alcelc
Re: Another drowned camera query
kiwigirl wrote:
Apologies for another one of these threads! Long story short - very thoroughly submerged G7 on a hike. Wasn't able to open the camera up for drying till several hours later. Was switched off and in a pouch at time.
Have read to be cautious about battery.....?? It is in the charger and appears to be charging fine. My question is - would it be safe to put into my G85? I have one critical camera so don't want to risk any damage to my G85!
The G7 will be left to dry out for a while yet but probably past its use-by date
In 2012 the G1 and 7-14 f/4 fell into a river (I slipped on the wet muddy floor on boarding a small boat) during a trip. They were picked up by sailors around me within a split second but it came out like a water tank.
Fortunately G1 was powered off during the accident so no circuit shortage.
Took out the battery immediately, drain all of the water inside and dry it with every paper tissue, handkerchief, dry clothes I could find.
That battery had been out of the camera for a few days, put it back to the camera while I believe it had been completely dried. Nothing bad happened. But IIRC I replaced it very soon after returned home for safety. It was a generic battery and so the cost is small. In your case, I might not reuse it, just for a peace of mind.
My wet gear were dried, the one day 0 and day 1 after the accident, they refused to power up. On day 2, G1 can be powered up but a dead LCD and basically not working. During all of the time I got an idea from nowhere to use the hairdryer supplied by the the cruise to blow dry the gear whenever I was in my cabinet. When I was out, I put the wet gears inside a drawer on top of the mini fridge, surrounded the drawer tight by towels to create a warm storage hoping can dry my gear. On Day 3, G1 came back to life again. So was the 7-14. I could shoot with it for the last few days of my trip.
Back home, sent it to Service Center but after inspection, I was told to let it be since it could die anytime.
G1 had been used as my major camera for 2 more years, then retired. But it works well, except for a few rare crashing, until now. 7-14 is still one of my major lenses today.
I had repeated here many times. Moisture corrode electronics, similar to cancer it kills electronic product immediately, or soon or later. Time becomes the essence and the shorter time we let electronic component exposing to moisture, the damage could be smaller.
My only suggestion is to dry the gear as fast as possible. Any possible ACTIVE/DIRECT means of drying (like apply heat, but please not overdoing it like some suggestions to heat a camera in an oven, etc) should be the first front line of action. A low RH storage would be the long time life keeping plan.
Passive/indirect means like let the gear to dry naturally by itself might not be a good idea unless the gear would be kept in an extremely dry environment which can do the natural drying very quickly. Rice is always a bad idea to me because not only it does the job slowly, rice rots after absorbing moisture pretty fast which might cause damage more than good. Silica gel could be safer to use for a more effective result but still on a relative slow processing. IMHO these are safe keeping measures but not for ER.
My 2 cents.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
