Dan W
Re: R6: Closing Touchscreen moves focus box to top left
CoolHandLu wrote:
Just received my first Canon camera today - the R6. This camera is amazing - LOVE how it feels in my hand and I'm excited to learn how to use it. However it seems I've discovered a mfg defect in my particular copy that's driving me crazy: if I close the display monitor shut (display side closed, against the body) with ANYTHING other than a very gentle push, the focus point shifts to the upper left (sometimes bottom left) of the screen. The only fix is to disable touch control. Then my focus point stays put (i.e. wherever I last left it).
This isn't an issue of my finger or nose accidentally touching the screen. I've set my focus point where I want them (I've enabled "orientation linked AF point" so I have 2 focus points - one for landscape and one for portrait orientation). But if I open out the display monitor and then shut it, 25% of the time the focus point will shift to top (sometimes bottom) left of screen. Unless I'm VERY gentle with the shutting motion (ridiculously so).
I don't want to return this camera - I just got it! If I return it, it will be for an exchange - this behavior has to be an anomaly. I don't think I want to give up the excellent touch control features - which is the only fix. Unless something's going on that I can't figure out, I am thinking an exchange is in order.
Any thoughts?
Thanks!
Brian
I believe you can adjust the sensitivity of the touch if I'm not mistaken. But really, I have my joystick on the R5 setup if I push on it it resets focus point to the center. I use eye focus servo with back button focus. I rarely use the LCD to touch focus, maybe if I'm shooting really low and don't want to lay on the ground. I usually don't flip the screen either, haven't had an issue yet with scratches. I think they have a glass protector on the LCD from factory.
Anyhow, charge up the battery, sit in your favorite chair plan on a few hours and go through every menu screen there is. If you're not sure what something is or does, stop and look it up in the manual. These things are so customizable it's getting insane. But most of the menu options are set it and forget it. The items that I may change like human vs animal eye focus, card formatting, battery health, bracketing, etc I put in my custom menu. My shoe mount flash or my trigger for studio strobes I set to my M-Fn button so its a quick push to get into my flash/trigger menu on the back of the camera to set HSS or first curtain sync to TTL/Man, FEC, etc.
Dont get discouraged yet, it's a lot to learn but once you get things figured out and customized to your style, you will have a hard time wiping the smile off your face while out shooting with it. The R6 is a solid camera.
