How To Add a Generic Slotted Filter Holder To Your Holga Toy Camera (or Any Other Camera)
Started Dec 21, 2021 | Discussions
BR0KENLAND
BR0KENLAND Forum Member • Posts: 56
Ever since the discovery of my experimental Polarizing/UV/ND filter, Which has been working very well on my Canon M6, I've wanted to mount the slotted filter holder onto my Holga 120N camera. Then realized that I had extra lens rings that came with my Ranger filter adapter kit as purchased from Amazon. test fitting the 52mm lens ring onto the front of the Holga 120N camera, I then mounted the ring into the slotted filter holder.
At first this setup worked very well. But over time the slotted filter (with filter attached) kept falling off the Holga lens. Thinking quick, I located a small piece of tin foil and bend/formed it over the inner edge of the lens ring. Then remounted or press fit the lens ring with slotted filter holder back onto the camera. Although the lens ring is threaded, the Holga lens is not but again the 52mm lens ring will fit/press fit securely over the outer edge of the Holga lens. So just in case you want to test or continue to use your 85mm x 100mm etc filters on your Holga camera, you now have an alterative.
Even after adding the filter, I have yet to notice any major difference with how the film looks. but I'll still keep the slotted filter adapter on the camera anyway at all times.
 BR0KENLAND's gear list:BR0KENLAND's gear list
Holga 120N Medium Format Plastic Camera
