Olympus E-M1 II review: flawed gem
Started Dec 21, 2021 | User reviews
JimH123 Veteran Member • Posts: 3,886
Re: My Olympus E-M1ii FW is at V3.1
Aberaeron wrote:
This makes me think that the problem you are experience started first in V3.2 where they played around with the EVF Auto Switch ???
And it makes me hesitant to do a FW update at this time.
You do not need to update sequentially. Just update directly to the latest version V3.5. It is a complete operating system install and incorporates all previous improvements. Works perfectly on my camera and I suspect on all others. You do need the Olympus Workspace app to update this camera’s firmware.
I went to the Olympus Workspace and was able to see V3.5 available for the EM1ii.  But I still wonder about the problem Henry Richardson is reporting.  Haven't gotten the courage to dive in yet.
 JimH123's gear list:JimH123's gear list
Nikon Coolpix P1000 Sony RX100 VII Olympus E-M5 II Sony a6300 Olympus E-M1 II +2 more
Harold66
Harold66 Forum Pro • Posts: 12,002
Re: good external controls
Cafe Racer wrote:
I set mine up so that when the rear lever is set to 1 then I get the default behavior where pressing the shutter button also performs AF. When it is set to 2 though I have mine set to use back-button AF using the button inside the lever control. In addition, what that means is that switching to 2 means I also instantly switch to MF with focus peaking. Although I mostly use 1 it is very nice to sometimes very easily be able to change to 2.
The many external controls are nice to have so it means less often needing to use the SCP for some changes. And, of course, the buttons and controls are larger and easier to use than on the smaller models.
For the last 5 years I have seen many posts from people expressing disappointment in the E-M1 II EVF, but no one investigated and went into detail like I did about what was wrong and narrowed it down like I did. Certainly the EVF is still very usable and the camera has many other great things going for it, but that just makes this Olympus blunder even more annoying.
Some reviews mention the EVF being low contrast and other things too. None of them really looked into it though and just assumed that the E-M1 II EVF was just not quite up to some of the others. But, until I decided to delve into it, no one seems to have investigated what the issue was.
Whilst I'm not familiar with the issue you have it reminded me of the issue I saw with Panasonic G9 EVF. It wasn't mentioned in reviews and I hadn't heard it mentioned on this forum but in all the copies I tried the EVF had excessively warped borders.
I would not call it excessive. I think your excessively is excessive  but in any case , it is solved immediately by choosing the lower magnification on the EVF
so not really an issue
Harold
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
Aberaeron Forum Pro • Posts: 10,184
It seems obvious from your two posts that you, like the overwhelming majority of users of this camera model, do not have the issue that Henry Richardson assumes to be fairly, if not totally universal. He does not mention that it happened after any particular update as far as I can see.
He has an issue either with his particular camera or, probably more likely in my opinion, has some user setting that inhibits his EVF from reflecting the true exposure that might result. The EVF has many customisations that are possible. The main  ‘Live view Boost’ should be set to off. There are separate auto luminance settings if I remember correctly and also EV compensation and colour temperature. I almost never have auto illuminance switched on and have the ‘EV Adjust’ set for -1 exposure value [this is exclusively for the EVF view not for a resultant recorded picture] and +1 EVF colour temperature. Also have ’S-OVF’ set to off.
Another possible setting maladjustment could be ‘LV Close Up Mode’ or more specifically the item beneath it which is another Live View Boost setting which is best set to off.
There is yet another option at the bottom of D2 under ‘Settings’ , which is yet another ‘Live view Boost’ option I set to off.
Cafe Racer Senior Member • Posts: 2,137
Re: Pincushioning EVF
Trolleyman wrote:
Cafe Racer wrote:
Whilst I'm not familiar with the issue you have it reminded me of the issue I saw with Panasonic G9 EVF. It wasn't mentioned in reviews and I hadn't heard it mentioned on this forum but in all the copies I tried the EVF had excessively warped borders. I felt this was unacceptable for a flagship camera so I can understand your frustration, particularly if the viewfinder is an important aspect of the camera for you. I hope you can resolve it.
I thought the G9 pincushion effect in the evf was very well documented.
It is now, but wasn't at the time. I think I may have been the first one to mention it on this forum.
Mine has it to a certain degree, but again like the E-m1 ii its fine for composition purposes
 Cafe Racer's gear list:Cafe Racer's gear list
Olympus PEN E-P1 Olympus PEN E-P5 Panasonic G85 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II Olympus M.Zuiko Digital 45mm F1.8 +4 more
The ones I tried I consider to be excessive to the extent that it was the first thing I noticed when I put the camera to my eye, and I had never heard of the issue at the time. It looked more pronounced when switched to the lower magnification.
Harold
OK, it is done.  I updated to V3.5 from V3.1.  Camera seems fine.  All my settings were retained.  I cannot tell any difference in the EVF and the LCD.
You will probably find lots of improved and new features after that jump in firmware versions.  It will take time for you to find them all unless you actively research the improvements.
Enjoy!
Harold66
That does NOT make any sense . how could that be ?
how long did you have the G9 ?
H
www.haroldglit.com
Well, that's how it appeared to me.
I didn't buy the G9 because I didn't like the viewfinder.
H
www.haroldglit.com
OP Henry Richardson Forum Pro • Posts: 21,959
Pork: Kosher, Halal
5
This user resorted to turning off Auto Luminance in order to get an EVF view that he found acceptable:
https://www.dpreview.com/forums/post/65669711
I am glad that he could find something that works for him.
If you read my 3 posts that I linked to in my review above you will see that for 2 months I have gone back and forth with Auto Luminance on and off. Neither one is really ideal and works well in all general photo taking conditions. When one is better the other may not be and vice versa. It seems to depend on lighting, subject, mix of light and dark, etc. that probably causes the Auto Luminance algorithm to make EVF adjustments. My PEN-F, E-M10 II, E-M10, and E-M5 do not have this unfortunate behavior. Over the years there have been many vague comments by users on this forum and other forums and also sometimes in reviews about how the E-M1 II EVF is not quite as good as some other Olympus bodies (not talking about size or resolution) (using probably all versions of the firmware). Usually things are said such as sort of washed out, low contrast, etc. No more detail or better description. No one bothered to look into it until I did. And I gave a much better description. Auto Luminance is dynamic so it is difficult to give a pat description because it changes its behavior depending on what the camera sees. I bet most people didn't even know there is an Auto Luminance and it is turned ON by default. Most never tried turning it off and experimenting. Probably no one had until me.
Sure, fan boys will always get their panties in a twist and be triggered. Some will foam at the mouth and be outraged. I generally ignore them. You will note that it is rare for them to write a review or provide much of any use to the forum community. Most are just takers, not givers. Some (many?) are neurotic, mentally ill so it is best to not engage with them.
Never wrestle with a pig. You just get dirty and the pig enjoys it.
As you will see in the 3 posts I linked to, I said this was not a major problem and the camera is still very usable. And great in pretty much every other way. I hold the flagship to a higher standard though. It was US$2000 when it came out so much more expensive than the other models. The EVF should be at least as good as my E-M10, E-M10 II, and PEN-F. I am convinced this is a firmware problem with Auto Luminance. It just doesn't behave well all the time. Sometimes it does. It is a dynamic thing. It is as if they didn't tune it properly for the EVF panel, but did for the lower level cameras.
If you don't see in your EVF what I have delved into or are not bothered by it then just be content.
Henry Richardson
http://www.bakubo.com
Harold66
I see , so you made up your mind in a few minutes in a store , is that it ?
Harold
www.haroldglit.com
No that's not it. I don't buy a camera based on handling it for a few minutes. I tried the G9 in 3 different camera shops on separate occasions in order to determine if it was an isolated issue. All 3 cameras I tried exhibited the same EVF issue.
Re: Pork: Kosher, Halal
The whole point of the auto-illuminance setting is to raise the brightness of the viewing experience above that which the exposure will be. It is for use in studio conditions for convenience. No idea why Olympus have it switched on by default from the factory but it should be off normally unless the photographer finds the feature useful. If you wish for the viewfinder and rear screen to be WYSIWYG then you set it to be so, as I have explained in detail. Otherwise do what you wish but do not blame the tool for your inappropriate settings. There is a slight possibility that your camera is faulty of course and I would rule nothing out.
If you want WYSIWYG, as most probably do most of the time, go through your setting in the first instance and set them as I suggest in the link you provide elsewhere, at the bottom of the topic string.
https://www.dpreview.com/forums/post/65667502
I have zero interest in being a “triggered”. Olympus is only one of many brands of cameras that I use. I’m telling you as it is. Your issue is either a problem with your camera or an issue with your particular camera settings which may possibly be shared by a small number of other users. Or maybe not. Your assumption [bet] that very few people, apart from you, know about ‘auto-illuminance’ is bordering on arrogance.
That you have invested your energy into making this [rather misleading?] review obviously makes you invested in it and you cannot entertain that you might have missed something, probably in the two categories I mentioned. You seem to have overly invested your pride in this subject.
Believe me, if this was an issue on my unit I would have no hesitation confirming your issue with it. It is not something I am emotionally invested in and the monetary investment is bordering on the trivial in my scheme of things where some of my camera bodies cost literally ten times what this one did. However it is categorically NOT an issue with my camera and I’ve actually posted photographic evidence that confirms this fact.
That you resort to the part you isolate in a paragraph in bold shows absolutely who is actually triggered and the pig in this instance. Be told that your issue is not universal and may be very rare and dependent on camera settings or fault.
Harold66
Ok then
Harold
www.haroldglit.com
Martin.au
Martin.au Forum Pro • Posts: 14,339
Re: Olympus E-M1 II review: flawed gem
I've seen some of these threads bouncing around for a while, but never bothered to check what mine was set to. My E-M1 II is set to Auto illuminance on, and doesn't display the over-brightened effect described. Both the LCD and EVF look pretty similar.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Today: Big rig and only using rear screen
5
The E-M1 II is as good or better in almost every way compared to my other Olympus bodies. It is a pleasure to use except for the poor EVF. If you can live with an EVF that is in some real day-to-day usage ways that is not as good as the E-M10 II, etc. EVFs and you don't mind or want a bigger/heavier/weather-sealed body then this is a good one to get.
For people who always use the rear screen and not the EVF then the E-M1 II is great, I suspect. I almost always use the EVF though so it is just an educated guess that using the rear screen will work just fine, like it does for most cameras.
I have seen youtube video reviews, etc. with people using FF mirrorless cameras with a 70-200mm f2.8 and other lenses holding the camera out in front of them using the rear screen rather than the EVF so it seems lots of people just don't use a viewfinder these days.
I suppose in m4/3 land some people may use the E-M1X + 150-400mm f4.5 and hold it out in front of them and compose using the rear screen.
This may be a clue why Olympus felt having a really good, well working EVF is not a priority anymore. At least for the flagship camera. The lower level cameras have good, well working EVFs.
This morning I saw a young man, maybe about 25, with what appeared to be a Fuji X-T4 + big lens + big lens hood. I am pretty sure it was the Fuji 50-140mm f2.8.  He was with a very attractive young woman, about 21, wearing a kimono and it appeared she was his girlfriend. It is o-shogatsu (New Year) time so not unusual. He was taking photos of her, sometimes directing her to turn one way or the other, etc. I watched for a few minutes and he never once used the viewfinder on his rather big rig. He held the camera and big lens out in front of him like a smartphone and took a bunch of photos that way. Nothing wrong with that. It is what he and many people prefer these days. For them an EVF is just an annoyance and an unneeded, unused extra expense and adds that unattractive hump. But actually, the hump may be part of the charm since it makes the camera look more like a traditional SLR camera even if it is just a bit of decoration for many people now.
Henry Richardson
Re: Today: Big rig and only using rear screen
So much harder to hold a camera with a big lens steady out in front of you rather than using the EVF which in turn uses your head as a anchor point to hold it steadier. I wonder if his results turned out as good as he had hoped for?
But you are right. When I see the tourist spots, the majority hold the camera way out in front and use the LCD. Those not doing that use the long camera sticks that hold the camera (usually cell phone) way out in front so they can take pictures of themself standing in front of something interesting. On a trip to Shanghai, my very last business trip before retiring, almost every young person was doing this.
And we wonder why camera sales are down?
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Although I use the viewfinder 99% of the time, if critical framing is important I prefer the rear LCD (only with short wide lenses though!).
I am not sure why, but for me viewfinders do not create a 'frame' in the same way which the rear screen achieves so easily.
Could it be because they are trying to achieve viewfinders which are effectively an extension of the eye.
With a viewfinder I need to scan the picture to Frame it. Not so with the rear screen.
What do others think ?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
I have no problem framing the picture when using the EVF and see no advantage to using the LCD.  But I will use the LCD if the camera is in a place that makes using the EVF hard to do.
OM-1 reviewer: washed out E-M1 II, E-M1 III, E-M1X EVF
5
Here is a nice OM-1 review by someone who owns the E-M1 II, E-M1 III, and E-M1X. He really likes the OM-1 EVF:
https://www.oxbowphoto.com/articles/om-systems-om-1-for-wildlife-first-impressions-review
He writes this:
As for the new EVF - I’m in love. After looking through the EVF on the OM-1, it’s hard to imagine ever going back to the washed-out 2.3 MP panel on the E-M1 X or III. The previous EVF was not horrible by 2014 standards, but having seen multiple generations of flagship camera, it was clearly time for an upgrade. I can’t overemphasize how drastic an improvement it is being able to accurately judge focus, exposure, and to review photographs with the new screen. To me, this was one of the biggest reasons to upgrade. OM needed to ace the EVF with their new camera - and they did. Finally, an Olympus camera with a great EVF. That’s enough WOW for me!
I don't know what he means when he says "washed out", but I suspect a lot of it has to do with my much more careful, descriptive dislike after lots of investigation that I wrote about in this thread.  Stuff such as this:
There is a problem with the E-M1 II EVF firmware that doesn't exist in any of my other Olympus bodies. The problem with the E-M1 II is not the EVF hardware (which is quite good), it is a bug/deficiency in the firmware that doesn't exist in the PEN-F (OLED), E-M10 II (OLED), E-M10 (TFT LCD), etc. Since the last firmware is 3.5 and the E-M1 II is no longer a current flagship model it is very unlikely that OMDS will fix this bug. Specifically the Auto Luminance setting is broken in this model. I dug into the problem and wrote about it in detail in the following 3 posts. You need to read them to understand what is wrong with the E-M1 II firmware and what the ramifications are:
https://www.dpreview.com/forums/post/65721962
https://www.dpreview.com/forums/post/65730373
Henry Richardson
