X-E3 and Accurate (repeatable) Autofocus ...
Started Jan 4, 2022 | Questions
Chas J Contributing Member • Posts: 955
I have (and have used for years) Nikon DX and FX cameras.
I bought a Fuji X-E3 about I year ago as a travel camera. I really want to like the camera (and do) BUT I find the autofocus hit rate to be low ! ... missing approx 1 in 5 shots ... much lower than my Nikons in similar circumstances. This is for static subjects.
I thought it might be the lense (23mm f2) so I bought other lenses. I thought that it might be the body so I bought another (used) body. But I get the same problem with any combo.  I am now mainly using it with the 27mm f2.8.
Is this common ?. Do you have any tips for better autofocus or am I just going to have to live with it ?.
Thanks.
Do Not Listen to What I Say ... Listen to What I Mean !.
 Chas J's gear list:Chas J's gear list
Nikon D700 Panasonic Lumix DMC-GH3 Olympus E-M1 Nikon D610 Nikon D810 +30 more
Erik Baumgartner Senior Member • Posts: 6,893
Re: X-E3 and Accurate (repeatable) Autofocus ...
5
Thanks.
What focusing methodology are you using?
AF-S, single point, focus box on the subject, full-press the shutter button - never misses for me (X-T20, should be the same as the X-E3). With a static subject you should be getting a 100% hit rate.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Mr Bolton Senior Member • Posts: 1,468
Thanks.
There are a wide variety of autofocus settings on Fuji cameras.  I can't claim to fully understand them, but this forum has proven helpful over time in doing so
 Mr Bolton's gear list:Mr Bolton's gear list
Fujifilm X100T Olympus OM-D E-M5 Fujifilm X-E1 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Raymond L
Raymond L Contributing Member • Posts: 674
Thanks.
It's good for AF-S, not the best for AF-C.
But here are my settings, would be great if you could share you settings as well.
Camera Settings:
Performance: High
Focus Area: Single Point
AF-C Custom: Set 2
PRE-AF: Off
AF Illuminator: Off
Face/Eye detection settings: Face / Eye
Release/Focus Priority: Focus for AF-S/AF-C
Touch screen settings: Off
Focus Technique:
Move AF single point to the area that I would like in focus, if object is further away, use a smaller single point area (this will ensure it doesn't back focus).
 Raymond L's gear list:Raymond L's gear list
Sony RX100 IV Sony RX1R II Leica M9 Nikon D800 Fujifilm X-E1 +29 more
Thanks.
Camera Settings:
Performance: High
AF-C Custom: Set 2
PRE-AF: Off
AF Illuminator: Off
Focus Technique:
I've found the face/eye detect to be unreliable.  Except with the 50mm f1, where it seemed to work much better than with any other lens..  if you aren't shooting people you might try turning it off.  Heck, even if you are shooting people you might try turning it off
Thanks.
Camera Settings:
Performance: High
AF-C Custom: Set 2
PRE-AF: Off
AF Illuminator: Off
Focus Technique:
Agreed, I've found the Face/Eye AF pretty much worthless on the X-Trans III cameras, I never use it.
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,178
+ Priority on focus not release
+ AF/MF off
BR,
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Yes, but with a full press of the shutter button, my Fujis won’t shoot until focus is acquired regardless of the Focus Priority setting.
+ AF/MF off
Why? I like AF + MF and usually keep it on.
+ High Performance mode too.
BR,
Martin
FTOG Senior Member • Posts: 1,359
I understand you had the same problem with the 23/2.0, but just wanted to point out to you that your current main lens, the 27/2.8 has some field curvature. Especially at its faster apertures and shorter focus distances, move the AF point to your main subject, rather than using AF+S and recomposing, for more consistent results.
As for the X-E3, I've used two bodies with a plethora of lenses and outside of the so-so face detection have not had issues with missed focus. I don't shoot sports with AF-C and tracking, but you don't seem to either.  I tend to use single-point AF, with a rather small focus box and most commonly AF-S (or MF). My cameras are always on high performance mode, and AF-ON and AF-illuminator are always off.
 FTOG's gear list:FTOG's gear list
Fujifilm X-E3 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR +2 more
Rightsaidfred
Exclude unwanted effects
+ AF/MF off
Hi Erik, in critical situations, I always recommend to exclude any possible unwanted effects as much as possible. I've read in the forum that AF+MF overrides the focus priority. Seems logical, didn't check it, but this is enough reason for me to recommend the OP to switch it off, at least for now.
BR,
Martin
OP Chas J Contributing Member • Posts: 955
X-E3 Autofocus ...
Thanks for the good responses from you all.
I will make sure that the camera is set up as suggested and go out for a photo walkabout today and see what I get.    Will report back.
Chas.
a_c_skinner Forum Pro • Posts: 13,047
Just to join in, mine is spot on.  I choose something to focus on, trigger the focus, recompose if needed and push the button.  It hardly ever misses.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
Re: X-E3 Autofocus ...
Also the smallest focus box is not the best choice.  I alway use the next one up.
"The winds of heaven is that which blows between a horse's ears," Arabic Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Chas.
Well. It was -24°C and I was invited to overnight with my buddy who lives so far out in the sticks that my GPS started asking me for directions.
Anyhoo. I took my (not) trusty X-E3 with me (with my Nikon D700 as back-up). Here is what I found while paying special attention to the focus:
In good light (daylight) the focus is mostly accurate and dependable. When light levels drop (dusk and beyond) the camera will give a nice reassuring 'beep' that it has found focus but quite often it has not !. Also, in good light, I was trying to photograph some birds landing on a bird feeder. I was using the bird feeder as the focus point. The feeder had many trees behind it in the background. I would say that nearly 50% of the time the camera would focus on the trees. I tried small box single focus and 'group' focus. In this instance the 'group' seemed to be the most successful.
Everybody has their own expectations and determine what is acceptable to them. For autofocus, my experience has been built on Minolta and Nikon with a sprinkling of Olympus and Panasonic. To date, in low light and / or low contrast situations the Fuji X-E3 is the least reliable autofocus camera that I have worked with. As a parallel, my Nikon D610 is notorious for not being able to focus in low light but at least it has the decency 'not' to give the autofocus confirmation 'beep' (and take the photo) when it has not found it !.
What am I going to do ?. I do not know. I like the output, look, feel and the size of the X-E3 ... I want so much for it to be a 'keeper'. But that autofocus !!!.
FWIW.
Chas.
FWIW.
I honestly don’t know what you’re doing wrong, but my X-T20 with presumably the same AF system NEVER misses with a static subject in pretty much any light with any of my lenses.
AF-S, single point box on the subject, full-press the shutter button - perfect every time.
Raymond L
Can you provide some insight as to what is “low light” for you ? is it 1/60 ISO 12,800 ? and do you have any pictures to illustrate what scene you were attempting to capture ?
Yes, I don't know what is going on here. My X-E3 with a variety of lenses fro static subjects is pretty much 100% spot on.  Just pre-pandemic I was out at -30C (arctic Finland) and it worked perfectly.
Andrew Skinner
I looked through my X-T20 ISO 12800 shots and there really aren't any that aren't in focus. Terrible, yes. But out of focus, no, not really.
Since I'm not having any trouble, why don't you post some missed focus examples and EXACTLY describe the settings and techniques used while shooting each.
I can't auto-focus on a featureless wall in the dark, but with any static subject with even a hint of contrast, i really have very little trouble focusing (AF-S) using any of my lenses in any light with anything worth photographing, including with the 35 f/1.4 and 56 f/1.2.
Phil1 Senior Member • Posts: 2,307
Quite a lot of OoF shots with Fuji cameras are due the inadvertent inclusion of a small portion of background with a higher brightness and/or contrast that the intended subject. Did it myself at a shoot today!
Just make sure your focussing square only covers the subject and that it doesn't move off the subject when you press the shutter which can be difficult to avoid. Also, as pointed out elsewhere, avoid the smallest focussing squares and ensure that the square doesn’t include anything other than the subject.
This may not solve all focussing problems, but get these points wrong and you can guarantee OoF shots!
A recent poster had a similar problem and when we looked at the focussing point it had completely missed the target area every time, so getting this right is not always easy. Best to practice before shooting irreplaceable shots – and always check focus and re-shoot if necesary!
Good luck
Phil
uniball Veteran Member • Posts: 3,075
I bought my first Fuji, the original X100, when I shot a D800. There was an adaption process required. On my part, not the camera's. Fuji still lags the industry in AF. If that’s a dealbreaker, you should probably consider you’re not going to be happy shooting Fuji. I shoot an X100V, a couple of Panasonic m43's and a couple of Sony RX100's. The Fuji lags them all. But if I had to choose only one, it would be the X100V without any hesitation. You know your criteria. Your decision.
