X100V SS dial play
Started Dec 26, 2021 | Discussions
GSharp87 Regular Member • Posts: 269
X100V SS dial play
Hello beautiful people. I’d like to ask if this amount of play is normal on the X100V shutter speed dial. To me it doesn’t feel right. I have the original X100 and on that camera there is no play whatsoever.
https://youtube.com/shorts/rDYrRPLfil8?feature=share
I’ve posted a short clip to show what I mean. Can anybody confirm if this is the same with their X100V?
Thank you!
 GSharp87's gear list:GSharp87's gear list
Ricoh GR III Fujifilm X-Pro3 Nikon Z6 II Nikon Z9 Fujifilm X-H2S +4 more
Fujifilm FinePix X100 Fujifilm X10 Leica X1
Erik Baumgartner Senior Member • Posts: 6,894
Re: X100V SS dial play
Thank you!
Mine has a tiny bit of play, but the clicks are very stiff, sharply defined and nowhere near as sloppy as what I'm seeing in your video.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP GSharp87 Regular Member • Posts: 269
Thank you!
To me, the actual clicks are pretty stiff. The problem I have is the amount of play between the clicks. Does your dial show as much play as seen in the above video?
Thank you!
No, just a tiny bit.
robnich
robnich Contributing Member • Posts: 767
My X100V has essentially no play in the shutter speed dial.
Robert N.
 robnich's gear list:robnich's gear list
Panasonic FZ1000 Fujifilm X100V Canon Pixma Pro-100
larsbc Forum Pro • Posts: 18,282
Nope...
Mine doesn't have much play at all.
Today the shutter speed dial finally gave up and fell off the camera while I was using it. Suddenly felt no resistance while turning the dial and it came off into my hand.
Took it to the retailer today who will be sending out hopefully covered under warranty. Estimating a month turn around which is a bummer.
