Playback for the Fuji W3?
Started Dec 26, 2021 | Discussions
fPrime
fPrime Veteran Member • Posts: 3,727
Contemplating getting one of these cameras and wondering how people play back the 3D images without a 3D capable HDTV.
Could the images potentially be displayed stereoscopically on a huge 4K OLED and viewed with a Stereo Wide-View Viewer for Prints and Monitors like the one shown here?
https://www.amazon.com/gp/aw/d/B07DQT8QD6/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8
I wouldn’t be keen on conversion to anaglyphs nor playback via VR headsets. Thanks!
fPrime
Half of my heart is a shotgun wedding to a bride with a paper ring,
And half of my heart is the part of a man who's never truly loved anything.
 fPrime's gear list:fPrime's gear list
Canon EOS 5D Fujifilm FinePix S5 Pro Leica M8 Nikon D60 Nikon D1X +3 more
3D Gunner Senior Member • Posts: 1,031
Re: Playback for the Fuji W3?
fPrime
Yes, if you can find that device somewhere.
Brian F Flint
Brian F Flint Regular Member • Posts: 184
I have been thinking of viewing parallel side by side movie clips on a large TV screen. This is a normal 2d not 3d TV., and this  is with the images not squashed.
These glasses are available from here
http://www.3dstereo.com/viewmaster/pvn-swv.html
I don't have any , but would be interested in the quality of the image you get.
I have designed my own glasses. It uses a couple of small mirrors and I would place the 'rig' over one eye only. I just need to find the time to go into my garage and cut up some pieces of wood to make it. I have some mirrors which are suitable for the job.
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
I made a similar device a very long time ago.
For good quality you need "first surface mirrors".
The annoying problem is that the position of the head has to be unchanged during the viewing of the 3D material (after the optimal overlapping of the two images has been achieved).
Also, the geometric distortion of the image displaced by the mirrors is very pronounced.
fPrime
OP fPrime Veteran Member • Posts: 3,727
Thanks, all, for the confirmation of concept and links. I do understand that stereoscopic glasses like these would be a visual compromise compared to viewing on a true 3D HDTV, but at least the 3D images could be viewed on a larger TV without the color distortion that anaglyphs involve.
The irony here is that I actually used to own one of LG’s early 3D OLED HDTV’s but it had to be sent back due to an internal mask misalignment that showed up as a slightly yellowed blotch on the screen whenever an all-white image was displayed. I think the difficulty LG had in producing 3D screens without these sorts of defects helped to ultimately doom the 3D wave.
fPrime
This solution is not recommended, except for a little fun.
A good solution can be AR glasses . Some interesting models are announced for 2022.
Oleg L K Regular Member • Posts: 293
The closest to 3DTV off-the-shelf solution is a projector with "active" shutter-glasses.
Even 720p models give great picture in 3d mode - because it's actually 2x720p, thus the total resolution equals to that of full-HD.
fPrime
Thanks for the additional suggestions with regards to VR Glasses and Projectors.
One other question occurred to me… how are W3 images best processed? For example does the camera output a RAW file that can be converted in Lightroom or would I be limited to developing the image through Fuji’s legacy software package?
fPrime
I recommend you try using a video projector as a 3D PC monitor, then we'll talk.
I own a 3D VR system with a smartphone, a passive 4K 3D TV and a 4K 3D projector...
The simplest and most preferable 3D system with video projectors is the passive one with 2 projectors and glasses with interference filters. But it's an expensive formula.
My new investment will be in a VR/AR system with smart glasses with high resolution screens and wide FOV.
Chu123 New Member • Posts: 5
fPrime
The best solution is using the amazing and free Stereo Photo Maker software:
https://stereo.jpn.org/eng/stphmkr/
It can open the .MPO files from the camera directly if desired.
For more processing options, my workflow is to batch split the .MPO files to Left and Right images and import into Photoshop Lightroom.
From there, I do a bit of noise reduction since the Fuji W3D is noisy.
(You could also use the enhance function in Lightroom and up-res the photos, but that is hit or miss).
Once the pairs are edited..... export the pair and then use SPM to create your choice of output.
 Chu123's gear list:Chu123's gear list
Panasonic LX100 Canon EOS 5D Mark II Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
fPrime
fPrime
Thanks for sharing your W3 workflow, Chu123.
This seems to confirm the other commentary I've seen online that the .MPO file basically contains two JPEG's and that there is no true RAW file for the W3 for Lightroom to demosaic.
So, while the W3 JPEG's can be enhanced and edited, they will essentially be 8-bit files with all the limitations we know that JPEG's have. If I have any of this incorrect, let me know.
fPrime
Yes, the camera provides you with a pair of jpg images that do not need to be separated. From SPM you can save them in a single file (Full SBS for example), preferably in an uncompressed/losless format (TIFF, BMP), which you can later clean and enhance in Lightroom or other software.
fPrime
Got it, thanks.
If I may ask, what model passive 4K 3D TV do you have that you currently use for playback? Maybe the used market has some to offer…
fPrime
I have an LG 55UB850V, but being an old model it is completely irrelevant.
It has worked as a PC monitor for more than 32000 hours.
fPrime
That’s a lot of PC time!
Thanks for the tips.
fPrime
fPrime
The Fujifilm W3 3D is a fun little camera for quick captures that require perfect sync of moving subjects. But it is horrible in low light and the quality of the images is only so-so.
You can shoot superior quality 3d photos with your iPhone and the i3DSteroid app .
For the price the Fujifilm W3 are commanding on eBay, I would consider looking for a pair of point and shoots and mounting it on a twin stereo bar.
It would be hard to get perfect sync for fast moving subjects with both hands pressing the shutters. The stereo base is wider then "normal" human eyes-- but the image quality is superior. (You could flip one camera upside down.. but that's a mounting/rigging challenge).
One could even consider a Lenovo Mirage Camera which were selling for less than a hundred bucks. It's a VR180 camera, but it does VR180 photos. You can use Google cardboard to view the photos.
StereoPhotoMaker can work with the files from the Lenovo, but only with the full fish eye look.
Anyway.. my thoughts.
fPrime
fPrime
Thanks, Chu123, for the suggestion above. I actually already have one Nikon J1 already and adding another likely wouldn't cost more than $150. Honestly, getting images this way would have a tremendous advantage since I could edit the Nikon 1 RAW's instead of the W3's JPEG's. What's the model of twin stereo bar that you chose for your setup?
fPrime
There are several solutions. This for example is a very solid solution with many advantages: PU-200 200mm Universal Quick Release Plate
Or: PU-300 300mm
fPrime
Or: PU-300 300mm
Thanks for the recommendations!
fPrime
fPrime
Heck, seeing your gear list... you could get a second Canon 5D and get 2 sets of wireless remotes?  I believe one remote can trigger both the cameras.   That would be awesome.
