Pinhole, Zone Plate, Zone Sieve
Started Dec 29, 2021 | Discussions
3dpan
3dpan Contributing Member • Posts: 734
Has anyone else tried 3-D pinhole photography ?
Example below is not a true pinhole, actually a zone plate.
view X-eye
 3dpan's gear list:3dpan's gear list
Olympus E-M5 II Olympus E-M1 III Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro +9 more
3D Gunner Senior Member • Posts: 1,031
Re: Pinhole, Zone Plate, Zone Sieve
Very interesting result! 👏👍
3dpan
OP 3dpan Contributing Member • Posts: 734
Thanks, I find it a real challenge to get an interesting photo using the zone plate/sieve.
Their primary feature is putting a halo around highlights.
Can even get a fascinating portrait with them.
Stereo adds another dimension to the image.
Putting a halo around the highlights is used as an artistic effect.
This effect is also very interesting for stereoscopic photography.
What is your opinion about image quality at large sizes?
3dpan
I wouldn't know how to measure image quality for pinhole zone plate/sieve.
I suppose you could look at the "graininess" of the halo.
I refer to a subjective assessment. For example, I am curious how the image presented looks at 2000 pixels per frame width (i.e. 4000 pixels per image pair width).
3dpan
I've never projected my images on a big screen. Can't answer from experience.
I presume factors such as viewing distance would come into effect there.
Otherwise, just viewing on a computer screen, you could set the ppi to suit when processing the image.
The image I showed above is reduced/compressed for emailing.
I would have to go back to my archives to find the original frames to process a high res version.
Because of the high level of "halo", the image looks good scaled to a much larger size and seen full screen.
From which it can be deduced that the original image looks even better.
I also achieved a similar effect by applying a complex processing in Photoshop.
KudzuLite New Member • Posts: 13
I use zone plates for 3D routinely. Don't see it much different from regular lenses. Here are a couple of quick shots for parallel viewing:
 KudzuLite's gear list:KudzuLite's gear list
Samsung Galaxy S9+
