MH-100 Wimberley MonoGimbal Head with Oly 100-400
Started Dec 27, 2021 | Discussions
Tom899 Senior Member • Posts: 1,241
Has anyone used a MH-100 Wimberley MonoGimbal Head on a monopod with their Oly 100-400?
I'm thinking about getting the MH-100, but my question is: Should I also order the Wimberley P-30 Lens Plate for proper balancing? Or, will the 100-400 on my EM1-Mk III balance fine without the plate?
I know I could just order the MH-100 and try it out, but thought if anyone has this setup it might save me having to order twice.
Thanks,
-Tom
 Tom899's gear list:Tom899's gear list
OM-1 Sony RX100 VII Panasonic Lumix G Fisheye 8mm F3.5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +18 more
Albert Valentino Veteran Member • Posts: 9,762
Re: MH-100 Wimberley MonoGimbal Head with Oly 100-400
Just my 2 cents, but I would try it first before investing in a plate since the collar has a reasonably long built-in arc-swiss foot. I have owned a few long lenses, biggest was the Sigma 120-300 f/2.8 monster, that did not have an arca-swiss plate so I needed to get one, unlike with your 100-400. I just do not see it adding any real benefit. That said, I owned a few Wimberley plates and used my longest one mounted 90 degrees on my camera body to work as a focusing rail for macro 😃
Lastly, i never used a gimbal on a monopod. I did own the Wimberley Sidekick and used that on my tripod with Nikon 80-400, Sigma 120-300 f/2.8, and Sigma 150-500. In all cases the tripod mounted sidekick was extremely useful. I have owned a monopod with a ballhead but never warmed up to it. I suspect a gimbal on a monopod will be a mixed experience. But if you have experience with a monopod and also have experience with the 100-400 alone, then you would be in a better position to judge if this combo with help with what and how you shoot.
Not sure if any of the above was helpful but can’t hurt to mention 😐
Truth never fears scrutiny.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
photoski Regular Member • Posts: 278
I've  been an Olympus user since the E1 (E3, EM1 mkI), but recently started shooting Nikon for wildlife with the D500 and 200-500.
After seeing a review of the Wimberley MH 100, I picked one up with a Benro Supadupa monopod and it is a great combo.  Able to balance no problem without adding a longer plate and the mono gimbal works like a charm.
 photoski's gear list:photoski's gear list
Olympus E-M1 Nikon D500 Panasonic Lumix DMC-LX3 Olympus E-1 Olympus E-3 +8 more
OP Tom899 Senior Member • Posts: 1,241
Thanks both of you for the information. Yes, I think I should try it without the plate first.
Appreciate,
-Tom
Skeeterbytes Forum Pro • Posts: 23,182
My $0.02 is a simple tilt head is adequate for a tele lens with collar on a monopod, such as the 100-400, 300 Pro and 150-400 Pro (I have just the prime). It makes for a simple and robust connection with the weight centered over the monopod, regardless of orientation.
Camera and lens lacking a tripod collar might call for a ballhead (or other way to flop the camera to portrait) but I only use a monopod with teles.
The Arca-Swiss grooves are a big help, making a better connection between lens and head.
I do have a gimbal head that came with a verrrry long plate to help with balancing. That I only use on a tripod, it's too ungainly for a monopod.
Good luck!
Rick
john isaacs Veteran Member • Posts: 8,440
Thanks,
Depends on your camera.  The E-M1X is a bit too heavy, and you have to get it so close to the MH-100 that your hand might not fit, especially with the lens at 100mm.  But the balance doesn't change much when zoomed to 400mm.
The E-M1.3 however, balances much better; leaves room for my hand to hold the grip.
There is very little adjustment needed to balance the 100-400 at different focal lengths because the lens is very light on the front.
You definitely don't need the lens plate.
Normally, I use the 300mm with TC on the E-M1x and the 100-400 on the E-M1.3 sans grip.
BTW, the E-M1X with 300mm with or without TC balances with proper spacing for to hold the grip.
Here's a picture of the MH-100 with a G9 and PL 100-400. Using lens/camera on the right, it appears to not be in the way of the grip?
There are many reviews, here's one I just randomly picked one.
https://www.youtube.com/watch?v=yqyqZb7-L_A
-Tom
I mount it on the other side, so I can control the zoom and focus rings with my left hand and control the camera with my right hand.  That puts the camera grip close to the mount.
Mounted as shown in this picture, I don't know how you get to the lens because the monopod is in the way.
I see what you mean, I will have to wait until I get it to try all positions. I will be using an E-M1 III
Thanks!
-Tom
Thanks!
Before you get the Wimberly, just try an Arca Ball Head on a monopod, tilt the ball head over 90 degrees, and use it like you would the Wimberly.   That will show you how it will mount and handle.
Note: if you intend to pick up the camera/lens with the monopod attached, then with the Wimberly I recommend keeping the lens tripod collar loose (but with a ball head, keep it tightened).
Thanks for the tips!
-Tom
