Card Reader for iPhone
Started Dec 18, 2021 | Discussions
Elliern Senior Member • Posts: 1,737
I need an XQD card reader compatible with my iPhone 12 Pro and my iPad; both with lightning connector.  Do any of you have one that works with the D500?  My camera will now be delivered tomorrow 12/19 and I forgot to order a card reader.  I have googled them but reviews are mixed.
Ellie
Enjoy the Moments!
“What day is it?” asked Pooh.
“It’s today,” squeaked Piglet.
“My favorite day,” said Pooh.
A.A. Milne
 Elliern's gear list:Elliern's gear list
Canon PowerShot SX50 HS Nikon Coolpix P610 Nikon D5100 Sony a6000 Nikon D5500
Nikon D5 Nikon D500
Sagittarius Veteran Member • Posts: 9,104
Re: Card Reader for iPhone
What you probably need is USB to iphone adapter, something like this
https://www.amazon.com/s?k=usb+to+iphone+adapter&crid=1L9IFMQU3FQ38&sprefix=usb+to+iphone+adapter%2Caps%2C108&ref=nb_sb_ss_ts-doa-p_1_21
You can use regular usb card reader with it. I use one for android and it works like a charm.
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon Z6 II Nikon Z7 II Nikon Z9 Nikon Z 14-30mm F4 Nikon Z 85mm F1.8 +4 more
n057 Veteran Member • Posts: 8,798
The USB connector in the D500 will accept a micro-USB or USB-3 cable, so if you have a lightning connector with eiter one of those USB ends, you can use the D500 as a card reader. You might want to read some additional information, in case Apple has some extra requirements.
JC
Some cameras, some lenses, some computers
 n057's gear list:n057's gear list
Nikon Coolpix 995 Nikon D200 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm F1.8G +7 more
OP Elliern Senior Member • Posts: 1,737
Sagittarius wrote:
Thanks for responding.
So you are saying I need a USB to lightning adapter and then a USB XQD card reader and connect them together?  The link above does not say it’s compatible with XQD card.
Ellie
Enjoy the Moments!
A.A. Milne
  • Elliern wrote:
Sagittarius wrote:
You can connect regular USB card reader to the USB on this adapter and connect adapter to your phone. It is does not matter if it is XQD or SD or whatever cardcit is. Also you need a software on your phone to be able to open files. I do not use iPhone, so cannot help you there.
Best regards
arniebook
arniebook Senior Member • Posts: 2,454
The special USB cord that comes with the camera can be used with the adapter mentioned for your IPhone.  You don't need a XQD reader.  You can also upload to a computer with the same cord.
Arnie
What we spend on this stuff is equal to the depth of our pockets squared ($²) times what we (j)ustify in our minds as to what we expect to do with our pictures plus (+) the (e)njoyment we experience from using our stuff and sharing the result ... $xxxx=$²(j+e )
 arniebook's gear list:arniebook's gear list
Nikon AF Nikkor 50mm f/1.4D Nikon 200-500mm F5.6E ED VR Nikon D300 Nikon D500 Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +3 more
