First shots with my "new" SD1 Merrill
Started Dec 18, 2021 | Discussions
spiffariffic
spiffariffic Regular Member • Posts: 137
6
Thanks so much to Scott for selling me his SD1M when he was done with his epic roadtrip!
It's quite an adjustment to lack liveview… feels like I'm back in the 90s (but in a good way).
I don't have any Sigma lenses yet, so I'm adapting my Nikon lenses with an AI-PK mount. Not ideal, I know.
The Nikon 55mm macro delivers:
no color aberration outdoors… such detail!
think there's some lateral (top to bottom) chromatic aberration here but the sharpness and detail makes me HAPPY
For funsies, I popped on this whacky single-element 1980s soft focus lens I grabbed off eBay because I want to explore pictorialist style landscapes:
it has major purple shift in the corners so I converted to B&W — but then again, it is a single element lens in a plastic tube sooo nbd, just adds to the antique look
I famously did not get along with the SDQ and the 30mm Art lens. But I LOVE the SD1 Merrill so far. I've enjoyed borrowing my husband's Nikon D750 but there's nothing quite like a Foveon file, zooming in to 200% - 300% and it still looks amazing.
On adapted lenses and fixing color shifts…
My husband's deep into astrophotography and uses "flat frames" to remove color distortion from his photographs. You take the lens, at the aperture setting you're going to use, and cover it up with a white material that allows in light like plastic or cotton. Then you take a photo. That captures the purple or green distortions. Then, in Photoshop or other tools, you "subtract" that white frame from your photograph, resulting in corrected color.
Has anyone tried this?
Sigma SD1 Merrill
atom14
atom14 Veteran Member • Posts: 3,301
Re: First shots with my "new" SD1 Merrill
Congratulations to you, and I'm sure Scotty is missing it (though I reckon he's got a spare snaffled away )
Yes!
So far so good. It's the IQ you want to maintain.
It's "pretty" de rigueur in the Astrophotography forum.
atom14.
spiffariffic
OP spiffariffic Regular Member • Posts: 137
Yes!
It really is warm & nostalgic. And I was worried about it actually… my #1 concern.
Indeed!
I forgot to add the most important part of the question: has anyone tried this on the SD1M to eliminate the color distortions from adapting lenses?
quma
quma Forum Member • Posts: 67
spiffariffic wrote:
Yes!
Indeed!
It works, but is rather troublesome as the color shift also depends on the aperture.
I would go for Sigma (SA) lenses, many of which are now available at reasonable prices on ebay.
 quma's gear list:quma's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Canon EOS R +9 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
spiffariffic,
Well done with your "new" SD1M.
Can you say what AI to PK converter you are using  for the Nikon lens on the SD1M. Does it have a correction lens for Infinity focus in it and can you remove that correction lens for greater macro work. I have an M & F adapter, it works but I think the correction lens could be better. It tends to produce images brighter in the centre depending on the lens & circumstances. It is good with my 55mm f2.8 micro though.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
Scottelly
Scottelly Forum Pro • Posts: 18,028
5
spiffariffic wrote:
Yes!
Indeed!
I never have, but it seems like an easy way to do it, compared to the processes I've read about. I guess the white balance setting and lighting used to make each shot would influence the color, so I'm guessing it might be a bit more difficult than one might first think. I also wonder if the color distortions change with focus changes. I never bothered to try editing away the color distortions. I was never really affected much by them. I only shot a little with my adapted lenses though. Here is my best shot with an adapted lens:
Shot with Asahi 55mm f1.8 on SD Quattro H
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Yes!
Is that "subtract" as in a layers' blend mode i.e. put the white frame layer over the scene layer and set the white frame layer mode to 'Subtract'?
For example, going to extremes with green:
Lowering the brightness on the green layer adjusted the amount of green removed ...
It's all in the numbers ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
spiffariffic
Ceistinne wrote:
spiffariffic,
S
Happy to share. This is the one I bought (eBay).
Yes it's one with a corrective lens. There is definitely an effect on image quality, the more photos I took, I started to notice some softness and highlight blooming. It's not bad at all… in the close-up images. But the further away the focused object, the worse it got.
No, the corrective lens doesn't seem to be removable. I've ordered one without the lens for macro work. I have a Nikon F bellows system and multiple macro lenses, so it's well worth it to me and a win in my book. We shall see if that produces color casts…
D Cox Forum Pro • Posts: 32,979
spiffariffic wrote:
Ceistinne wrote:
spiffariffic,
S
I have one of those adapters, and the big Nikon PB4 bellows. It works very well, particularly with enlarger lenses.
A cheaper (and lighter) alternative would be an M42 bellows with a K mount adapter glued to it. Again, enlarger lenses are the easiest to use.
Don
Sigma fp
Ceistinne
spiffariffic wrote:
Ceistinne wrote:
spiffariffic,
S
spiffariffic,
Thank you. That is similar to the one I have, but I believe there is one that the correction lens can be removed from as required but I could not find it anywhere.
The ones we have are, as you say, good close up but less so for further away scenes.
For macro I might get another one and grind it out to convert it to an extension ring.
S
