Unremovable white spots on EOS R viewfinder
Started Jan 1, 2022 | Discussions
NickMDal New Member • Posts: 10
Hi. This EOS R is only 7 months old. I cannot remove these spots at all with a clean magicfiber and a little breath.
They remind me of coating wear-spots on an old Nikon binoc eyepiece. Is this worn away glare coating? I really baby this camera so what on earth?
The pic is blurry because it was taken through a cheap desktop magnifier, the only way I could isolate them. Thanks much!
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
Re: Unremovable white spots on EOS R viewfinder
It's really too blurry to tell. Could be dust specs on the inside, fungus, salt deposits (e.g. from sea spray).
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
CameraCarl Veteran Member • Posts: 9,193
Have you tried cleaning it with something like a Zeiss wipe? At 7 months old, it should still be under warranty. You might consider asking Canon to take a look at it.
Phylloxera Regular Member • Posts: 256
My viewfinder looks worse  but if it bothers you try an old household remedy: corona free saliva and a toothpick. No joke!
 Phylloxera's gear list:Phylloxera's gear list
PTGui Pro
OP NickMDal New Member • Posts: 10
Mr Phylloxera, you are my hero!  Toothpick and saliva (I brushed my teeth first!) WORKED
It just gently broke up whatever had built up. Then back with the magic fiber cloth to clean up the debris and the viewfinder is like new!  All spots are gone!
Thank you my friend!
