D Canon EOS 50D Canon EOS 7D Mark II Canon 6D Mark II Canon EOS R6 +14 more
