The 16mm f/2.8 on the X-E2
Started Jan 3, 2022 | Discussions
Jeff Biscuits Senior Member • Posts: 1,166
Anyone using this combination? It seems that whilst my X-T2 corrects the lens’s optical distortion (in fact to my eye it over-corrects it just very slightly) the X-E2 doesn’t, and nor did the X-T1 that I previously had. My X-E1 also doesn’t correct it, but I expected that, as I believe (perhaps incorrectly) that the E1 doesn’t have the LMO whereas the E2 does—though perhaps I’ve misunderstood the scope of the LMO.
There seem to be no relevant firmware updates to either the E2 or the lens, so it would appear that there’s no way round this. Obviously, it’s not a big deal for rural shots but it is for urban ones.
Is anyone using the 16/2.8 on an X-Trans II body without seeing the barrel distortion?
(I know one solution is “swap the 16 for the 14” but I’ve tried two copies of that lens and not had much luck: one seemed to have unreliable AF while the other had a faulty aperture ring, so I’m not convinced by the build quality—and in any case I like the compact size, fast AF and—on other bodies—weather resistance of the 16.)
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
Fujifilm X-E2 Fujifilm XF 16mm F2.8
FTOG Senior Member • Posts: 1,359
Re: The 16mm f/2.8 on the X-E2
You're probably correct in assuming this is due to a lack of firmware support for the earlier generations.
If you're shooting RAW, you might be able to apply a lens correction profile to at least correct lens distortion in your final image. Unfortunately, this won't do anything to the distortion displayed during composition and capture.
 FTOG's gear list:FTOG's gear list
Fujifilm X-E3 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR +2 more
OP Jeff Biscuits Senior Member • Posts: 1,166
Indeed (and the lack of correction in the viewfinder isn’t a major issue), I’m just trying to minimise workflow these days. One of the things I really like about Fujifilm (having come from mainly Ricoh) is the quality of JPEGs so I’m seizing the opportunity to do as little as possible in Lightroom 🙂
Rod McD Veteran Member • Posts: 8,589
Hi Jeff,
I just put my 16/2.8 on my old XT1, and it looked quite rectilinear through the EVF..... I lined up interior building details - walls and cupboards, etc.  No problem.  I can't explain why your lens might not have looked rectilinear on your XT1.
Regards, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
Interesting. Thanks. Now I look again at the X-T1 shots there’s also a lot of softness/CA in the edges and corners, but again this is (impressively) well-corrected on the T2. I’ve also used it on my A5, but that’s infrared so hard to draw robust conclusions from—but that certainly seems much better than the T1, if maybe just a little shy of the T2. Hmm…
